New to Forum... - Mustang Evolution
Old 07-03-2009, 02:32 AM   #1
New to Forum...
Hi all Im new to the forum and just wanted to say Hi.I have a 2007 V6/w pony package.
I was thinking of adding a cat back exaust and a BBK cold air intake.Would this void the warranty on the car.The cold air intake does not require a tune.Thanks for the info...
SPovelko is offline   Reply With Quote
Old 07-03-2009, 09:37 AM   #2
jimbullit's Avatar
Re: New to Forum...
There are laws to protect consumers-who want to modify their cars. The only time there is a "potential" problem-is where they are able to "trace back" to the add on parts-as being a "cause"/ "contributor"-and then they can disqualify the warranty work-but they have to be able to first, definatively prove -the mods "caused" the problem in the first place. I say go for it, and welcome!
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 07-03-2009, 12:02 PM   #3
Re: New to Forum...
they can only void the warranty if they can proove that what you did caused the damage, but ...some dealers dont care about the law and will just tell you its voided when its not
Old 07-03-2009, 12:24 PM   #4
Re: New to Forum...
Thanks guys for the advise.It is my understanding that the warranty can not be voided unless you re-tune the engine?Which the BBK intake does not require.Do you have any info on tuneing???
Old 07-09-2009, 06:49 AM   #5
jimbullit's Avatar
Re: New to Forum...
`That's a-d-v-i-c-e.. There are a bunch of thread postings-currently-where folks are discussing tuning-and throttle bodies-and welcome
Old 07-09-2009, 09:23 AM   #6
Re: New to Forum...
they can only void the warranty on the part you replace and any parts it influences. An exhaust would only void the exhaust warranty for example. Some ford dealers are very anal about this and will void the entire thing at the drop of a had... it is illegal and they are in the wrong but try fighting it... you wont win.
Old 07-09-2009, 09:35 AM   #7
Re: New to Forum...
So basically I should'nt add the cat back,or the intake ???
Old 07-09-2009, 09:40 AM   #8
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
Re: New to Forum...
maybe try asking your local ford dealership first and see their view on it before going through with this just in case you have a problem down the road :dunno:
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 07-09-2009, 09:41 AM   #9
hottcobra's Avatar
Re: New to Forum...
I worked as a tech for years. I've never seen a voided warranty from a cat back exhaust and a cold air intake.
you will be fine.
Old 07-09-2009, 09:43 AM   #10
Herbstang's Avatar
Re: New to Forum...
He speaks the truth !! The dealer has you by the balls when it comes to mods Some are very cool some are ******* !! Doesn't matter if you tune for the CAI or not Although if your not gonna tune for the CAI you might as well stay stock
Quotes form Justin From VMP Tuning
"The BBK CAI no tune requires that the factory transfer function be modified by roughly 15% for fueling to be correct, that is a fact.
However, without proper tuning, it may eventually set a check engine light.
I just don't see the point in putting so much effort into something that is still technically wrong. "
2nd quote
"None of those people you quoted are actual tuners though. There is a big benefit to "claiming" that your intake requires no tune, its appealing to the consumer that has not done a lot of research, and makes them think they can get into a performance part for less money. In reality, properly tuning the PCM is important when you put the MAF sensor into a larger housing.
I would say that KN is probably the only true no tune required intake, and thats because its CARB legal and they must answer to the government"
Old 07-09-2009, 09:44 AM   #11
hottcobra's Avatar
Re: New to Forum...
they don't void the warranty anyway. they just tell you that they can't fix it under warranty because of the aftermarket. If that happens. just go to another dealership.
Old 07-09-2009, 03:59 PM   #12
wiarumas's Avatar
Re: New to Forum...
welcome
Old 07-09-2009, 04:19 PM   #13
Re: New to Forum...
welcome to the site.
96 GT- Who knows what's in it.
New to forum 02apex New Member Introductions & Greetings 19 01-16-2007 02:26 PM
New to Forum Mustang Cherly New Member Introductions & Greetings 16 12-07-2006 02:10 PM
New To Forum The Arson The Bar 12 08-24-2004 08:47 PM
11:55 PM
