wiring in a trailer pigtail - Mustang Evolution
Old 07-16-2009, 06:39 AM   #1
Need some advice please. I have a hitch install on my 07 GT to tow my tire trailer, but need to install the wiring pigtail. The manual warns of attaching a pigtail. I need to know where to properly install the wiring and not place the harness in jeopardy. Any advice? Thanks in advance....
olds350 is offline   Reply With Quote
Old 07-16-2009, 10:44 AM   #2
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
Re: wiring in a trailer pigtail
i don't know about the newer mustangs, or even the older ones for that, but the way my ranger was set up you just had to unplug the turn signal harness and plug in a spliced harness. On my moms explorer the manual said not to splice into the tail lights for some reason, they went to a shop to get it wired and i think the did the same thing that i did to my ranger iirc.
I know this probably doesn't help much, but that is how ford did it on two separate vehicles.
you could also try asking the dealership and see what they tell you:dunno:
EDIT: http://allfordmustangs.com/forums/20...ustang-v6.html
that might give some info, there is one suggestion of running relays and whatnot to the lights, hope it helps
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 07-16-2009, 11:02 AM   #3
From another thread on this topic....
Originally Posted by yoyofruity View Post
The hard wiring is done and my hitch is on. Took the kids out fishing with the top down some time ago.
Here is where I got the hitch and wiring.
wiring
hitch
Moss Mustang Store - Parts and Accessories for your Ford Mustang
Old 07-16-2009, 11:24 AM   #4
Region: Oregon
i think that video says exactly what that other forum was talking about, it will light up an led tester, but it won't light up actual lights.. i dunno, good find on the video, i was looking all over for something relating to this.
Old 07-16-2009, 12:36 PM   #5
PM that yoyo guy...he is the one that started the thread about it and that video is what he provided as his means of hooking up his boat trailer.
Personally, hitches on a mustang are retarded in my book, but, it's not my car so I'm just provided the info I have available to me.
Old 07-16-2009, 01:00 PM   #6
retarded eh? Then show me a better way to haul 4 r-comp tires, jacks, spare gas and tools in the car for a day at the track and I'll dump the trailer hitch.
after talking to the local ford dealer and local hitch store, I think the best bet is to go w/ a powered pigtail to limit the draw on the thin *** wiring in the car. Still need to tap the lights, but only to signal the relay that's direct powered by the battery. Thanks for the responses.
Old 07-16-2009, 01:05 PM   #7
Truck and trailer. You wanna be a racer, you gotta pay to play.
Old 07-16-2009, 01:30 PM   #8
I'll be happy to drive what ever truck & car trailer you want to buy me. Otherwise it's a tire trailer.
Old 07-16-2009, 01:35 PM   #9
Clever.
Old 07-16-2009, 02:51 PM   #10
yea, the best thing is to trailer it so when it eventually breaks you are not stranded
Old 07-16-2009, 03:17 PM   #11
Region: Oregon
i fit 2 people and a set of r-comps in my 94 coupe... still had the ****** spare, a floor jack, a tub to put everything in (jackets, sweatshirts, a stuffed penguin that likes to ride in the back seat, rule book, haynes manual that also doubles as a numbers holder, tripod, camera, and water) 2 helmets and i think that is it...
i could have fit my basic tool set in there, but for some reason i didn't bring it :S
i see vettes pull tire trailers all the time at the track, i think its a good idea, but at the same time i don't want to put a hitch on my car.
Old 07-21-2009, 07:27 AM   #12
jimbullit's Avatar
:worship: Extremely good video-very helpful-and I get the trailer gig. HOT ROD has a contest-whereby, everyone has to drive their race car from track to track-and that means you will have to have more stuff than the car will hold-a lot of doods use a small utility trailer-pulled by the race car...
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
2000 Mustang V6 Wiring Door panel wiring problem wyatt-00' Pre-2005 V6 Mustang 3 11-30-2009 12:43 AM
New GTA4 Trailer Brent Pictures and Videos 14 12-07-2007 01:36 PM
New I Am Legend Trailer Brent The Bar 10 10-25-2007 12:03 AM
SAW 4 TRAILER!!!!! Cajun JungleBoy The Bar 9 04-09-2007 05:00 PM
Pirate's 3 trailer Seph The Bar 2 03-20-2007 01:20 PM
03:55 PM
