Hi-flow cat question - Mustang Evolution
Old 12-13-2009, 05:15 PM   #1
This is for any of you S197 drivers who have replaced your H-pipe with a catted X. If this has been asked before, I apologize. If you are running a Magnaflow catted Tru-X, a Bassani catted X, a Pypes catted X or a SLP catted X, have any of you gotten a CEL caused by the rear O2 sensors? I know the CEL can be turned off by turning off the rear O2 sensors with a tuner, but I'd like to know if anyone who is running the stock tune who hasn't turned off the rear sensors actually tripped the CEL. Bassani actually comes out and says their system will cause a CEL, because modern high flow cats cannot yet match the OBDII characteristics of the factory cats. Any feedback will be appreciated. Reason for question: trying to decide between a splice-in X-pipe or a catted X that bolts to the factory headers.
MetallicMist is offline   Reply With Quote
Old 12-13-2009, 05:42 PM   #2
gmantheman's Avatar
Re: Hi-flow cat question
I don't have an X pipe with hi-flows, but I have a prochamber with hi-flows. My CEL has never came on because of the cats. I know my brooksspeed tune leaves the 02 sensor on. I am not sure about my bama tune. If the O2 sensor is off, I will have to ask Doug to turn it on. I would spend the extra money and get the X-pipe that bolts to the factory headers.
gmantheman is offline   Reply With Quote
Old 12-13-2009, 05:49 PM   #3
That's what I was thinking, too. I just hesitated when I read the blurb under Bassani's warranty page about aftermarket cats causing CELs. Do you know if the cats you got from MAC are metallic or ceramic substrate?
Old 12-13-2009, 05:54 PM   #4
gmantheman's Avatar
The cats are from magnaflow and they are metallic.
Old 12-14-2009, 11:54 AM   #5
05bluestang's Avatar
I have the Magaflow Tru-X highflow x pipe. I had it on the car when I did not have the supercharger with the O2's turned on and did not have a problem with a CEL. Now, because of the SC, my rear O2's are off....
BTW I have the magna packs with it and the car sounds awsome...........
2005 Mustang GT, Pacesetter LT's with OR H-pipe, "Magna Pack" exhaust, Techco SC @ 9psi making 464whp & 449tq, steeda tri-ax shifter, 3D Carbon Eleanor Grill, Pioneer F90BT, FRPP 3.73 gears.
Get in, sit down, strap in, hold on, shut up!
05bluestang is offline   Reply With Quote
Old 12-14-2009, 03:54 PM   #6
Thanks to both of you. I like the Tru-X as well as the Bassani catted X. Since I'm running the Magnapaks as well, I'll probably end up going with the Magnaflow X.
Old 12-14-2009, 04:35 PM   #7
07stang's Avatar
just do it big and have no cats haha
07gt. sct 93octane custom tune,bbk cold air intake,kooks LT headers,o/r x-pipe,borla stingers, ford racing 3.73 gears,19" tsw wheels,eibach sportline lowering springs, 12k hid headlights, clear turn signal lens, cdc upper and lower billet grille.
07stang is offline   Reply With Quote
Old 12-14-2009, 05:09 PM   #8
I'm no tree hugger, but I do try to obey the law. Besides, my car won't see the track; she's a street fighter. So, the cats will stay but they may be aftermarket ones.
Old 12-14-2009, 05:16 PM   #9
07stang's Avatar
you only live once haha. no cats sound so much better to me.
Old 12-14-2009, 05:51 PM   #10
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
+1^
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Old 12-14-2009, 08:57 PM   #11
gmantheman's Avatar
I don't about catted x vs o/r x with the magnapacks, but prochamber with hi-flow cats + magnapacks sound better than o/r prochamber + magnapacks. At least in my opinion.
Old 12-15-2009, 05:57 PM   #12
I'm sure it sounds good without cats, but I'm not going that route. What you do with your rides is your business. I'm getting a federal pension, so I'm not about to break federal law for the sake of a couple of HP and/or decibles. No offense to you all; that's just my choice. Thanks GMan; I'll give that some consideration.
Old 12-15-2009, 06:44 PM   #13
gmantheman's Avatar
Whatever midpipe you get, stick with the hi-flows. When I had an O/R prochamber I dynoed an avg of 301 hp/ 303tq. With the hi-flows it increased to 304 hp/311 tq.
Old 12-16-2009, 04:15 PM   #14
I'll keep that in mind. Thanks.
High Flow Cats StgRsh Pre-2005 V6 Mustang 3 10-14-2009 05:47 PM
Flow chart FTW n8r Pictures and Videos 9 03-01-2007 03:42 AM
EGR flow insufficent el cheapo Pre-2005 V6 Mustang 2 04-25-2004 11:04 AM
Cat Question Scott Pre-2005 V6 Mustang 10 12-24-2003 09:10 PM
Mac True-Fit Cat-back System with flow path mufflers McStang Pre-2005 V6 Mustang 6 09-04-2003 11:50 AM
07:07 AM
