Lowering a S197 Mustang - Mustang Evolution
Old 10-18-2009, 02:17 PM   #1
wkndpaintballer's Avatar
Send a message via AIM to wkndpaintballer
How is one supposed to lower these cars. The lowering springs i have found range from a 1" to a 2" drop in the rear but if I lower my car that much it will be bottoming out on the bump stops.
NOBODY cares about threats over the internet. Don't try to act hardcore with the keyboard. FIGHTING ONLINE is like racing in the special Olympics; even if you win, you're still RETARDED .
wkndpaintballer is offline   Reply With Quote
Old 10-18-2009, 03:19 PM   #2
Re: Lowering a S197 Mustang
This article gives you a good idea on how the springs are installed.
Installing Mustang Lowering Springs
Most lowering springs lower the car 1" to 2". The average drop is around 1.5" The car won't bottom out after being lowered this much, but you should still be careful around inclines, speed bumps and driveways. Leaving the isolators in will keep the rear higher.
I'm sure someone with a lowered 05+ will chime in.
Old 10-18-2009, 03:29 PM   #3
Well I measured the spacing and it's only about an inch and I actually need to get longer bump stops bc my tires are a little wider than the fenders and the tires already rub on them when it bottoms out
Old 10-19-2009, 07:43 AM   #4
for 05+ cars its the same idea but the fronts are coil over the the procedure is a little different. The most important part is deciding on springs. My friend went with Eibach Pro kit they gave it a good drop and the ride isnt much worse than stock (a touch more bouncy on the highway but not bad)
Your tires (unless you added a huge spacer) should not hit the fenders if they are the stock wheels. What do you mean by hitting them.
Also keep in mind alignment has to be done~ and you will need something to allow this if you go much lower than stock.
Old 10-19-2009, 07:49 AM   #5
Blogger
Blogger
rickf73's Avatar
Send a message via MSN to rickf73 Send a message via Skype™ to rickf73
I have Eibach Kit on mine and it is lowered 1.5. I do have to watch going over some bumps and 45 some inclines but the rides is still good. I know one guy that lowered his 2 in.
rickf73 is offline   Reply With Quote
Old 10-19-2009, 08:20 AM   #6
yea, but if you dont lower it enough where you have to worry about bumps and such scraping then... you didnt lower it enough
Old 10-19-2009, 09:55 AM   #7
No I don't have the stock wheels and the new ones stick out about 1/2 inch from the fenders and when I bottom it out on some of our extremely rough roads the tires rub on the fenders to the extent that I have a new tread line. The fronts aren't an issue as they camber in when compressed
Old 10-19-2009, 09:56 AM   #8
I'll take some pics to show exactly what I'm talking about in a couple hours
Old 10-19-2009, 10:53 AM   #9
I thought you had the stock rims going by your signature pictures (at least I thought they were the stock ones). Ive not seen taller bump stops just shorter ones for the rear. I my self have the same issue you have, mine are to far out for as low as I am. Being I have an IRS rear they tuck in but just not quite enough (very nearly so though)
Old 10-19-2009, 10:58 AM   #10
yeah thats an old pic from when i first got the car
Old 10-19-2009, 12:11 PM   #11
heres a link to how the car looks now http://www.cardomain.com/ride/2615020
and to the pics on the tire width and bumpstop height http://www.mustangevolution.com/foru...lbums519-3568/
http://www.mustangevolution.com/foru...lbums519-3569/
Old 10-19-2009, 12:39 PM   #12
The Darkside's Avatar
wow, your car looks ILL! Its a very diffrent look then ive seen. its not my thing, but that deff stands out from the crowd!
im not much into low profile tires, im old, so im old school lol
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 10-19-2009, 12:39 PM   #13
had to ask, what kind of front bumper and grill??
i bleed Race fuel!
Old 10-19-2009, 02:30 PM   #14
the bumper is from ait racing its the stallion 1 design there are 3 of them now but i cut out the original grille that came in it and made a billet one to go in. i wasn't going to go that big on the rims but i got a good deal on them. and standing out is my goal i hope to soon be able to paint it a dark metallic red
Old 10-20-2009, 06:47 AM   #15
edross's Avatar
thats the biggest wheels i have ever seen on a stang
2003 gt, sct custom tuned by VMP, k&n fipk, upr o/r x-pipe, dynomax turbo mufflers, mm c/c plates, mm full length subframe connectors, h&r race springs, bullit rims 18x10 rear 18x9 front, 4.10 gears, 20% tint, 9 inch shorty antenna
edross is offline   Reply With Quote
Old 10-20-2009, 09:58 AM   #16
i have wheel envey lol
i bleed Race fuel!
