new clutch for supercharger - Mustang Evolution
Old 05-31-2010, 01:21 PM   #1
I am saving up to buy the Steeda carb legal supercharger and was wondering if I need to buy a new clutch for it as well. The car only has 500 miles on it and I have babied it since I bought it 2 weeks ago, so the clutch is still in perfect condition. If I should be buying a new clutch, what are some recommended ones. Thanks in advance for any input.
Cheers
Kenny
SickGT is offline   Reply With Quote
Old 05-31-2010, 04:43 PM   #2
hottcobra's Avatar
Re: new clutch for supercharger
If you just want to do the clutch now you can, but the factory clutch will hold for awhile. I say there is "Spec" and then there is everyone else. Do the stage 3+ now that way you have the best and never have to upgrade later. Also got the flywheel with the replaceable friction plate. That way you can just change the plate later and not the whole flywheel.
Old 05-31-2010, 06:15 PM   #3
Thanks for the reply. Will definitely look into this.
Old 06-01-2010, 10:06 AM   #4
Any links?
Old 06-01-2010, 10:47 AM   #5
dont buy a king cobra clutch, they dont hold very much hp/tq
Old 06-01-2010, 12:15 PM   #6
Originally Posted by SickGT View Post
Any links?
Found it.
Old 06-01-2010, 12:17 PM   #7
Will definitely keep that in mind, thanks.
Old 06-01-2010, 02:00 PM   #8
hottcobra's Avatar
I know a member of this site that is on his third king cobra clutch and is N/A.
Old 06-01-2010, 05:56 PM   #9
jimbullit's Avatar
Spec +1
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 06-02-2010, 05:51 PM   #10
05bluestang's Avatar
Depending on now much HP you plan to make I would recommend the McLeod RST or SXT. I currently have a spec stage 3+ with spec aluminum flywheel and am regretting not getting the McLeod. The spec is a great clutch to hold the HP (I'm making 465 at the wheels) but it is not very smooth when it engages and when you try to slip it you have to find just the right (sweet) spot or it chatters like crazy. Everybody I talked to told me the McLeod is really smooth.
HTH
my0.02c
2005 Mustang GT, Pacesetter LT's with OR H-pipe, "Magna Pack" exhaust, Techco SC @ 9psi making 464whp & 449tq, steeda tri-ax shifter, 3D Carbon Eleanor Grill, Pioneer F90BT, FRPP 3.73 gears.
Get in, sit down, strap in, hold on, shut up!
05bluestang is offline   Reply With Quote
Old 06-03-2010, 10:16 PM   #11
HTH
my0.02c
Looking to make around 430hp. Mcleod, huh...will have to look into them. I had clutch chatter on my 04 srt-4. Took some getting use to, but I can agree with you...it did get annoying after a while.
Cheers
Kenny
Old 06-04-2010, 08:15 AM   #12
So I've taken a look at Mcleod's website. Just not sure which clutch kit would be good to get for the hp I am looking to make.
Old 06-04-2010, 12:55 PM   #13
This one, it's good to 800HP
McLeod Industries 6911-03C - McLeod RST Street Twin Clutch Kits - Overview - SummitRacing.com
Old 06-04-2010, 12:56 PM   #14
Originally Posted by jimbullit View Post
Spec +1
Spec 1+ wouldn't work with over 400HP, Spec 3+ minimum............................
need a clutch and... DarkShadows 1996-2004 Mustang GT 12 01-02-2009 11:54 AM
clutch? roach 1996-2004 Mustang GT 5 03-23-2007 01:58 PM
Clutch cms09071987 Pre-2005 V6 Mustang 5 05-22-2005 10:18 PM
Clutch cms09071987 Pre-2005 V6 Mustang 6 05-22-2005 09:36 AM
Using a used clutch? Tbird232ci Pre-2005 V6 Mustang 2 01-16-2004 07:24 PM
08:09 AM
