4.10 gears - Mustang Evolution
Old 03-23-2010, 08:16 PM   #1
b's stang's Avatar
4.10 gears
im about to put 4.10 gears in my 05 mustang gt. im wondering if i have to buy anything else to put them in. i need a quick response please!
b's stang is offline   Reply With Quote
Old 03-24-2010, 11:32 AM   #2
Loc: Austin,TX
Re: 4.10 gears
Should be fine depending on miles and wear.
Old 03-24-2010, 01:55 PM   #3
upton7's Avatar
Re: 4.10 gears
get the rebuild kit from american muscle
Old 03-24-2010, 07:12 PM   #4
big show 98's Avatar
Re: 4.10 gears
Do you have a tuner? If not you will need one for the speedo to be correct & to shift correctly if it is an auto.
big show 98 is offline   Reply With Quote
Old 03-24-2010, 07:38 PM   #5
Re: 4.10 gears
Yah depending on the mileage I'd look into a rebuild kit as Upton said. Always a good thing to have.
Gear oil is also necessary when installing gears.
2005-2009 Ford Mustang Gears at AmericanMuscle.com - Free Shipping!
Old 03-24-2010, 07:59 PM   #6
Loc: Austin,TX
Re: 4.10 gears
I would get with your shop and see if they recommend a bearing kit. I had 36k on my 07 when I did 4.10's and didn't use the bearing kit,no whine what so ever and runs like a top with no issues.
Old 04-01-2010, 11:35 AM   #7
jimbullit's Avatar
Re: 4.10 gears
DDTCM: what kind of fuel economy have you observed-since the gear(s) install?
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 04-02-2010, 08:18 AM   #8
Loc: Austin,TX
Re: 4.10 gears
To be honest......I really don't pay attention to it because I only drive her maybe 2 days out of the week and don't really just cruise her around. So I put in 20 bones worth of 93 and it will last me for 3 weeks sometimes. I have glaced at it on occasion and seen it range from 17 thru 22 on the average. Sorry I couldn't be much help on that.
Old 04-02-2010, 09:44 AM   #9
Re: 4.10 gears
going from 3.31 to 4.10 expect 2 mpg loss on the highway and a gain of maybe 1 mpg or break even in the city. You may lose a bit more on the highway but probably around 2mpg.
Old 04-02-2010, 12:43 PM   #10
Loc: Austin,TX
Re: 4.10 gears
Which isn't much at all.
Old 04-20-2010, 01:47 PM   #11
jimbullit's Avatar
Re: 4.10 gears
I thought my `08 has the 3:55 to 1 axle ratio
Old 04-20-2010, 04:54 PM   #12
Loc: Austin,TX
Re: 4.10 gears
You actually have the 3.73's in the 08 Bullitt
http://www.musclecardrive.com/specs/...ng-bullitt.php
Old 05-17-2010, 08:08 AM   #13
b's stang's Avatar
Re: 4.10 gears
finally had my 4.10's installed just waiting to get the car retuned to really tell the difference. it has whine. it sounds like an airplane when its taking off. does that go away?
Old 05-17-2010, 10:14 AM   #14
Re: 4.10 gears
If they are used gears they may very well whine. If not used gears then the whine is due to an in correct installation. They may say it will go away, Ive never seen it go away. I wouldnt drive it whining if they wish to take a go at it and redo it... once the pattern is worn its to late.
A friend just had some gears put in his GT and it whined (would do it on decel) and he had to buy new gears. I hope the shop you let install them warrantys whine, as its NOT right if it whines with new gears... that means they dont know what they are doing at least to me.... as gears are not just a bolt in and go kind of thing.
A VERY slight whine might be acceptable, especially if you have lower control arms and such that dont have rubber bushings (transfers sound better with stiffer bushings) but any more than a very very faint whine I would do my best to make them take care of it.
Some say Motive gears (now making Ford Racing gears) and Richmond are known to whine due to their make up~ but generally OEM ford racing that are not made by motive are good.
Old 05-17-2010, 11:22 AM   #15
Loc: Austin,TX
Re: 4.10 gears
Take it back for sure and see what can be done. I would ask them who test drove the car after the install and if they noticed the whine why would they send it out knowing there was a install issue.
Old 05-17-2010, 01:02 PM   #16
b's stang's Avatar
Re: 4.10 gears
they are motive gears. and the shop double checked and did everything right. i just heard that motives whine alot
Old 05-23-2010, 06:04 PM   #17
The Darkside's Avatar
Re: 4.10 gears
Yes i was also told by my mechanic that motive gears whine alot. as they wear in they will stop whining. mine whined in the start as well. good luck. i do hope he did the install right. i have a feeling all is well and its just the normal whine of motive.
question- why didnt you go ford racing gears?? i didnt have a choice because i got a v6.
