Urgent throttle body question! - Mustang Evolution
Old 07-05-2009, 12:08 AM   #1
Exclamation Urgent throttle body question!
Does a bbk throttle body work with a jlt cai? will it need to be tuned if I just put on the throttle body?
GhostStang is offline   Reply With Quote
Old 07-05-2009, 09:44 AM   #2
Re: Urgent throttle body question!
yes, you will need a tune if its a GT, I am pretty sure on a V6 as well.. My idea behind this is if your CAI doesnt require a tune... guess what... its not good enough and doesnt flow enough air to warrant one, I would get one that does require it.
The throttle body in your near stock car is worthless, dont waste your money on it.
Old 07-05-2009, 12:13 PM   #3
Yes I realize it is near stock worthless, but I plan on buying a jlt cai from bama with their tunes. Will the throttle body pose any difference then? Im looking at one that I can get for 125 dollars from a friend. (it looks next to new).
Will bama alter the tunes if I have a bbk tb?
Old 07-05-2009, 02:02 PM   #4
upton7's Avatar
they will make the tune for whatever you have put on you can get bbk holley anything they will do it
Old 07-07-2009, 08:35 AM   #5
05bluestang's Avatar
Don't get the BBK TB, you are asking for trouble. I'm running a SC @ 10psi with the stock TB, it flows plenty. Use the money for something else (better)...................
2005 Mustang GT, Pacesetter LT's with OR H-pipe, "Magna Pack" exhaust, Techco SC @ 9psi making 464whp & 449tq, steeda tri-ax shifter, 3D Carbon Eleanor Grill, Pioneer F90BT, FRPP 3.73 gears.
Get in, sit down, strap in, hold on, shut up!
05bluestang is offline   Reply With Quote
Old 07-07-2009, 12:20 PM   #6
I've seen cars run the stock throttle body up to 400-500 hp, like bluestang said, just save the money and spend it something better.
2008 Torch Red Mustang GT
SCT3/JLT intake and Bamachips 93 race tune l shorty antenna l rear blackout panel l RT hood struts l Steeda Tri-Ax shifter l JBA LT's l O/R H pipe l FRPP Stingers l DDM 55w 8000k Headlights and fogs l Blacked out turn signals l M/T ET Street Radials
Best time with mods-13.1@105mph(before LT's)
echoinsilence is offline   Reply With Quote
Old 07-08-2009, 12:34 PM   #7
aftermarket throttlebodies hardly show gains on forced induction. spacers are garbage as well. for the price of a throttle body you can get a set of steeda pullies and delete plates.
jroc07gt is offline   Reply With Quote
Old 07-09-2009, 06:31 AM   #8
jimbullit's Avatar
Just clean the stocker from time to time-buy something else
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
throttle body ? wvstang5.0ho 1979-1995 Mustang GT 16 07-29-2008 10:48 AM
throttle body kingboy23 2005-2010 Mustang GT 7 05-06-2008 06:31 AM
throttle body sonicpony Pre-2005 V6 Mustang 2 09-09-2007 12:23 AM
Question about throttle body sizes Jrw4482 1979-1995 Mustang GT 10 02-27-2006 04:22 PM
throttle body Murph00 Pre-2005 V6 Mustang 5 11-26-2004 11:43 PM
10:15 AM
