Jacking the back up. - Mustang Evolution
Old 08-04-2009, 05:42 PM   #1
I am currently painting my brake calipers and it sucks lol. Its not that hard just time consuming. I am having to use the factory jack on each individual jack spot (started front driver, and almost done with driver rear now). My problem is that I have a huge jack thats flat on top and could lift up the whole back of the car... Only problem is Im not sure where to put it. My idead was on the rear differential... but the manual says NO!~!!!!~@!~!~ dont lol.
GhostStang is offline   Reply With Quote
Old 08-04-2009, 06:15 PM   #2
Re: Jacking the back up.
do it anyways, just make sure you aren't putting the weight on the cover
ThaWill is offline   Reply With Quote
Old 08-04-2009, 06:15 PM   #3
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
maybe get a second floor jack, or use your scissor jack on one side and your other jack on the other? the floor jack i have doesn't really sit in the body lift points, but that or on the outside of the axle (not the dif) is supposed to be ok from what i've read
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 08-04-2009, 06:23 PM   #4
ok Thank you
Old 08-05-2009, 08:51 AM   #5
for the front put it under the K member for the rear you can put it on the torque arms (where the lower control arms bolts to the frame) and put a jack stand there then do the other side, you can jack with putting it under the rear differential but you must NOT have any pressure on the rear differential cover as it will cause leaks. You have to push it forward a bit more to put it on the pumpkin fully so it doesnt put pressure on the diff cover.
Old 08-05-2009, 03:46 PM   #6
OsirisGuy's Avatar
You should be able to jack up on the axles. Invest in some jack stands so you can lift up a side and leave it up and work. You can lift up one side at a time instead of worrying about getting both ends up at once. Using the factory jack is good but I wouldn't leave my car sitting up on one.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Differ Ways of Jacking bluemustang Pictures and Videos 25 03-02-2007 08:26 AM
Welcome myself back! Autobadges.com New Member Introductions & Greetings 21 06-26-2006 12:31 AM
i'm back... dark The Bar 18 09-12-2005 10:07 PM
Crispy's back...back again Crispy The Bar 9 04-09-2005 02:04 PM
11:57 AM
