AutoMeter Triple Gauge Dash pod - Mustang Evolution
Old 07-07-2009, 07:57 PM   #1
hello all,
I am a VERY proud new owner of an 05 mustang GT. Definetly a big upgrade from my V6. After I got it home I finally noticed it only had a few gauges (tach, fuel level, water temp, speedo....no oil pressure and volts). I really would like to have the other gauges but do not want to replace the factory cluster. I found the autometer dash pod with 3 gauges included for a decent price. The thing I am wondering about is how hard will the gauges be to put in? Will the kit come with some great instructions if any one has bought it. Is routing the wires easy? Is hookup easy? and clean? I have searched and searched on the forum but I am either not good at it or havent seen what I am looking for.
here is the kit
Auto Meter 2005-Up Mustang Triple Dash Pods - JEGS
thanks to all for help
tripod_2005 is offline   Reply With Quote
Old 07-08-2009, 08:58 AM   #2
05bluestang's Avatar
Re: AutoMeter Triple Gauge Dash pod
I got SOS a-pillar pod with Aeroforce interceptor gauges. Tha gauge pod replaces the existing a-pillar cover. Love it, simple install. They gauges plug into the OBDII port. Need a separate sending unit if you want to monitor oil pressure, Ford does not use one on our cars.
Speed of Sound 2005+ Ford Mustang gauge double and triple gauge pillars
AeroForce Interceptor Scan Gauges - GM, Ford, Chrysler, Special Order - PFYC
Oh yea, almost forgot......Welcome!
2005 Mustang GT, Pacesetter LT's with OR H-pipe, "Magna Pack" exhaust, Techco SC @ 9psi making 464whp & 449tq, steeda tri-ax shifter, 3D Carbon Eleanor Grill, Pioneer F90BT, FRPP 3.73 gears.
Get in, sit down, strap in, hold on, shut up!
05bluestang is offline   Reply With Quote
Old 07-08-2009, 09:22 AM   #3
jimmy_beaner's Avatar
Region: Iowa
I would go with the Speed Of Sound ones as well. I have the 2 pod version on my 02 GT, and I love it. Their bullet style gauge pods are excellent looking. It matches the interior perfectly.
Old 07-08-2009, 09:43 AM   #4
I'm not real big on the a-pillar gauges....almost a little ricey. I like the dash pod because not every car can have a gauge pod like that. You can put pillar gauges on almost every car out there.
How hard would it be to hook up a oil pressure, volts, and water temp gauge??
oh and thanks for the welcome but I have been on the site before in the v6 part. just forgot my username and what not so i re-registered
Old 07-08-2009, 09:51 AM   #5
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
from most of the ones i've seen id say this to be true, but looking at the sos ones, i kind of want them now, they aren't the huge bulky crappy molded ones you see on every civic in town, if i ever go f/i ill definitely be picking these up
also... welcome back!
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 07-08-2009, 11:27 AM   #6
the install will be a ton of wires~ but its not THAT bad, you can combine some of the wires. You will have to drill into the dash though. What other gauges do you need?
Old 07-08-2009, 12:33 PM   #7
drill into the dash?? I thought it said everything was mounted with adhesive back. I am doing this because I would like the volts and oil pressure. I had a alternator go out in my 6er and I noticed it because of the gauge.
Old 07-08-2009, 12:53 PM   #8
well the wires have to go somewhere, so you will have to drill holes for them to go down into the dash to be hooked up.
The aero force gauges are quite nice, they are super easy to hook up as well. The only issue is they are only as accurate as the OEM computer in the car is, as they use the ODBC port to read from.
Get electric do NOT buy mechanical gauges fyi. Oil pressure is a great one to have as the stock gauge SUCKS and is useless (if 05+ even have an oil pressure gauge)
water temp is a good one to have as well as the stock one once again is worthless.
Old 07-08-2009, 01:42 PM   #9
Right now I'm monitoring A/F (I have a separate PLX gauge in a Roush vent pod for that), on the Aeroforce I have fuel pressure, water temp, oil temp and charge air temp (for the blower). I did not get the MAP sensor yet to hook the boost up but that's next.