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 05-23-2010, 06:09 PM   #18
b's stang's Avatar
Re: 4.10 gears
you know i really don't know. i just wanted to go with the motives. the gears regardless are badass. loss of gas milage, but you get out of the hole much better and quicker and quicker acceleration
Old 05-23-2010, 09:31 PM   #19
tigercrazy718's Avatar
Re: 4.10 gears
i think theres more gears for the v6
u couldve done US Gear but its kinda too late now i guess lol
2008 V6
204 RWHP
If you wreck and kill yourself trying to jerk off on the way to her house I will put it all over the internet.
tigercrazy718 is offline   Reply With Quote
Old 05-24-2010, 09:45 AM   #20
oldtexasdog's Avatar
Re: 4.10 gears
Anyone know what the backlash settings would be on a set of 410 to replace my 331? Also will the rear drop enough so that the pinion can be acessed without taking the axel out?
oldtexasdog is offline   Reply With Quote
Old 05-24-2010, 03:12 PM   #21
b's stang's Avatar
Re: 4.10 gears
my mechanic had to take the whole axel off. and doing the gear swap is worth it.
Old 05-26-2010, 12:04 PM   #22
05bluestang's Avatar
Re: 4.10 gears
The gears can be done with the axle in the car (done it 3 times). DO NOT GET ANYTHING OTHER THAN THE FRPP "A" GEARS, everything else will whine, trust me, I learned the hard way..........................................
2005 Mustang GT, Pacesetter LT's with OR H-pipe, "Magna Pack" exhaust, Techco SC @ 9psi making 464whp & 449tq, steeda tri-ax shifter, 3D Carbon Eleanor Grill, Pioneer F90BT, FRPP 3.73 gears.
Get in, sit down, strap in, hold on, shut up!
05bluestang is offline   Reply With Quote
Old 05-27-2010, 05:55 AM   #23
Re: 4.10 gears
Thanks for the info. I get the FRPP but what is "A"? ALSO is Pinion depth critical with new OEM Ford Racing Gears?
Old 05-27-2010, 09:10 AM   #24
Re: 4.10 gears
The "A" gears are made by FRPP the "B" gears are sold as FRPP but are made my Motive and had issues and that's why Ford does not use them anymore but there are still set of them out there. Yes pinion dept is critical...........
Old 06-27-2010, 11:56 AM   #25
Re: 4.10 gears
Are the FRPP gears offerd by Amercian Muscle A or are they made by Motive?
Old 08-21-2010, 06:03 AM   #26
Wolfsbain76's Avatar
Re: 4.10 gears
Some good info here, and even though there is some talk about loss of mpg, can someone tell me about the effect on the engine? My car is a daily driver, and I heard that putting in 4:10's will wear out my engine faster. Heard that the engine will work harder and the speed of the vehicle will not be as fast on the Hwy, but engine will be racing. I would like to put in the 4:10's though.
Wolfsbain76 is offline   Reply With Quote
Old 08-21-2010, 10:20 PM   #27
Re: 4.10 gears
On my 08 GT I am getting about 15 MPG now. As far as wear and tear the engine realy works less to get up to speed. 2000 at 60MPH. If I had it to do all over again though I would have gone with the 3:73. For the GT I think this would be a better mix. Mine is a daily driver also.
Old 08-26-2010, 04:36 AM   #28
Re: 4.10 gears
Interesting, I'll take a look into the 3:73. Thanks for the opinion! So how are you liking the gear upgrade?
Old 08-26-2010, 07:59 AM   #29
Re: 4.10 gears
It does put a smile on your face when you get the shifts just right
Old 09-01-2010, 09:29 AM   #30
Re: 4.10 gears
Don't fear the gear. I have 3:73's and a blower which my tuner told me was just right, now I wish I had put the 4:10's in. I guess you can never have too much acceleration . Trust me, after a while you want moaaaaahhhhhhh
Old 09-04-2010, 04:44 AM   #31
Re: 4.10 gears
hahaha....Thanks, I won't fear the gear then! Let me ask you guys then, since the gears will help you accelarate quicker, will you still have the power to pass someone if you have to while crusing at a moderate 80mph? I think I'll go with the 4:10's. If I'm going to change gears, might as well do it up!
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
3.73 gears tim11 Pre-2005 V6 Mustang 5 10-25-2005 08:21 AM
4.10 gears powerhungry966 Pre-2005 V6 Mustang 7 10-23-2005 06:53 PM
gears 8.8 or 7.5 strike1980 Pre-2005 V6 Mustang 5 07-31-2005 11:05 PM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
10:01 AM
