Problem with Locking & Anti Theft - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 2005-2009 Mustang GT
Closed Thread
Old 10-09-2009, 10:05 AM   #1
Tungstenblade is unknown around these parts
Hey guys well let me tell you my story. I have an '06 mustang which was involved in an accident...some girl smashed into my right side as i was passing her on the side and totally destroyed the right side fender and scratched the car all the way to the back...
My Doors were locking perfectly before and after the accident with the remote. One press would lock and two presses would beep the horn and flash the lights real quick. Here is where the thing gets messed up. I dropped off my car at a body shop to get repaired and after about a week I got the car back looking perfect.
I get home, park the car and when I am about to leave the car I hit the remote twice to lock the doors and hear the beep like I am used to hearing... Instead I get this: the doors lock and I get 2 beeps and my lights don't flash... wtf? I am not sure if the locking anti theft is working correctly anymore? would disconnecting the battery for a long period of time mess that up? would it need reprogramming? I am just concerned because I get no indication the doors are actually locked...I have to physically check them both now everytime its driving me crazy... I hope someone can chime in please. Thx
Tungstenblade is offline
Old 10-09-2009, 10:41 AM   #2
Blogger
Blogger
rickf73's Avatar
rickf73 is unknown around these parts
Send a message via MSN to rickf73 Send a message via Skype™ to rickf73
Re: Problem with Locking & Anti Theft
I forgot and left my truck ajar last week, I had hit the button to unlock but did not open it. When I hit the lock on the key the cars horn made two quick blows and light flashed. Once I closed the truck it set itself then.
Sounds like the systems is reading the door ajar.
rickf73 is offline
Old 10-09-2009, 12:27 PM   #3
so what your saying is that maybe the sensor or door pin is not telling the system that the door is closed?
Old 10-09-2009, 12:48 PM   #4
Blogger
Blogger
rickf73's Avatar
If the door is closing then that could be it. Maybe a sensor is misaligned or bad. I don't know how they make contact but if it is proximity that might be it.
My trunk did not look like it was open but somehow the sensor did not make contact. As soon as I closed it the system armed.
rickf73 is offline
Old 10-09-2009, 08:15 PM   #5
ThaWill is unknown around these parts
There is probably a little button near the door hinges that the door panel depresses when you close the door. At least thats how it is on most vehicles. It works the dome light and junk and lets the car know when the door is closed. Check to make sure its not broken, or popped loose from the dash.
ThaWill is offline
Old 10-09-2009, 10:57 PM   #6
OsirisGuy's Avatar
OsirisGuy is unknown around these parts
Yeah the "door sensors" will be the same switches that causes the dome light to come on. Same thing for the trunk (and hood). Make sure they are all properly being closed and switching off.
Also I thought I remember reading that the new Fords allow user programmable locks (something to that effect regardless). That is you can program the lights to not blink, blink once, or blink twice when you lock or unlock.
If when you hit the lock button, the car fully locks around then the system should be operating fine. Unlocking the car should be once for driver side, and a quick push right after should unlock the rest of the doors (i.e. passenger side). As long as it does this it sounds like the car is fine just some settings have changed.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
OsirisGuy is offline
Old 10-12-2009, 07:35 AM   #7
Terminator Owner
SpectorV is just getting started.
when you lock it so it beeps and you hear two beeps that means the car thinks the car door is still open. As said that sensor (in the door jam) is probably just messed up.
SpectorV is offline
Old 10-12-2009, 09:50 AM   #8
jimbullit's Avatar
jimbullit is unknown around these parts
: Mine doesn't beep-after I have hit the lock button, the parking lamps flash. If I hit it a second time the parking lamps will flash-and the horn will chirp.
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline
Old 10-13-2009, 09:56 AM   #9
OsirisGuy's Avatar
Usually on the PATS system the first lock will give a "silent" confirmation, that is the parking lights may or may not flash, depending on the programming. The chirp is just a "check" for the owner so if you forgot if you lovked your car or you hit lock too many times the car will let you know it has already been locked by chirping.
OsirisGuy is right
2002 Mustang GT
Closed Thread
Gears &Speedometer problem??? arlander344 1996-2004 Mustang GT 6 10-12-2009 12:54 PM
anti-theft system lowering kit 1996-2004 Mustang GT 3 06-19-2008 09:17 AM
Amp problem Stumpy Mustang Audio & Video 14 09-11-2006 07:50 PM
Locking Fuel Door Dom Mustang Audio & Video 25 09-05-2005 12:49 PM
Anti theft keeps triggering shutdown of car! ASSEMbler Pre-2005 V6 Mustang 2 08-17-2003 09:24 AM
03:03 PM
