2006 Clutch - very minor chatter from 1st - 2nd - Mustang Evolution
Old 10-03-2009, 05:32 PM   #1
Howdy All,
My 2006 has had a "touchy" clutch ever since I bought it. It takes a push near the floor before you can change gears. I have to move the driver seat up to have more control of the clutch and shifting. This clutch feel is most annoying when going form 1st - 2nd. It's not uncommon for me to stall. I've had this car for more than a year, so you'd think I would be used to this clutch by now.
So I guess I'm asking if it's a big deal to adjust this clutch?
Also, I've noticed this week that there is very minor chatter going from 1st to 2nd. Doesn't happen all the time, mostly when the clutch is partially engaged. (like going up a drive way, etc)
Will an adjust help the "feel" allowing for engagement faster as the pedal is pushed? Is the chatter something to be concerned about?
2006 Redfire GT
5sp manual
18in fanblade wheels
Stock
Thanks in advance,
RedFire2006 is offline   Reply With Quote
Old 10-07-2009, 09:06 AM   #2
jimbullit's Avatar
Re: 2006 Clutch - very minor chatter from 1st - 2nd
It sounds like you need a clutch. If the "throw" is "all the way at the floor"-you are probably at-or close to zero adjustment. There is a hydraulic component to these clutches-which I don't particulary care for-and have compensated for this by shifting at the "top of the pedal". This is a 5900 mile clutch-and that's the way I have shifted it-since purchasing the car back in April...
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 10-07-2009, 09:37 AM   #3
you can adjust is so its higher up aka more petal push before it reaches the floor. This might fix the issue. Since you dont have a clutch cable not sure how to adjust it but it cant be that bad. I am pretty sure the manual has how to do it but... their way (if its raising up on the petal and pushing it in or what ever which yours may not can do) generally doesnt work. There may be a screw or something you can do.
Old 10-07-2009, 09:19 PM   #4
I did a poor job describing the "feel". It's more the combination of clutch and gas that is required to **** smoothly. It's got more of a drag strip setup than a "stuck in traffic" "pulling up the driveway" setup.
Hope that makes sense.
2006 Mustang clutch problems brokenford Pre-2005 V6 Mustang 1 03-18-2008 12:48 PM
trans problems 1st to 2nd automatic 96 cobra vert 1996-2004 Mustang GT 14 10-19-2007 01:41 PM
Clutch chatter Mike D. Classic Mustangs 13 03-30-2007 03:07 PM
Belt slips when shifting from 1st-2nd??? mohrnormal 1996-2004 Mustang GT 5 04-12-2006 02:45 PM
2006 V6 Manual Trans - Bucks in 1st Gear in AM lovcom Pre-2005 V6 Mustang 9 11-20-2005 09:08 AM
01:48 AM
