has anyone heard what a 05-09 v6 sounds like with no crossover pipe? i cant find any on youtube so if anyone has some personal experience that would be great. im asking bc with no cats i know that the 4.0 sounds ricey, so i feel like no crossover would make it move more towards that area of sound
it shouldn't really change the sound as its not needed on a 4.0 at all since its an even fire motor I do believe (but double check that) I put an H on my 3.8L v6 and it made no difference in sound.
what I mean by H vs no H is just the balancer pipe. Basically one pipe on each side all the way out to the back no connecting of pipes. The little connector balancer pipe is what I was talking about. The X pipe will make it more raspy by its design~ you may get a slightly deeper tone with an X vs no balancer pipe~ most after market kits are probably H pipes vs no balancer pipe.
well the balancer pipe is the pipe the goes from one side to the other in an H pipe its why they call it an H pipe, the connection between the two sides is the H part.
i say go o/r h. a v6 is a v6 so it wont vary that much from years. i definately wouldnt go x. ive heard straight pipes also sounds pretty good on your car, so that would just be with no crossover. they will all sound like crap in the upper rpm's, however my exhaust sounds really deep and 'gt like' in the lower portion. if u want i can show you how mine sounds in the upper rpm's so you can get an idea.
also, if you plan on going catted, you should probably just skip it. even with two hi-flow cats, it still wont make that much of a difference.
yea yalls def sound way better than the 4.0's
if i put long tubes on my car with no cats it sounds like such a pile
but ive heard tigerfan's and it sounds bad ass
same with ryanquick6
dont forget youll have to modify your catback for the mid-pipe to work. it'd probably be easier to just do straight pipes from the headers to your existing mufflers. and cheaper. and i dont see how the 4.0 sounds that much worse than the 3.8. i understand it has sohc and all that.
yea it was actually cheaper for me to sell my catback and start over when i did the long tubes and mid pipe. actually sold them to that fugly white mustang a few spots over. im assuming youre catback is welded and that it has a y conversion of some sorts. so it has one pipe connected to the y-pipe and then splits into two before the mufflers. if it is clamped on, it would probably be an easy fix. so im not sure exactly how its setup. in any rate, you would also have to get some new piping called flow tubes that go off the h-pipe to the mufflers and i believe those have to be welded to the muflers. they cost like $50 or so.
good luck in whatever you choose and id like to hear it once its done.
yea i think its clamped and its the set up u described
havent really looked into prices yet i think its way more down the line thing
getting rims this sumemr and then with any left over money im gonna get suspension set up for autox
black shelby 2010s
the ones on american muscles website
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
