spark plugs - Mustang Evolution
Old 04-17-2010, 06:08 AM   #1
Perry Wyatt's Avatar
spark plugs
looking for information about the "one piece" plug that is the upgrade from the two piece plugs ?
Perry Wyatt is offline   Reply With Quote
Old 04-17-2010, 10:31 PM   #2
Re: spark plugs
Apparently 08-09 models used a newly implemented cylinder head with one piece spark plugs that don't break off upon removal. About all I know about it.
Old 04-17-2010, 10:42 PM   #3
Re: spark plugs
Here's a link to the Service Procedure to removing the 2 piece plugs, not sure if you need it.
spark plug change - Mustang Forums at StangNet
I'm guessing you could just upgrade to a motorcraft or autolite 1 piece if you owned an 05-07.
Old 04-17-2010, 10:44 PM   #4
upton7's Avatar
Re: spark plugs
I think i remember him saying he has an 05 in another post might be someone else though.
Old 04-17-2010, 10:48 PM   #5
Re: spark plugs
Yes, mine is an 05. I believe it has the two piece plug. I can't upgrade to the one piece then ?
Old 04-17-2010, 10:54 PM   #6
Re: spark plugs
Don't quote me on it, but I'd say that you could get one pieces for your 05 now. I think companies like motorcraft designed a 1 piece to fit the 05-07 3v's back in 07 or 08. You may want to check into it with your dealership, or maybe one of the 05-07 GT members will chime in.
Old 04-17-2010, 10:57 PM   #7
Re: spark plugs
If I can upgrade to a one piece plug, does Motorcraft or Autolite make one ?
Old 04-17-2010, 11:05 PM   #8
upton7's Avatar
Re: spark plugs
Yes most likely.
Old 04-17-2010, 11:06 PM   #9
Re: spark plugs
The autolites are a 2 piece similar to the stock ones so you won't want them.
Champion #7989's are a 1 piece design, double platinum.
Have heard a few good things about them being used in the 05-07 GT's.
Old 04-19-2010, 08:35 AM   #10
Re: spark plugs
My friend changes his and I am pretty sure he went with an autolite plug as it was one piece.
Old 04-19-2010, 12:52 PM   #11
Re: spark plugs
Does anyone know what the Autolite or Motorcraft number would be for the one piece ?
Old 04-19-2010, 08:31 PM   #12
05bluestang's Avatar
Re: spark plugs
They ones you are looking for are made by Brisk Racing, they are one piece dsign for the 05 -07 GT's
Brisk Racing :: Search results
2005 Mustang GT, Pacesetter LT's with OR H-pipe, "Magna Pack" exhaust, Techco SC @ 9psi making 464whp & 449tq, steeda tri-ax shifter, 3D Carbon Eleanor Grill, Pioneer F90BT, FRPP 3.73 gears.
Get in, sit down, strap in, hold on, shut up!
05bluestang is offline   Reply With Quote
Spark plugs upton7 General Mustang Discussion 15 02-02-2010 03:00 PM
what spark plugs do i need fastfanatic 1996-2004 Mustang GT 6 09-14-2009 09:23 PM
Which spark plugs should I use??? koch_A_tyler 1996-2004 Mustang GT 5 03-18-2008 07:36 AM
Spark Plugs megax29 Pre-2005 V6 Mustang 20 10-09-2006 06:36 PM
Spark Plugs megax29 Pre-2005 V6 Mustang 13 03-25-2006 08:51 AM
05:12 AM
