Do you need a chip? - Mustang Evolution
Old 08-04-2009, 12:22 AM   #1
Do you need a chip?
I have been looking into getting new exhaust for my 'Stang, '09 V6, from the headers back and a new intake. I have a mechanic friend who says that I will need to get a new chip or my 'Stang will be 'throwing random codes'. I am guessing he means to say that me stock brains will not know what to do with the new parts?
snydermj is offline   Reply With Quote
Old 08-04-2009, 02:12 AM   #2
Re: Do you need a chip?
O.o...they should. After you do so much you'll have to tune it to get the maximum performance out of it, but I don't think it'l throw random codes.
19Delta is offline   Reply With Quote
Old 08-04-2009, 06:43 AM   #3
by "chip", he meant a tuner of some sort. they make handheld tuners such as diablo and SCT. it is possible those Mods can throw codes so he is correct
iamdat is offline   Reply With Quote
Old 08-04-2009, 09:31 AM   #4
For just a catback exhaust a modification to the car's computer is not needed. If you remove the cats then it will be needed.
Do not ever buy a "chip" and by "chip" I mean a chip that plugs into the computer and stays there. You want a tuner. This will plug into the port under the drivers floor board and reprogram the computer backing up your stock files.
You also can not just buy a tuner from anyone and be good to go. You need a REAL tune, not the off the shelf one size fits all tune.
Old 08-05-2009, 08:36 PM   #5
I have been skeptical since I have not heard of that before. Since those are bolt on parts I didn't think there would be a problem.
I don't plan on removing the cats but I think I will be getting performance cats. Are performance cats worth the money and time?
Old 08-06-2009, 12:17 AM   #6
MonteCitan's Avatar
Actually, unless specifically designed to not need a reflash, most CAI kits for the 05+ require a reflash with the install to keep from throwing lean codes.
Performance cats are fine, but what's worth it more is an aftermarket H or X pipe, cats or no cats it will be an improvement, axle back exhaust also are supposed to have good results..
One of the best mods you could do would be a rear gear swap.. which would also require a tuner to calibrate your speedometer (3.73s minimum.. I vote 4.10s for the 05+ due to powerband/delivery..) That's if you have a manual.. 4.10s minimum if you've got an auto
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 08-06-2009, 11:06 AM   #7
gears hurt gas mileage but.. thats the price you have to pay
Old 08-09-2009, 02:09 AM   #8
MonteCitan's Avatar
Doing all city driving, driving about the same or even a little harder I've GAINED 1-2 MPG by switching to 3.73s
Old 08-10-2009, 07:27 AM   #9
yea true you will gain in the city and lose on the highway.
Back to CAI's and Tunes... I would rather have a tune... that just means that the modification made enough of an actual change that the car needs to be modified to handle it... lol
Old 08-10-2009, 08:38 AM   #10
The Darkside's Avatar
do yourself a favor NEVER get a "chip" i have done that and i regret it so much.
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 09-06-2009, 08:24 PM   #11
ARSMITH25's Avatar
Are Jet Performance Modules considered a chip?
http://www.jetchip.com/Shop/shopdisp...ppp=10&catID=1
ARSMITH25 is offline   Reply With Quote
Old 09-08-2009, 07:31 AM   #12
hmm i dont think that is actually what everyone is refering too, but that does alter the programing in some way. anyone wanna help in the question??
i bleed Race fuel!
Old 09-08-2009, 08:22 AM   #13
^^ not sure I understand the question?
some ebay companies market a "chip" (to be a chip it actually has to be a circuit not a resistor though...) but its 100% BS... it just dumbs your computer into thinking the incoming air temp is cold so it adds more fuel. Its the IAT sensor and you can do that yourself with a resistor for Radio Shack for 1 dollar or less. They also say 35+ mpg which is laughable... I dont see how ebay lets them sell that trash.
Old 09-08-2009, 08:54 AM   #14
the question was whats the diffrence between the Jet chip and when you get a tune and they install it with a chip vs a hand held?
i bleed Race fuel!
Old 09-08-2009, 11:29 AM   #15
its all basically the same~ as far as I know. The reason more today are hand held is its much easier to modify and install to begin with I would think. It all about what is ON the chip or hand held that matters.
Old 09-08-2009, 07:40 PM   #16
2007STANG's Avatar
Region: West Virgina
I Have a JET Chip and have been happy with it but """now to i need to get a hand held to do my next mod""" the JET for mine was $297 the hand held is $361 so in the long run its better to get the hand held if your going deap into moding also my dealer reset the rear gears but only had 3.73 in there program so check and only certion tire size
Billet fuel door, Daiblo 91 Tune, Xenon ram air hood scoop, MAC performance direct fit headers, 3" 304 SS Dual exhaust, hood pin appearance kit, Red l.E.D. underbody lights, Boy Racer rear wing, Helix power tower plus Throttle body spacer, ventvisor deflector, Aeroform chin spoiler, SVT 18" 9.5 45/255 frount SVT 18" 9.5 40/285 rear trire , GTO rear blackout kit, OEM rear splash guards, Steeda CAI, 8.8 rear axle with 3.73.1 LSD, killer Glass Hose, Smoked Window Louvers by GT Styling 35% Tenting on rear and side windows.
2007STANG is offline   Reply With Quote
Old 09-11-2009, 06:54 PM   #17
Nice links here
jerseymike68 is offline   Reply With Quote
Chip Gray Ghost 1996-2004 Mustang GT 6 04-02-2009 09:04 AM
what chip should i use CCstang2004 Pre-2005 V6 Mustang 17 06-30-2005 10:32 AM
chip Sublime782 Pre-2005 V6 Mustang 11 06-09-2005 02:32 AM
f2 chip ttpancakes Pre-2005 V6 Mustang 3 07-07-2004 10:46 AM
Chip ERICK Pre-2005 V6 Mustang 2 08-08-2003 05:50 AM
11:27 AM
