Help! Convertible top won't go down! - Mustang Evolution
Old 09-30-2009, 06:48 PM   #1
Hi,
I have recently purchased a 2006 GT convertible with 42K and after a couple of weeks in my possession I have found that the top goes down intermittently. That is I can always power it up but it might go down the first time I try and back up but then when I try to repeat a few minutes later it will not go back down. It always goes back up (I can hear the motor turning if I press the up switch even when it is in the latched up position. I have narrowed it down to the switch or the mini relay #31. Has anyone had similar issues? If so have you replaced the switch and how tricky is it? It is no trouble to replace the relay if necessary.
I should note that when the top does not go down neither do the windows. This leads me to believe it may be the switch. Finally I have yet to switch the up and down mini relays; I will do so when the top stalls again in the down mode.
Thanks for the help!
Eric
madscientist is offline   Reply With Quote
Old 10-01-2009, 04:36 PM   #2
Re: Help! Convertible top won't go down!
i would check the motor for leaks just to be safe and while you are looking see if its working and see if its getting power.
convertible top pipeguy 1996-2004 Mustang GT 13 07-26-2008 08:36 AM
Convertible top Scarlet General Mustang Discussion 3 06-05-2008 10:34 PM
Convertible top mustangmare Mustang Parts for Sale and Wanted 2 06-07-2006 06:11 PM
Convertible top V6STANG007 Mustang Audio & Video 12 08-24-2004 08:32 AM
09:16 AM
