Question about dynocharts & shift gears - Mustang Evolution
Old 11-16-2009, 11:05 PM   #1
I've been reading up on dynochart and dynotuning and there's still one question that's been bugging me and I haven't figured out - all of the dynocharts I've seen so far display a number of trial runs or 'pulls'. Each pull has a HP plot and a Torque plot over the same RPM range.
Why does each pull only show one set of HP & TQ plots over the RPM range even though there are multiple shift gears the transmission can be in? Why wouldn't a HP & TQ plot have to be generated & displayed for each gear the car transmission can be in? I'm thinking that the the TQ value at 4000 RPM in 1st gear would be different than the TQ value at 4000 RPM in 2nd gear and so there would be value in measuring and plotting the HP & TQ curves in each gear. For example, I could use those plots to determine the best shift points from gear to gear when driving a manual tranny.
Was wondering if anyone might know the answer to this or be able to correct me if I'm making a faulty assumption somewhere along the way? Is it maybe the case that a dynochart for testing in one gear can be used to represent the HP & TQ curves for any other gear (maybe by throwing in some type of scaling factor) and so one set of HP & TQ curves for a single gear is all the information you really need? When dynotuning is performed and dynocharts are generated, what gear is the car typically put in for testing?
FenixBirdWind is offline   Reply With Quote
Old 11-17-2009, 12:43 AM   #2
Re: Question about dynocharts & shift gears
It is because you don't care what the ho and tq are in any gear that isn't a 1:1 ratio. Otherwise, the numbers would be inflated. The operator will get the car into the 1:1 gear which is usually 4th gear in a 5 or 6 speed trans and 3rd gear in a 4 speed trans before they start logging. Logging in other gears wouldn't report your true power levels. Like I said, they would be inflated.
Old 11-17-2009, 12:51 AM   #3
Also, a dyno pull in a lower gear would not give you enough data to really see what was going on. For example, it takes very little time to hit redline in 1st gear where as it takes a bit longer to go from 2k to redline in a 1:1 gear. This gives you much better insight into what is happening as the motor is under much moreload for longer.
Old 11-17-2009, 08:07 AM   #4
They calibrate the dyno to work with what ever gear they do the pull in, they dont shift on the dyno to get hp/tq readings. Some do drag strip runs and shift on the dyno but this is more about ET's than HP/TQ
another question, i warned ya (shift kits) Senorjizzy Pre-2005 V6 Mustang 6 07-08-2009 11:33 AM
Get gears or stick-in a shift kit? AirBrontosaurus Pre-2005 V6 Mustang 22 03-13-2006 01:33 PM
shift kit question coolstang Pre-2005 V6 Mustang 23 01-04-2005 12:37 PM
Bought me a B&M Shift Kit Brent Pre-2005 V6 Mustang 40 06-11-2004 04:50 AM
Shift knob question dUckPhrEak Mustang Audio & Video 2 11-24-2003 09:48 PM
05:03 PM
