BBK Throttle Body and Cold Air Kit - Mustang Evolution
Old 04-30-2006, 09:23 AM   #1
does anyone have experience with the bbk throttle body and cold air kit. articles say no computer refresh, but most other kits require this...tks...Ray
rbwheeler is offline   Reply With Quote
Old 05-01-2006, 11:33 AM   #2
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
Re: BBK Throttle Body and Cold Air Kit
im mechanically impaired so not sure what you mean but i have a 96 gt with bbk cold air and throttle body so maybe i could help but you will have to explain what you mean
1996stang is offline   Reply With Quote
Old 05-01-2006, 12:58 PM   #3
Old 05-01-2006, 01:00 PM   #4
I want to put the throttle body and CAI on an '06. When you install most CAI kits on '06, they require a computer refresh (load). Is this refresh required for BBK?
Old 05-01-2006, 01:17 PM   #5
I think you would be much better off with a tune (not just a chip) after such a thing. I would just save up and get it all at once to ensure it all goes right so when you have it tuned you will be good to go.
Old 05-01-2006, 03:46 PM   #6
bbunt302's Avatar
I believe there are indeed some CAI's for the 05+ GTs that do not require a tune (or flash, whatever you want to call it). However, you'd be much better off saving up and doing it both at once like Spector said. Because no matter what the manufacturer says... there is always a slight risk that your car is different and may indeed run lean. A popular combo seems to be the JLT CAI with a SCT chip from Bama Chips.
These new GTs are very touchy when it comes to intake mods.
Scary stuff.
Old 05-01-2006, 11:39 PM   #7
o sorry i dont know we didnt do anything like that to mine just installed and thats it sorry i couldnt help.
Old 05-02-2006, 08:05 AM   #8
im not even putting a cai on my car until I can tune it. And if im doing all that im going to wait until I do a pulley as well~
Old 05-02-2006, 09:10 AM   #9
Zim
You want to **** me?
Zim's Avatar
If it just requires a refresh, all that means is you unplug your battery for 30 minutes, plug it back in, and the computer relearns everything. They say to do that since you'll be moving more air with the CAI kit, so your computer compensates the fuel, etc. for that added air. Its not a big deal...
I like toys
Old 05-02-2006, 09:23 AM   #10
bbunt302's Avatar
I don't think that's what he is referring to though. I believe "flash" may have been the word he was looking for.
Scary stuff.
Old 05-02-2006, 09:38 AM   #11
Zim
Zim's Avatar
Why else would they require you to "flash" or "refresh" or whatever you call it with just a TB and CAI? Ive never heard of needing a chip for something that small. Of course I know absolutely nothing about the electronics in the 05+, but I wouldnt think something as simple as a couple bolt ons would need to be tuned...
I like toys
Old 05-02-2006, 11:47 AM   #12
bbunt302's Avatar
On the 05's, just about anything dealing with the intake system requires a tune. That's the main thing I don't like about them.
Hell, I changed just about everything on the '90 and never touched the computer. Not to say that it couldn't use a tune...
Scary stuff.
Old 05-02-2006, 01:59 PM   #13
thanks for all the input, wiil try an SCT or Diablosport tuner.....
Old 05-02-2006, 03:51 PM   #14
the best bet is to buy a hand held and get a REAL tune the can tunes they stick on those things blow chunks
Old 06-16-2006, 07:23 AM   #15
KKM
Simply flowing more air than stock will not require a flash or tune as the ECU will compensate for this, though any induction kit that has a larger MAF bore than stock will change the electronics output voltage signal of the MAF and then will require tuning on the dyno for that particular induction kit. Also of note, the tune for brand A will not work for brand B, though most systems requiring a tune usually have them available in the Diablo or SCT packages.
KKM is offline   Reply With Quote
Old 06-18-2006, 09:52 AM   #16
I put the BBK CAI on my 06 GT Mustang and it did NOT cause any problems nor cause any "check engine" lights. If the same MAF diameter and stock MAF electronics are used no "reflash" is required.
Without a tune the BBK gave my 6 RWHP...with a tune it went to 13 RWHP.
Sonic Blue GT is offline   Reply With Quote
Old 06-18-2006, 10:39 AM   #17
Danger Dude's Avatar
Please explain this!!! If this is the case they have put in the 05 a computer that is unable to adjust to simple changes in airflow.
That is a major suck *** thing to do and another reason not to like the new mustangs
Old 06-18-2006, 12:00 PM   #18
bbunt302's Avatar
Any slight change in the diameter of the air intake tube or MAF causes the MAF to no longer get an accurate read. If you try to install a CAI that is not specially designed to not require a tune (i.e. the JLT, Steeda, etc) without having it tuned properly... it'll run lean and probably go into "Limp Home" mode.
I personally would be weary of any product that claims to not require a tune (i.e. K&N, BBK)... Number one, because if it does not require a tune, chances are it is because it really doesn't flow much more than stock. You'll make more power with a higher flowing CAI and a proper tune. If you're gonna spend your money doing something, at least do it right. Number two, I do not trust manufacturers' claims. It may have worked just fine on the five or so cars they tested it on without a tune. That doesn't guarantee that it won't **** mine up to hell and back.
Simply put, if you put on a CAI and it ends up running too lean and ruining your motor, your warranty is not gonna cover it (unless you have a connection at the dealership or just a really cool dealer). You then will be up a creek (which will be decidely brown in color and won't really smell of roses) without out any sort of device to propel yourself against the current and up said creek.
Scary stuff.
Old 06-18-2006, 03:16 PM   #19
I never trust advertisers claims but the computer on 2004 and earlier would adjust for a lot of stuff including P&P intakes, CAI P&P and P&P T/B's. So for the EEC to not be able to make necessary small changes is limiting the computers abaility to make changes without a tuner. So they have been put into the pockets of the tuners for any little change needed to be made. More control
Old 06-19-2006, 02:25 PM   #20
03/04 cobras have been known to run dangerously lean with a cai/exhaust so thats why im not putting a cai on my car until I can get a tune as well.
Old 06-20-2006, 01:47 PM   #21
DarkShadow's Avatar
Send a message via AIM to DarkShadow
I've heard that for a long time the new GT's require a tune for CAI's. I thought it was common knowledge~
And like bbunt said, if it says it doesn't need one, it's probably not much better than your stock intake.
DarkShadow is offline   Reply With Quote
Old 06-20-2006, 06:47 PM   #22
There are a couple of CAI's that do not have a lean condition problem for 03/04's. Just stayaway from ones with bends in them.
BBK 65mm Throttle Body SonicBlueV6 Pre-2005 V6 Mustang 21 01-08-2010 08:11 AM
94-98 BBK 56mm Throttle body rydog Mustang Parts for Sale and Wanted 4 06-29-2007 09:05 AM
BBk Headers, and Throttle body... Fast93Coupe 1979-1995 Mustang GT 18 09-16-2006 12:25 AM
04:30 PM
