Replacing stereos with DVD/gps unit - Mustang Evolution
Old 10-20-2009, 04:25 PM   #1
Cool Replacing stereos with DVD/gps unit
Has any body done this ??? and any words of advice. I have 2008 mustang.
please give me brands,model and if you used stock amp or not???:
GRAYTAG is offline   Reply With Quote
Old 10-21-2009, 07:01 AM   #2
OsirisGuy's Avatar
Re: Replacing stereos with DVD/gps unit
What do you currently have in your car? Is it just a plain stock radio or do you have a DVD/GPS unit in there already? OR do you even have the Sync system.
For the most part the install is exactly the same as a regular radio.
Brand wise I'd recommend Pioneer.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 10-21-2009, 09:18 AM   #3
I have the stock radio in now but want to upgrade to have DVD/GPS.
But I do not have "Sync"..........Wish I did.
Old 10-21-2009, 09:29 AM   #4
OsirisGuy's Avatar
Then the install will just be like a regular radio, except you will just have to run a separate cable for the GPS and ground a wire to the parking brake for DVD.
OsirisGuy is right
2002 Mustang GT
Old 10-21-2009, 09:44 AM   #5
Did you use the stock amps???
Old 10-21-2009, 05:48 PM   #6
wkndpaintballer's Avatar
Send a message via AIM to wkndpaintballer
i have the shaker 500 system in my car and replaced the head unit with an Eclipse GPS unit. I agree Pioneer is probably the best choice but if its out of your price range look at kenwood they make a good product too. the stock amps will be fine as long as you dont have an aftermarket sub and amp. the stock amps are much more sensitive than aftermarket ones and the levels going to them must be kept lower or they sound horrible. i put a crossover on mine to keep the power levels to the factory amps low and higher to my amp in the trunk
NOBODY cares about threats over the internet. Don't try to act hardcore with the keyboard. FIGHTING ONLINE is like racing in the special Olympics; even if you win, you're still RETARDED .
wkndpaintballer is offline   Reply With Quote
Old 10-21-2009, 05:51 PM   #7
also do you know how the radio comes out?.. i found it to be a bit difficult until you find out the right way to do it
Old 10-21-2009, 11:22 PM   #8
OsirisGuy's Avatar
Written by yours truly
http://www.mustangevolution.com/forum/t119033/
Kenwood is good product, however I usually recommend Pioneer because their functionality is "out of the box" and you won't need to purchase any additional components. Pioneer also offers a wide variety of included features/uses for each head unit. For instance some Double DIN units have GPS but not DVD, vice versa, etc... Purchasing a higher end (GPS/DVD) Kenwood will probably offer the same functionality I like so much with Pioneer. You will have to compare your radio models to see which one suites you best.
As for using the stock amps you should be fine, just pick up a wiring harness for your car and it should all be plug and play.
You will also have to ground a wire to the parking brake so if you want to watch DVD the brake has to be engaged. Some units need the parking brake also engaged to set new routes on the GPS.
OsirisGuy is right
2002 Mustang GT
Old 10-22-2009, 11:35 AM   #9
00STANG00's Avatar
Send a message via AIM to 00STANG00 Send a message via Yahoo to 00STANG00
i tryed to replace mine but i cant get ne sound out of it i got 2 aftermarket cd players....there useless i got 4 4-way sony speakers
00STANG00 is offline   Reply With Quote
Old 10-22-2009, 12:05 PM   #10
Idk if u know but there is a way around the parking brake safety feature although it is illegal in some states
Old 10-22-2009, 12:36 PM   #11
00STANG00's Avatar
what u mean
Old 10-22-2009, 01:37 PM   #12
Please let us know your trick to not using your parking brake.????
Old 10-24-2009, 02:49 AM   #13
OsirisGuy's Avatar
Did you use an aftermarket harness? And does this harness have a square black plug? And did you plug the black harness into the correct square plug?
Yes I do know this and I completely refuse to let people know how to do this.
Newer units are now designed so that these "tricks" can not work.
OsirisGuy is right
2002 Mustang GT
Old 10-24-2009, 02:54 AM   #14
Originally Posted by OsirisGuy View Post
D
If there is a wire that must be connected to something for the video to work then there will always be a way to get around it
Old 10-24-2009, 02:57 AM   #15
OsirisGuy's Avatar
Yes, by hooking it up to the parking brake, as per the installation instructions. Usually it is the positive side of the parking brake wire.
OsirisGuy is right
2002 Mustang GT
Old 10-24-2009, 03:05 AM   #16
I'm not the person to argue with when it comes to electronics. I never said I would install someone elses radio like this or advise anyone to do it as it is illegal in some states I just said there will always be a way to bypass any safety feature that requires wiring the radio to something in the car
Old 10-24-2009, 03:15 AM   #17
OsirisGuy's Avatar
Yeah nothing personal, just the shops I've worked at have always pissed me off when it comes to this because they look the other way.
Just simpler if you want to bypass it, just install the radio as it was supposed to be installed. The "old method" of doing the opposite of this reached the new radio models and manufacturers included a program in them so the old trick will not work anymore.
The only car I would be willing to bypass is my own, or a best friend's car where I know I'm not getting paid for it.
