NX vs nos - Mustang Evolution
Old 06-12-2009, 03:19 PM   #1
GT773's Avatar
NX vs nos
i have been loockin for a nitrous kit and so far i like both of these i looked for a thread on nitrous on here and couldn't find one. anyway what do you guys think
GT773 is offline   Reply With Quote
Old 06-12-2009, 03:41 PM   #2
hottcobra's Avatar
Re: NX vs nos
I have have the zex kit for the 05+ mustang and I love it. It's by far the best wet kit out there for your car. It adjusts from 75hp-175hp.
Old 06-12-2009, 03:59 PM   #3
SaleenFiend's Avatar
Re: NX vs nos
Louis is on the money again! (nothing new)
Old 06-16-2009, 07:32 AM   #4
slostang's Avatar
Re: NX vs nos
Zex is very good! and I have quite a few friends running the dynotune kits also... They have some pretty nice pieces.
DynoTune - DynoTune-Nitrous systems, Purge kits, Nitrous Bottle heaters and more!
Hi Rob
slostang is offline   Reply With Quote
Old 06-16-2009, 07:47 AM   #5
Re: NX vs nos
all of them are good if installed right.
tvs supercharger,20 lbs of boost,cti stepped header, cti 3" catless dp,cti 3" catback,79# injectors,ls4 tb,rebel 3" cai, cx raceing heat exchanger ,billet rotated tranny mounts,dss stg 2 axles,spec 3 plus clutch,spec alum flywheel,steel crank,steel rods,hyper. pistons,4.05 1st gear,posi diff.. tuned by auto motion .next week meth and more boost.
fast cobalt is offline   Reply With Quote
Old 06-16-2009, 02:31 PM   #6
jimbullit's Avatar
Re: NX vs nos
And let me "chime in here"-is there any problem with setting a lightly modded `stang-for the "shot"?
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 06-16-2009, 05:21 PM   #7
upton7's Avatar
Re: NX vs nos
can u just get some sweet piston rings or should you get forged internals too?
Old 06-16-2009, 08:15 PM   #8
Y2E0L0L5OGWT's Avatar
Re: NX vs nos
the 4.6L 3V Mod motors are pretty well built to handle 50-100hp shots with completely stock everything and a good tune...I wouldnt go much beyond that before I started building up the motor...
As for brand, NX, Nos, and Zex are pretty well all the same...the key to spraying is all in the tune...****ty tune & you will blow it up, 50-shot or otherwise...
Old 06-16-2009, 09:10 PM   #9
Re: NX vs nos
Run whichever kit you care for...I will tell you this. If you plan on keeping the nitrous around for a while go ahead and invest in a wet kit with a wot switch and find a good tuner. If you use those resources wisely you will be running nitrous safely for a long time with no ill side effects.
Old 06-17-2009, 12:41 AM   #10
hottcobra's Avatar
Re: NX vs nos
How about I sell you the kit off my car?
Old 06-17-2009, 07:02 AM   #11
2007STANG's Avatar
Region: West Virgina
Re: NX vs nos
wHATS ALL IN THE KIT AND HOW MUCH
Billet fuel door, Daiblo 91 Tune, Xenon ram air hood scoop, MAC performance direct fit headers, 3" 304 SS Dual exhaust, hood pin appearance kit, Red l.E.D. underbody lights, Boy Racer rear wing, Helix power tower plus Throttle body spacer, ventvisor deflector, Aeroform chin spoiler, SVT 18" 9.5 45/255 frount SVT 18" 9.5 40/285 rear trire , GTO rear blackout kit, OEM rear splash guards, Steeda CAI, 8.8 rear axle with 3.73.1 LSD, killer Glass Hose, Smoked Window Louvers by GT Styling 35% Tenting on rear and side windows.
2007STANG is offline   Reply With Quote
Old 06-17-2009, 09:38 AM   #12
GT773's Avatar
Re: NX vs nos
nos has a 50-75hp kit which i like i don't want to go to hard core with nitrous. it has your pretty standard stuff with the kit its got the soft plume nozzle, window switch, 10bls. bottle, and all your fittings and hoses.
Old 06-26-2009, 12:34 PM   #13
Re: NX vs nos
The key to any nitrous setup is the tune, if you have a bad tune it doesn't really matter what shot you're running. I've seen a 4.6L 3V run a 150 shot on a stock internal motor safely. Just do what everyone else has already said on here and you'll be fine. Buy a kit that you like, get or do a CORRECT installation, and get a good reputable tuner, and enjoy the extra ponies
2008 Torch Red Mustang GT
SCT3/JLT intake and Bamachips 93 race tune l shorty antenna l rear blackout panel l RT hood struts l Steeda Tri-Ax shifter l JBA LT's l O/R H pipe l FRPP Stingers l DDM 55w 8000k Headlights and fogs l Blacked out turn signals l M/T ET Street Radials
Best time with mods-13.1@105mph(before LT's)
echoinsilence is offline   Reply With Quote
Turbo or Supercharger or NOS???? Camaro Eater Pre-2005 V6 Mustang 71 07-22-2010 09:22 AM
NOS Zebs5408 Pre-2005 V6 Mustang 4 05-30-2009 08:20 PM
Where can I get a NOS/NX? Stang01 Pre-2005 V6 Mustang 23 07-29-2003 09:07 PM
How much NOS/NX shot wont F me up Stang01 Pre-2005 V6 Mustang 8 07-26-2003 08:35 AM
04:24 AM
