no fuel pressure ? - Mustang Evolution
Old 06-23-2009, 09:49 PM   #1
no fuel pressure ?
I am new to this so if i am posting this wrong i do apologize . I have a 2006 mustang gt . when car is sitting still the rpms flukuate just a little , but if i turn air on the rpm will drop to 0 and kill car when clutch ingaged. I checked fuel pressure and fuel pressure is only at 35 and when acceleration givin the rpm actually drop instead of getting stronger . I have replaced fuel pump and fuel filter already . the only code the check engine light is a cam postion sensor, but ive heard that other people thought that was the problem and it was not
Chasity:love:
Chasity is offline   Reply With Quote
Old 06-23-2009, 10:03 PM   #2
Otlaw80's Avatar
Re: no fuel pressure ?
35psi is about right at idle, could be a bit higher, but shouldn't be your problem. I wonder if the 4.6's have a fuel pressure regulator? could be an issue. I'm not familiar with the 4.6. Does the pressure drop when u give it gas?
Old 06-23-2009, 10:08 PM   #3
yes it has a fuel pressure regulator but it is actually built on the fuel pump. so you can say it has been changed also i guess . the pressure does drop when you give it gas
Chasity:love:
Old 06-23-2009, 10:36 PM   #4
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
has it been modded at all? i was really expecting an older car when i said the tps... still could be a possiblity, but i wouldn't suspect it on a newer model...
when did this all start? had anything changed around the same time this started that you can think of? maybe something within a couple weeks?
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 06-23-2009, 10:45 PM   #5
MonteCitan's Avatar
Are any of your lines crushed or kinked?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 06-24-2009, 05:41 AM   #6
bbunt302's Avatar
Could be a leaking injector.
Scary stuff.
Old 06-24-2009, 07:51 AM   #7
jimmy_beaner's Avatar
Region: Iowa
your fuel pressure (if similar to 99-04) is right on. Autometer tells me 25-40 psi at idle.
The top gauge is my fuel pressure gauge.
Your fuel pressure should react like that. I'm not sure how you're measuring it (Schrader Valve and throttle blip?)
Old 06-28-2009, 03:22 PM   #8
I am testing fuel pressure by disconnecting the fuel line from fuel rail and hook it up that way. I do not have a schradier valve
Chasity:love:
Old 06-28-2009, 03:26 PM   #9
My fuel pressure actually drops when i gas on mine. by the way your car sounds real good
Chasity:love:
Old 06-28-2009, 03:32 PM   #10
not that i have noticed , just got it back from the ford place . they changed throttle body and a sending unit. 660.00 dollars. the throttle body did fix the problem with my car dieing when air is on when i am stopping . but did not fix my hesitation.
Chasity:love:
Old 06-29-2009, 07:43 AM   #11
ive heard that the 05+ cars are known for their hesitation in the gas petal vs go it can be set with a tune they say
Old 06-29-2009, 12:27 PM   #12
Ok thank you. Now are you meaning a tune as like a tune up or a programer ?
Chasity:love:
Old 06-30-2009, 06:42 AM   #13
jimbullit's Avatar
He's talking about a hand held programmer. Probably my next investment..
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
need help with custom fuel rails, fittings, fuel pressure gauge tire Pre-2005 V6 Mustang 2 07-13-2015 03:32 PM
holley adjustable fuel pressure regulator trickflow5 1979-1995 Mustang GT 6 01-13-2007 01:51 PM
NX fuel pressure safety switch cuban3jumper Mustang Parts for Sale and Wanted 0 12-29-2006 12:04 AM
Fuel pressure guage questions eagle05 1979-1995 Mustang GT 4 10-25-2006 04:47 AM
Stock fuel pressure Duncan 1979-1995 Mustang GT 3 10-22-2006 02:57 PM
05:11 PM