OsirisGuy is right
2002 Mustang GT
Old 10-24-2009, 03:20 AM   #18
No I wo t install anyone elses like that but if they ask how it is done I will tell them the method and let them do it themselves. How is it Prevented bc I have a brand new eclipse DVD gps and the bypass worked on it
Old 10-24-2009, 03:35 AM   #19
00STANG00's Avatar
Exclamation Re: Replacing stereos with DVD/gps unit
yes it is a aftermarket harness and yes it as the black plug i get a static noice
Old 10-24-2009, 03:43 AM   #20
OsirisGuy's Avatar
If you want to install it on your friends' cars go for it, but personally if it's going to be involving me at some step (they ask me to install it, ask me how to install it, ask specifically how to bypass the bake) I will not tell them. Now to sound like a hypocrite, currently if I'm off the books and I can get a job by doing so I MIGHT take it and do it. This is only because I am currently out of work and I can't be in a position to turn away a paycheck. However at the same time so I left the last shop I worked at before the summer started I've only done one DVD install and it was on my best friend's car. I was also called at 12:30am when him and my other friend were trying to get it to work.
I'm assuming somewhere in the software it knows what it is looking for, I found this out on my friend's car. I do know specifically what it looks for, I just don't want to say. I shouldn't say all new models have the extra security but Pioneer does.
But even if the old way worked you still can't use it
OsirisGuy is right
2002 Mustang GT
Old 10-24-2009, 03:45 AM   #21
OsirisGuy's Avatar
Did the speakers work before the new head unit?
Did you plug in the correct wires? The dual DIN setup has two very similar square harnesses, one has 6-pins the other has 8-pins. You want to connect to the 8-pin harness.
OsirisGuy is right
2002 Mustang GT
Old 10-24-2009, 03:56 AM   #22
00STANG00's Avatar
ya there worken wit the stock one and ya i pluged it to the 8 pin the pins are kinda bent that might be y ill bent them back n see (my had been broken n to i hope they didnt f**k up anything
SUCK MY DUST
Old 10-24-2009, 03:58 AM   #23
OsirisGuy's Avatar
You say you're getting a static noise? On what? Radio? CD player? one or the other or both?
OsirisGuy is right
2002 Mustang GT
Old 10-24-2009, 03:59 AM   #24
00STANG00's Avatar
both i didnt have this much trouble with my 89
SUCK MY DUST
Old 10-24-2009, 04:12 AM   #25
OsirisGuy's Avatar
And the speakers worked before you replaced the head unit correct?
Don't mind these questions I'm just trying to troubleshoot.
OsirisGuy is right
2002 Mustang GT
Old 10-24-2009, 12:33 PM   #26
00STANG00's Avatar
yes
SUCK MY DUST
Old 10-24-2009, 07:49 PM   #27
OsirisGuy's Avatar
I would check over all your wiring. Nothing from the old audio system should be connected. Does the white static have volume control? It sounds like either the speakers are picking up interference, or the speakers aren't receiving a signal.
Did you connect both the power antenna and the amp turn on wire? Did you try to bypass the amps? Are the amps good? Have you checked the fuses?
OsirisGuy is right
2002 Mustang GT
Old 10-25-2009, 01:00 AM   #28
00STANG00's Avatar
no didnt bypass amps amps sound like they r ok no did connect the amp turn on didnt kno what wire to connect to(on the aftermarket cd player has a att wire do i connect amp turn on and the att wire?) no vulume at all i put a cd in and it stops fuses are good
SUCK MY DUST
Old 10-25-2009, 03:06 AM   #29
OsirisGuy's Avatar
Are you sure the radio is good?
The radio, in best circumstances, have a blue and a blue/white wire. More importantly you will want to make sure the blue and blue/white wire on the aftermarket harness going into the car is connected, and wired correctly.
OsirisGuy is right
2002 Mustang GT
Old 10-25-2009, 02:34 PM   #30
00STANG00's Avatar
it was in my 89 stang when i sold it i took it out it played in there
SUCK MY DUST
Old 10-26-2009, 08:51 AM   #31
OsirisGuy's Avatar
So were the two blue wires propery connected? I don't think '89 had any amps and I'm iffy on saying it also had a power antenna (although the power antenna in this case wouldn't cause the problem).
OsirisGuy is right
2002 Mustang GT
Old 10-26-2009, 12:53 PM   #32
00STANG00's Avatar
did yours have a mcah 460?
SUCK MY DUST
Old 10-26-2009, 02:07 PM   #33
idk about the power antenna not being the issue.. on my 4runner if the power antenna was not powered then the speakers wouldnt work
Old 10-26-2009, 02:12 PM   #34
00STANG00's Avatar
the pins inside the stock harness are all bent i think the pins on the aftermarket one is not going inside em
SUCK MY DUST
Old 10-26-2009, 02:18 PM   #35
if you are decent with electronics and wiring you could just hardwire it in but if they are bent on the factory harness then your factory radio shouldnt have worked unless you bent them when installing the new radio
What to do when replacing Odometer? fast64 General Car Discussion 5 01-17-2008 08:52 AM
have questions about stereos.....ask this guy Kyle The Bar 8 06-16-2005 01:58 PM
dvd head unit charkelly9 Mustang Audio & Video 7 06-13-2005 11:09 PM
05:36 PM
