Major Electrical Problems - Mustang Evolution
Old 10-28-2009, 10:02 PM   #1
wkndpaintballer's Avatar
Send a message via AIM to wkndpaintballer
Ok so I've determined that I have some major electrical problems. 1st off my battery dies after the car is left alone for more than like 4 hours. 2nd the door has started chiming like its open even it if it is closed. I have no idea what the problem is and the dealership cannot find the problem with it. all they tell me is that it is my aftermarket radio causing the battery to die but when they reinstalled the factory radio it was dead just the same the following morning.
NOBODY cares about threats over the internet. Don't try to act hardcore with the keyboard. FIGHTING ONLINE is like racing in the special Olympics; even if you win, you're still RETARDED .
wkndpaintballer is offline   Reply With Quote
Old 10-29-2009, 10:26 AM   #2
Re: Major Electrical Problems
sounds like something is pulling power, you just need to figure out what. Do you have any amps in the car or anything like that?
Old 10-29-2009, 11:59 AM   #3
Yes but it's all been in here for 3 years and it's just now starting to die
Old 10-29-2009, 01:31 PM   #4
OsirisGuy's Avatar
A leap would be that the battery has degraded since. A shallow charging battery that takes deep draws or vice versa may start to sound even more plausible.
If your car thinks your door is open I'd say that's the first hint. Figure out why it is telling you so. Could be something as silly as the overhead, or trunk, or hood light is staying on. Could be the door switch is grounding, or the switch itself is defective. I say if you want to test this; leave the door open so the reminder starts to chime then with you yourself close the door switch (i.e. with you hand/finger and not the door) and see if the chime still sounds. That could indicate it's not closing properly, or grounding properly, for the door and switch respectively.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 11-03-2009, 08:47 PM   #5
Ok so now my window instead of dropping the 1/2 inch to let the door open is now dropping 8 inches whenever the door is closed. It's like the door switch is backwards now?
Old 11-04-2009, 08:13 AM   #6
jimbullit's Avatar
Hook up the diagnostic unit to check codes-has this been done ?
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 11-04-2009, 09:44 AM   #7
OsirisGuy's Avatar
As when you close the door the window drops?
Have you made sure the window track and interior assembly is sitting right/working properly?
OsirisGuy is right
2002 Mustang GT
Old 11-04-2009, 10:50 AM   #8
ok a little more explanation here. normally when you open the door the window drops about 1/2 inch to keep the glass from hitting the top seal of the window and when it is closed it raises back up. now when the window is rolled all the way up with the door closed it drops down 8 or so inches (same spot every time). with the door open usually it goes up to the 1/2 inch drop spot and when closed it roll up to the top. now it rolls all the way up and hits the window seal so to close it i have to pull the plastic piece up a little to keep it from hitting but when it closes it drops down the 8 inches. its kind of like the sensor is backwards and thinks that 8 inch drop is the all the way up position.
Old 11-04-2009, 01:57 PM   #9
Got the window working again. Took it to the dealership and they fixed it and explained the reprogramming sequence to me
Old 11-05-2009, 05:14 PM   #10
OsirisGuy's Avatar
Well that's good to hear.
OsirisGuy is right
2002 Mustang GT
Fixing minor electrical problems 1983 Mustangman General Mustang Discussion 0 06-25-2010 10:50 PM
Electrical help kack85 Pre-2005 V6 Mustang 5 01-28-2009 04:47 AM
electrical help! please! trickflow211 1979-1995 Mustang GT 0 07-31-2008 12:25 AM
Major exhaust problems charkelly9 Pre-2005 V6 Mustang 26 08-20-2005 06:44 PM
major problems.. charkelly9 Mustang Audio & Video 9 05-11-2005 08:30 PM
03:03 AM
