Aftermarket Coil Packs - Mustang Evolution
Old 11-30-2009, 08:52 AM   #1
jimbullit's Avatar
Angry Aftermarket Coil Packs
Well-after approximately one and a half weeks-and maybe a couple of hundred miles-I'm getting ready to send my Granatelli MotorSport "hotter" "street" coil packs back to American Muscle. My car is running like $*#+, with erractic idle, stall on take off, and poor performance.:
One of the techs-here at the car store where I am employed-who has a much hotter set-up Mustang than mine-ordered his from the manufacturer, GMS-and had similar problems. He had orderd the "track" coil packs-with a similar result(s) in 600 miles of use. He was able to contact someone at GMS-and they are sending him replacement coil packs, to "fix" the problem.
What a disappointment. Anyone have similar experience/know someone that has had a similar result, after installing these?
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 11-30-2009, 10:42 AM   #2
Re: Aftermarket Coil Packs
ive heard issues with them before, but no real other choices
Old 11-30-2009, 12:08 PM   #3
jimbullit's Avatar
I have also contacted the folks at E3 Performance Spark Plugs -regarding their really nice spark plugs-great performance-for 4.6 3V application/availability. Currently they don't have the longer plug(s) available, that the 3Valve 4.6 would require. They indicated they are 4-6 months from development/availability.
Old 11-30-2009, 01:48 PM   #4
nice, keep us updated
Old 11-30-2009, 01:56 PM   #5
outlawfrog's Avatar
We started pushing e.3's at work......so I did a little research on em, trying to decide if I wanted to use my hard earned discount..lol
Most of the reviews I've found so far, are bad! SEVERAL of em where " I had them start fouling out within 6 hours". After seeing a few of those that were basically all the same, I think I'll just be going with NGK's.
1996 GT, 5-speed, Moonlight Blue, Opal Gray leather, Flowmaster Cat-Back exhaust (Delta 40 series), BBK cold air intake & 75mm TBI, Super Chips programmer.
Originally Posted by 67mustang97 View Post
outlawfrog is probably right
Originally Posted by outlawfrog View Post
I might pull an "osirisguy", and make that my new sig quote!
outlawfrog is offline   Reply With Quote
Old 11-30-2009, 01:57 PM   #6
outlawfrog's Avatar
Oh, but I will add, their marketing hype does sound good!
Old 11-30-2009, 02:09 PM   #7
jimbullit's Avatar
`Just returned from the shop, and uninstalling the GMS coil packs. American Muscle said return some of them for exchange/ all for credit-whatever I wanted to do.. ! By the time I started ny car to drive into the shop-after the seriously rough running morning commute with no "check engine" light on-it was on now!
I reinstalled the OEM coil packs and reset the "check engine" light(unfasten the negative cable, touch the positive terminal with the negative cable clamp, wait a few minutes, reconnect-no light!)
Old 11-30-2009, 02:17 PM   #8
outlawfrog's Avatar
ummm Jim, do you have a hand-held tuner? If so, you know you can read/reset the codes with it? If not, you can go to the local parts store....most of em can read/clear codes for ya...as a complimentary service. Just the thought of doing the way you did, makes my brown-eye pucker! lol Guess that's from catching ringing current too many times on phone system intalls.
Old 11-30-2009, 10:40 PM   #9
gmantheman's Avatar
I have read mostly negative things regarding Granatelli coil packs. The general consensus is, unless your F/I, coil packs are a waste of money.
gmantheman is offline   Reply With Quote
Old 12-07-2009, 10:41 AM   #10
jimbullit's Avatar
yea... there's nothing like being the "guinea pig"-sometimes you just have to go against the grain and "live on the edge", a little bit
Old 12-09-2009, 12:02 PM   #11
05bluestang's Avatar
Everybody I talked to agrees, the best coils for our 3v's are OEMs.
I am having spark issues under boost with my car so I am going to install the Kenne Bell Boost-A-Spark module.
It's adjustable up th 60K volt by regulating the input voltage and a lot cheaper than coil packs. I'll let everybody know how it goes in a couple of weeks.
2005 Mustang GT, Pacesetter LT's with OR H-pipe, "Magna Pack" exhaust, Techco SC @ 9psi making 464whp & 449tq, steeda tri-ax shifter, 3D Carbon Eleanor Grill, Pioneer F90BT, FRPP 3.73 gears.
Get in, sit down, strap in, hold on, shut up!
05bluestang is offline   Reply With Quote
Old 01-13-2010, 04:52 PM   #12
V8Demon's Avatar
Send a message via AIM to V8Demon
This is the problem
Granatelli
It's not just the CP's either.
--05 Mustang GT-Low 12's-Whippled!
--87 Cougar 5.0 Trick Flow Heads & Intake-Ed Curtis Cam-Many other goodies-3100Lbs...Low 12's
V8Demon is offline   Reply With Quote
Old 12-13-2010, 02:46 PM   #13
Angry Re: Aftermarket Coil Packs
Yes I got a set of those for my 2006 GT and within 3 weeks one failed. After twisting the company for three days they sent one to replace it. Within another 3 months had a second went bad and now after another 6 months have a third. The company wash ther hands and out and out blaimed me for miss installation of them. How is that possible?
Any input on other OEMS like Accel?
radar123 is offline   Reply With Quote
Old 12-13-2010, 02:53 PM   #14
use OEM only dont mess around with other brands as its not needed
Coil on Plug Ignition Coil Pack Set (8) 99-04 Mustang W/ Wiring Harness Cobra GT Mustang Parts for Sale and Wanted 7 12-28-2008 09:59 PM
msd coil packs installed stovalini69 1996-2004 Mustang GT 0 08-04-2006 10:20 PM
side exit 'packs? 01mineralgrey6 1996-2004 Mustang GT 11 08-30-2005 03:19 PM
power packs Kyle Pre-2005 V6 Mustang 16 05-12-2005 12:17 PM
Glass packs whipster24 Pre-2005 V6 Mustang 11 10-09-2003 08:57 PM
11:38 PM
