bullit oem rims - Mustang Evolution
Old 06-29-2009, 06:01 PM   #1
BaginDVS1's Avatar
bullit oem rims
I think I have bullit oem rims. they have the cobra center caps, and they are staggerd. i donot know what the exact size of them is, is it 17 x 8 front 17x 8.5 in the rear? I dont know the specs on them any help.
2nd thing is i want to sell them what is a good price? i looked on ebay, but have not really seen ones like these on there? I think they are for the 05.
BaginDVS1 is offline   Reply With Quote
Old 06-30-2009, 06:59 AM   #2
Re: bullit oem rims
if they are 05+ they are 17x7.5 and will fit pre 05 but only with spacers. A good price would be 150-200 without tire if no curb rash.
If they are pre 05 they are 17x8's
also note the rules for posting classifieds, you have to have a post count of at least 100 but you will be there before you know it.
Old 06-30-2009, 01:45 PM   #3
Y2E0L0L5OGWT's Avatar
Re: bullit oem rims
Incorrect..
05+ Bullitt's are 17"x8" just like all previous models...The issue is with the offset...The 05+ Bullit wheels have a +45mm offset...But you are correct that 05+'s will fit previous models with wheel spacers...Previous model bullit's will not fit 05+'s...
Old 06-30-2009, 03:14 PM   #4
Re: bullit oem rims
they have a 235 tire that budges over the edges I dont see how an 8 wide rim would work on the base level bullit looking wheel with only a 235, it wouldnt show over the edge of the rim..
Old 06-30-2009, 04:08 PM   #5
Re: bullit oem rims
Sure it could...Two 235 tires aren't the same tread width...The Pirelli Pzero Nero probably has a slightly wider tread than other 235 tires...You can look on tire rack & see what the actual tread with is for those vs. other tires...What might come up short of the edge for one 235 tire won't come up short on another tire...
In any event, the 05+ bullit wheels are 17x8's...I know this because I bought a set of Enkei Racing wheels that had to meet factory specs within +/-5mm offset to maintain legal for SCCA stock classing rules...Of course I run a 275/40 Hoosier R-comp on them so I have a lot of sidewall bulge
*Edit*
FWIW...
http://www.newtakeoff.com/mustang_wh...litt_each.aspx
Old 06-30-2009, 04:56 PM   #6
jimbullit's Avatar
Re: bullit oem rims
Wow I feel like I just received a tire/wheel education. I hope BaginDVS1-got the answer that he needed.
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 07-01-2009, 09:23 AM   #7
BaginDVS1's Avatar
Re: bullit oem rims
the best thing i could do is show a pic of them. yes the there is pirelli pzero neros on them, the front, but there is bf goodrich kdw on the rear. the only thing is this, the rims on the front are not as wide as the rears. the rears are dished out about inch and some it looks like. 235 front, 255 rear. they are staggerd.
Old 07-01-2009, 01:01 PM   #8
Re: bullit oem rims
interesting
Old 07-01-2009, 02:48 PM   #9
BaginDVS1's Avatar
Re: bullit oem rims
here are some pics. therer definently is a difference in the width of the rims.
ID:	20785   Click image for larger version
Name:	pirreli front.jpg
Old 09-12-2009, 12:21 PM   #10
Re: bullit oem rims
Not trying to be a jerk but, 235 is the width of the tire in millimeters (not necessarily tread width). There are 25.4 mm in one inch. Therefore the tire width in inches is 235/25.4 = 9.25 inches. On an 8" rim I think it would bulge a bit.
I measured my stock 235s and they are 9.25 inches from outside to outside. Oh, and they bulge a bit.
Al
RunningPony is offline   Reply With Quote
Old 09-12-2009, 01:11 PM   #11
Re: bullit oem rims
Tire discussions are always a headache.
For this lesson we have a tire: 235/55-15
235 - width in millimeters, from widest point sidewall to sidewall, not necessarily tread width
55- aspect ratio, % of width that is sidewall height from rim to tread
ex. 235mm x .55= 129.25mm
15 - rim size
The letters in tire sizes denote construction and speed rating, and have nothing to do with its size.
I know most of you know this, but its easier to just put that out there because some people have just never been shown or were taught wrong growing up and are just going to get confused.
Yeah I know that we aren't even all discussing the same thing in this thread but I was bored.
ThaWill is offline   Reply With Quote
Old 09-13-2009, 06:30 AM   #12
edross's Avatar
Re: bullit oem rims
those rims are not oem, i dont think Ford ever staggered the rims other than the gt 500
2003 gt, sct custom tuned by VMP, k&n fipk, upr o/r x-pipe, dynomax turbo mufflers, mm c/c plates, mm full length subframe connectors, h&r race springs, bullit rims 18x10 rear 18x9 front, 4.10 gears, 20% tint, 9 inch shorty antenna
edross is offline   Reply With Quote
Old 09-13-2009, 04:50 PM   #13
Re: bullit oem rims
I do know one thing, you have to reduce the price because you have now used them. Doesn't matter for how long. they have been used. Second thing is more scratches and dirt on them plus if you decide to keep the tires off them less money they worth. Plan and simple. I have been there and done it.
tjzola is offline   Reply With Quote
Old 09-14-2009, 07:32 AM   #14
Re: bullit oem rims
generally speaking ford wheels/tires are much cheaper than other brands~ which is good for aftermarket
Old 09-15-2009, 09:43 AM   #15
jimbullit's Avatar
Re: bullit oem rims
That appears to be a set of Wheel Replica's "deep dish" black bullitt wheels. I had a set on my MaCh1 when I purchased it-sold them to a dood with a black GT for 400.00-with tires mounted-after I installed the OEM MaCh wheels back on the car..
Old 09-15-2009, 07:08 PM   #16
edross's Avatar
Re: bullit oem rims
i just sold my original bullits with worn out tires for 300
WTB: Bullit, Saleen, or Cobra rims kcfan_2004 Mustang Parts for Sale and Wanted 9 09-24-2008 05:36 PM
WTB Bullit rims Sublime782 Mustang Parts for Sale and Wanted 3 07-18-2007 12:18 PM
WTB OEM Bullit rims Sublime782 Mustang Parts for Sale and Wanted 4 04-13-2007 10:40 AM
17" Bullit rims of a 2002 mustang gt for sale ssaleen Mustang Wheels & Tires 4 04-13-2007 05:30 AM
FS: 03 Cobra and 02 Bullit Rims PureVenom Mustang Parts for Sale and Wanted 5 01-30-2007 07:39 PM
12:59 PM