BTW if you do have to have a dash pod, SOS makes one that sticks on and the wires are run through the defroster vent, so no need for drilling into the dash.
Speed of Sound 2005+ Ford Mustang Center Dash Gauge Pods
Old 07-08-2009, 05:21 PM   #10
im still confused on what you are talking about that you need to drill holes in the dash. If you look at the kit, really look at it, it is pretty much the same as the SOS pod with a different look. I dont like the looks of the SOS pod as is it not made to match the stock dash.
whats the reason not to buy mechanical gauges?? yes oil pressure will be one I will be wanting to put in. 05+ only come with that gauge with the my color cluster I believe.
Old 07-08-2009, 06:56 PM   #11
If you have an idea for something custom...just email SOS. He's a great guy and I run by his shop every once in a while. He's part of our local SVTOA chapter.
He's finishing the touches on a machine that will help him get custom pieces out quicker...I promise if you can dream it up he can make it.
Old 07-09-2009, 07:28 AM   #12
jimbullit's Avatar
Where can I get a fun meter???
I let my wife drive my car to work yesterday-as I had the day off, and was picking up my old take-offs, and getting her Escape serviced/tires rotated. She called me when she got to work-she had a blast driving to work-and one co-worked passed her in the paking lot with that smile.. That was the first time since I bought it. She really dug it!
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 07-09-2009, 10:24 AM   #13
the gauge pod that sits on top of the dash just sticks on, no drilling... but the gauges that go into the gauge pod... how are you going to run the wires for them? you need holes to run the wires through. Thats where the drilling comes in.
Old 07-09-2009, 10:30 AM   #14
On some, you run it down the defroster duct.................
Old 07-09-2009, 06:36 PM   #15
You can run wires all the way to them with no drilling, just have to know how. The A pillar will pull right off and you can run the wires behind the dash and bring it up at the A pillar with no drilling.
Only drilling needed is where the actual pods mount.
Old 07-10-2009, 10:11 AM   #16
hmm interesting, I didnt know it went back all the way to the defrost vent
Old 07-10-2009, 12:31 PM   #17
the dash gauge pod snaps into the first row of defrost vents....thats why I was asking what you meant by "you will need to drill holes in the dash"
Old 07-10-2009, 01:21 PM   #18
Yup, I don't have one but was told it's a snap to install. I have the a-pillar one and with Interceptor gauges the whole install was about 15 - 20 min, took me longer to program the gauges then to install everything
Old 07-12-2009, 05:03 PM   #19
hello all,
here is the kit
if you want some help installing the autometer pod or the sos center pod i have done both to my vehicle.. you can put both of them in without any drilling of holes... there is a place on the right side of the cabin that will give you a place to go thru to the engine bay without drilling a hole!!!!
i have autometer electric units for fuel, and oil presure, a boost guage , oil temp. water intercooler and engine water temp, voltage guage and air/fuel guage... my vehicle is an 06 v6 supercharger with water to air intercooler... can help if u wanted to installed.if you sent me an e-mail address can sent you picture of my setup....jim
2006 v6 5 speed prem coupe, pony package
vortech supercharger with air to water intercooler
oil cooler,4 inch alum driveshaft,8.8 gt rear end,
gt front sway bar and strut tower bracket,
8 auto meter electric guages
colorado pony is offline   Reply With Quote
Gauge Wire Routing w/CDC gauge pod tripod_2005 2005-2010 Mustang GT 13 04-30-2010 12:46 PM
gauge pod upton7 1996-2004 Mustang GT 9 12-01-2009 02:54 PM
99-04 autometer lunar gauge cluster notstock02gt Mustang Parts for Sale and Wanted 4 05-09-2007 12:00 PM
Autometer Mustang 2005+ 3 gauge pod Airwinger63 Pre-2005 V6 Mustang 1 05-07-2007 04:02 PM
Bad Autometer Boost Gauge? initialb 1996-2004 Mustang GT 5 08-02-2006 12:35 PM
04:20 PM
