electrical problem - 2005 - Mustang Evolution
Old 07-05-2009, 06:29 PM   #1
Hi,
First post...
I have a 2005 and yesterday, both my key fobs stopped working. The batteries in both check out OK. I went to check the fuses and can't get the fuse box cover off!
Can anyone shed some light on what could cause the remotes to suddenly stop working and how do I get this danged fuse box cover off???
Thanks!
Aaron
2005Aaron is offline   Reply With Quote
Old 07-05-2009, 06:59 PM   #2
Y2E0L0L5OGWT's Avatar
Re: electrical problem - 2005
Did your battery recently die or did you recently replace it? If so, that would cause them to require reprogramming...
Old 07-05-2009, 07:05 PM   #3
UPDATE:
Using the procedure in the owner's manual, I reprogrammed the fobs and they now work, but not like they did before.
Before, one press of the lock button would lock the doors and flash the lights. Two presses of the lock button would lock the doors, flash the lights, and chirp the horn ONCE.
Now, one press locks the doors. No lights.
Two presses locks the doors, NO lights and the horn chirps three times.
PLUS - now my headlights (only, no other lights) are on dimly when ever the key is in the ignition. It didn't used to do that. They are not on fully, just about half regular brightness.
I don't like my headlights being on all the time.
Any ideas?
Thanks.
Old 07-05-2009, 10:58 PM   #4
OsirisGuy's Avatar
Did you place your fobs next to a magnet? Doing so could have erased them. Some of those features maybe programming issues, what I mean by that is that the alarm has features as to whether or not the lights flash, the horn honks and if one click locks one or both doors.
However it sounds like the problem may be a little more. Sorry I can't be of more help.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 07-23-2009, 06:49 AM   #5
jimbullit's Avatar
Have your favorite tech hook up a diagnostic reader-to make sure that you aren't pulling any codes. It sounds like something additional-outside of deprogrammed/reprogrammed fobs is happening too...
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 07-27-2009, 07:28 AM   #6
jimbullit's Avatar
2005Aaron-I could hardly believe it my own self yesterday I decided to attempt to adjust the passenger door reveal. I was successful at that then the same thing happened-that you wrote about. (I will have to say that earleir in the day-with an adult riding in the vehicle-my wife -that the passenger airbag "off" light was lit on the dashboard-for some unknown reason) And I made that adjustment to the latch-as I said... My pea brain wants to connect these two separate things-as to why my fobs deprogrammed themselves-cuz they did for no known reason, suddenly. OK-so I get the manual out-in the driveway-and I am NOT able to reprogram either keyless fob. I give up. This morning I unlock the car-old school-with the key. I get to work. I turn the car off. I decide for "grins" to try the fob-it works!: So I try the programming sequence-and reprogram both fobs on the spot.. WOW! The aliens attacked my Mustang and put an alien whammy on the computer. I'm just going to keep an eye out and-find my ray gun-in the meantime...
2005 Mustang GT - Problem with Radio and Windshield Wipers Mr_Horsepower 2005-2010 Mustang GT 11 08-03-2017 12:57 PM
electrical problem with my 65 Mustang convertible joeyemma Classic Mustangs 3 04-27-2009 09:42 PM
electrical help! please! trickflow211 1979-1995 Mustang GT 0 07-31-2008 12:25 AM
electrical problem? dave1170 1979-1995 Mustang GT 1 03-11-2008 12:51 PM
Problem with electrical system kitslik Pre-2005 V6 Mustang 4 11-29-2007 09:56 PM
10:32 PM
