Check engine light-SHEESH - Mustang Evolution
Old 06-26-2009, 04:50 PM   #1
jimbullit's Avatar
Y'all: I haven't had a "check engine light" on-in any vehicle-since I cratered my `75 Honda Civic-back in `79. Here's the dang deal-I had a check engine light on two days ago. I rolled into the dealer-had called my technician ahead of time-he hooked up the reader-it was a "misfire code" on cylinder #2. He replaced the coilpack and installed a new plug. `Code gone. That is, until this morning. The "idiot"light is back on. I have heard from a dood at work-who's Dad owns a 2006 GT-he had this same problem(s). #2, and #5 cylinders, pulling codes. After he started to pull mods of the car-and then his idle fan quit working-the dealer finally replaced his computer-hasn't had any problems since. I REALLY hope that I amnot "that guy". I don't have a heavily modded car-as anyone can see in my signature. My `08 has 3150 miles on it-with the second "idiot" light on. Anyone here, relate to this??
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 06-26-2009, 08:14 PM   #2
OsirisGuy's Avatar
Re: Check engine light-SHEESH
Is it the same code?
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 06-29-2009, 06:51 AM   #3
jimbullit's Avatar
Well-yesterday-Sunday-it disappeared. So I am unable to see what code it "was"... I guess I'm going to have to take it by the dealer and get another "reading" of the ECM.
Old 06-29-2009, 07:01 AM   #4
im sure they will take care of it, if its the same thing mention the computer but... unless you really know your tech chances are they will ignore what ever you way.
Old 06-30-2009, 07:02 AM   #5
jimbullit's Avatar
The ?good news?-or, not-the light went off-after about 36 hours. I am also intimately accquainted with the technician-as I worked at the store for 3 1/2 years, and he's worked on numerous cars and trucks that I have owned/ currently owned. They also hired a Service Advisor-that used to work on our service aisle-he writes it up, Tommy takes care of the rest. I will post the result(s) here. I'm going to try and visit there, tomorrow.
Old 06-30-2009, 07:10 AM   #6
good, keep us posted
Old 07-03-2009, 09:59 AM   #7
jimbullit's Avatar
Well I went back to get the diagnostic hookup. It coded an "intermittent misfire"-back to the #2 cylinder. The fuel system was "bled down"-all the injector pressures were measured-then when that proved to be okay-an unknown(content)software upgrade was uploaded. There-so far-hasn't been a problem. I think it's related to my CAI moving 144% more air-than the system is calibrated for-which is causing a "trickle down" effect. I'm moving forward with a handheld programmer-to remap the PCM-as I probably should have done-when I installed my power pipe and bigger MAF.. `More will? be revealed?
Old 07-13-2009, 10:49 AM   #8
jimbullit's Avatar
This just in-so far-no check engine light-next is handheld programmer
Old 07-20-2009, 10:04 PM   #9
i assume its a p0302? i assume he did a power balance test. what did the mode 6 data look like?
iamdat is offline   Reply With Quote
Old 07-21-2009, 07:17 AM   #10
jimbullit's Avatar
iamdat-WOW-that went a little over my head. I probably should have been paying more attention. I basically wrote about what I payed attention to-and that was the answer he received from the Tech Staff + the mysterious "software update". So far-no more "check engine" light. I'm just trying to figure out which programmer to use. I have used DiabloSport two other times, with decent results- `03 MaCh 1, and a 2003 Cobra.
Old 07-21-2009, 08:47 PM   #11
sorry, i used to be a ford tech in my previous life. actually, i went to UTI for the FACT program. i like ford a lot
holler if anything pops up, id love to help
Old 07-22-2009, 01:41 AM   #12
MonteCitan's Avatar
ditto, used to be a ford tech
Mode 6 is basically a way of tracking problem areas over a longer period of time
Your 'software update' may very well have fixed your issue (hopefully) Usually dealers don't update software unless required (TSB/recall) or it's to fix an issue basically directly related to the problem in question
Good luck!
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 07-22-2009, 07:24 AM   #13
Good luck!
exactly!
Old 07-23-2009, 06:43 AM   #14
jimbullit's Avatar
I really appreciate ALL ASE Certified/ Factory trained Technicians:worship: One of these days...I'm going to go to our local community college-as one of the techs where I work suggested :whistle: so that I can learn a little more of the basics. Honestly I have been doing preventive maintenance to my cars-since my Dad showed me how to adjust the valves on the `65 Beetle I shared with my older brother-when we were in high school I also worked at the local Ford store for 3 1/2 years, beginning in `02-and met some fine folks there-I still take my Mustang over there-to the SVT guy. He and I became friends over the years-him working on my Lightnings and Cobras-me selling he and his family cars:thumbs2: It's ALL good.. :spot: !
check engine
Check Engine Light - Help! Eeyore General Mustang Discussion 15 04-23-2009 07:26 AM
check engine light on! 1999Stang Pre-2005 V6 Mustang 2 08-09-2008 12:04 PM
Need Help with Check Engine light dch61407 1996-2004 Mustang GT 2 01-30-2008 07:01 PM
check engine light avery_y Pre-2005 V6 Mustang 9 01-13-2007 06:16 PM
Check engine light donnie Pre-2005 V6 Mustang 1 05-22-2006 02:53 PM
04:08 PM