Old 10-20-2009, 01:41 PM   #17
jimbullit's Avatar
Dangit! Can't get to cardomain-blocked here at work..
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 10-20-2009, 01:56 PM   #18
My 05 GT is down about 1.5" and occasionaly I will drag the exhaust at the x-Pipe clamps on a big speed bump but that's about it.
If you lower your car as much as I did, you will also need to add an adjustable panhard bar to realign the rear end housing, and it is a good idea to check your pinion angle after lowering too. I found my front end was out so I had to add caster camber plates to correct the "top in" condition my car had.
Just a few things to consider...
Casey4s is offline   Reply With Quote
Old 10-20-2009, 02:28 PM   #19
I guess my main concern is that when my rear suspension is fully compressed and it bottoms out on the bump stops my rear tires rub on the edge of my fenders. Easy fix longer bumpstops but I want to lower my car about an inch or so but the distance from the top of the bumpstop to the frame is just over an inch so my thinking is that if I get the longer bumpstops and lower the car it will be resting on the bumpstops all the time ie no suspension travel. Witha that said if I lower it without the longer bumpstops it will be more prone to bottoming out the suspension and rubbing the tires on the fenders. Anyone have any ideas onhow to solve this problem
Old 10-20-2009, 03:00 PM   #20
you will hit the fenders~ its just a matter of time since your tires stick out to far. If you want to lower it and keep that from happening the only way to do it and do it right is to get different rims might not be the answer you want but it is the only answer I have that wont cost you a ton more than just new rims.
(shortening the axle, possibly removing mounting wheel surface material if you can both tuck the wheel in, bump stops might fix damage but will mess you up driving as they will hit regularly if you drop a decent amount)
Old 10-20-2009, 03:05 PM   #21
The only other thing I could think of besides that is to flare the fenders bc I don't want to remove any of the backspacing because at some point I plan on gettin a widebody kit
Old 12-07-2009, 08:22 AM   #22
Something the shop that installed my Eibach ProKit Springs didn't know or didn't tell me is this....you need an adjustable Panhard Rod to recenter the rear of the car over the axle after lowering the car. I drove 30K miles without knowing this. A guy at Shelby told me about it when I was buying 20x9 Razor wheels. I didn't notice before but did after new wheels on...the left rear tire appears to stick out a little further than the right. I got a Steeda Adjustable Panhard Rod installed. Another expense to think about and another necessity if you lower your car.
07GT is offline   Reply With Quote
Old 12-07-2009, 08:29 AM   #23
+1 good advise, its not a big deal on stock wheels/tires but with fender flush it has to be much closer.
Old 12-07-2009, 10:54 AM   #24
jimbullit's Avatar
That dood will kick rocks out-behind you-for anyone that's following too close..
Old 12-07-2009, 11:55 AM   #25
Loc: Austin,TX
You could always roll you fenders instead flairing them.People roll fenders all the time because of clearance issues.
Old 12-07-2009, 12:59 PM   #26
05+ fenders are rolled from the factory
Old 12-10-2009, 10:57 AM   #27
05bluestang's Avatar
Why are you wheels sticking out? Are they from an SN95?
I'm lowered 1½" and cut the bump stops down to the last "knob"" I have no bottoming out or rubbing issues tith 285/40-18 on 10" rims. I know people that took the bump stops out all together and have no issues.
2005 Mustang GT, Pacesetter LT's with OR H-pipe, "Magna Pack" exhaust, Techco SC @ 9psi making 464whp & 449tq, steeda tri-ax shifter, 3D Carbon Eleanor Grill, Pioneer F90BT, FRPP 3.73 gears.
Get in, sit down, strap in, hold on, shut up!
05bluestang is offline   Reply With Quote
s197 mustang
East Coast S197 Mustang Shootout - Boonsboro, MD (04-24-10) 2K05GT Regional Mustang Discussion 0 04-18-2010 04:46 PM
2009 East Coast S197 Mustang Shootout (11-1-09) NC 2K05GT Regional Mustang Discussion 1 08-30-2009 09:43 AM
2009 East Coast S197 Mustang Shootout Rygen Regional Mustang Discussion 0 02-18-2009 07:11 AM
Australian S197 Mustang GT Brent 2005-2010 Mustang GT 8 06-25-2007 12:23 PM
06:34 AM
