Tires presure - Mustang Evolution
Old 11-04-2009, 12:41 AM   #1
carmonch's Avatar
Region: Mexico
Tires presure
Hi everyone! . I Changed the tires of my 2009 mustang GT for shelby size 288/40R18 rear and 255/45 R18 at front but can someone tell me the recomended "in cold" presure for this tires?
Tanhks !
carmonch is offline   Reply With Quote
Old 11-04-2009, 08:09 AM   #2
jimbullit's Avatar
Re: Tires presure
18s at about 35 p.s.i. That's what I roll with
:burnout:
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 11-04-2009, 04:09 PM   #3
Bstang03's Avatar
Region: Idaho
Re: Tires presure
It should say the recommended pressure on the sides of the tires
2003 Ford Mustang 3.8L V6
Bstang03 is offline   Reply With Quote
Old 11-05-2009, 09:13 AM   #4
Re: Tires presure
I generally run mine at 32-34psi~ right in that range. Keep an eye on wear and adjust as needed. More air = more middle tire wear, less air = more outside edge wear. Also an alignment has to be kept up~
Old 11-05-2009, 10:02 AM   #5
carmonch's Avatar
Region: Mexico
Re: Tires presure
:burnout:
Ok, Thank you very much.
Old 11-05-2009, 07:08 PM   #6
OsirisGuy's Avatar
Re: Tires presure
You'll want to keep the tire pressure at the car's recommended pressure which is usually located on a sticker inside the door jam. You do not want to exceed the posted tire pressure on the tires though.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 11-06-2009, 10:32 AM   #7
carmonch's Avatar
Region: Mexico
Re: Tires presure
yes i saw tis sticker and say 32 but the new tires are diferent size than originals and for this reason I don't knew the presure for news one . Thanks
Old 11-06-2009, 03:45 PM   #8
wiarumas's Avatar
Re: Tires presure
i usually go at 34ish. higher tire pressure also yields better gas mileage - just dont go too high.
Old 11-06-2009, 06:25 PM   #9
MonteCitan's Avatar
Re: Tires presure
The PSI number listed on the side of the tires = the maximum pressure for the tires, not the recommended pressure for driving
For daily driving I run ~32 PSI, if I'm going to the track I drop the rears down to ~28 if I'm going to drive spiritedly on the street, I bump it up to 35 or 36 all 4
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 11-06-2009, 07:08 PM   #10
Re: Tires presure
32................
billr814 is offline   Reply With Quote
Old 11-08-2009, 10:04 PM   #11
OsirisGuy's Avatar
Re: Tires presure
Different tires won't matter regarding the correct tire pressure unless you are running special tires or are filling them up to a specific pressure for performance. Just as long as you don't exceed the maximum tire pressure that's printed on the tirewall.
OsirisGuy is right
2002 Mustang GT
Old 11-09-2009, 09:14 AM   #12
jimbullit's Avatar
Re: Tires presure
32 p.s.i. - factory 17"-Upgrade to 18s - 35 p.s.i.
tires??? bluestang1724 Mustang Wheels & Tires 30 05-03-2006 06:08 PM
fuel presure regulator hose? blk2kconvstang Pre-2005 V6 Mustang 0 03-07-2004 01:00 PM
cobras/tires for welds/tires, $$$? tire The Bar 2 02-22-2004 11:11 AM
Difficulty installing presure line (power steering) 3.8turbo Pre-2005 V6 Mustang 0 11-03-2003 03:12 PM
02:17 PM
