Dyno results after bolt-ons - 07 GT - Mustang Evolution
Old 02-13-2007, 02:49 PM   #1
For those of you still in the bolt-on stage like me...I had my 07GT dyno tuned today. Bolt-ons so far include Corsa x-pipe and Corsa mufflers and Roush cold air intake (with the narrowed-tube insert removed). Dyno results after custom tune were 300 rwhp and 321 lb/ft torque.
Tune was done at PSI motorsports in Webster, TX (south of Houston). They saved the tune settings to my SCT Xcal flash tuner and to his computer...so if any of you in the Houston area are looking at buying a tune for an 07 GT he has it. FYI, car was still running lean on the SCT Xcal 93 octane tune.
07GT is offline   Reply With Quote
Old 02-16-2007, 03:27 PM   #2
bullitt482's Avatar
Re: Dyno results after bolt-ons - 07 GT
Why would you want a tune from someone who lets the mixture run lean?
01 Bullitt
Old 02-16-2007, 03:59 PM   #3
if he cant get a near stock car to not run lean im not sure I want him touching my car
Old 02-16-2007, 04:02 PM   #4
bullitt482's Avatar
Poor advertising FTMFW
01 Bullitt
Old 02-16-2007, 04:19 PM   #5
MonteCitan's Avatar
PRETTY sure he meant the tune that came with the xcal 2 still had his car running lean, but it was fixed by his dyno tune
Nice #s man.. I'm barely beating you in HP/TQ with a full engine swap.. I'm still basically on factory heads though, so its all good
was this on a loaded dyno/mustang dyno ? or a typical dynojet?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 02-16-2007, 04:59 PM   #6
bullitt482's Avatar
Sounds like dynojets to me. From what I've seen, the mustangdynos show about 199 to 215 ish at the wheels for an 05 GT 5 spd.
01 Bullitt
Old 02-17-2007, 07:17 AM   #7
OK, whatever. I don't care about the "number"... on the dyno they used for my car it was reading 267 before any boltons and now it reads 300. By your reports the engines in 05+ GTs are losing 33% of crank horsepower before turning wheels. That doesn't sound right.
Old 02-17-2007, 07:23 AM   #8
He didn't "let it run lean". The SCT tune had it running lean and he re-tuned it and saved the new parameters so could use on other 07s. Sorry about the confusion. Car runs a lot better since he re-tuned it.
FYI again: I optioned for the 3.55 gears on 07 but Ford uses same ECM for all 07 GTs which is programmed for 3.37 gears so when they entered gear ratio of 3.55 into computer for SCT tune and I downloaded to car, the car wouldn't start....that was a pain in the *** to figure out!!
Old 02-17-2007, 09:08 AM   #9
bbunt302's Avatar
You can't be serious. They dyno around 260-270 man. Do some research. 300 rwhp is pretty common with a 93 octane tune, CAI, and full exhaust with long tubes.
Scary stuff.
Old 03-07-2007, 11:03 AM   #10
silverstangboy's Avatar
I was just wondering how you would lose nearly 90 hp through the drive train of a car that only makes 300 brake
maybe if you ran it without any oil in the tranny.
93 mustang notch
~450hp 331 stroker - Sold
Old 03-07-2007, 11:06 AM   #11
Well, he did state on a mustang dyno...which will read lower than a dynojet so the loss would appear greater...90 still seems like a stretch, but, a MD will read lower than a DJ everyday of the week.
Old 04-07-2007, 04:26 PM   #12
mike05gt's Avatar
My 05 dynoed at 271 on Dyno-jet with just axel back mod.
With JLT and sct tune on Mustang Dyno 326 rwhp, 325 tq
mike05gt is offline   Reply With Quote
Old 04-08-2007, 11:56 AM   #13
DarkShadow's Avatar
Send a message via AIM to DarkShadow
From what I have read and heard about Mustang dynos, there are a lot more controlable parameters that can pretty much let the operator "fabricate" a number if they want to. But who knows...
DarkShadow is offline   Reply With Quote
Old 04-08-2007, 03:55 PM   #14
1LOBOSS's Avatar
199-215 hp-that's funny or try this get real. That would mean the EDGE ponys run 154-175hp or the Bullits at 159-180. Hehehehe
1LOBOSS is offline   Reply With Quote
Old 04-08-2007, 10:23 PM   #15
bullitt482's Avatar
That's funny because I'm presently looking at an issue of 5.0 and Fast Fords reading where a STOCK 05 GT dyno'd 199 at the wheels. It was on a Mustang Dyno. Yes the Mustang Dyno has more real world paramaters and can be fooled with more to cheat people who aren't paying attention.
I don't know why you all are taking so much offense toward this info about dyno numbers on a mustang dyno. "Nuh uh, my car dyno's way more that that." Oh yeah, go run it at the track and run that 13.0 ET that you "dyno slip" says it will. Guess what, you numbers will just be a hair quicker than stock if you tuner says your car has 320 ish hp on a mustang dyno. The mustang dyno in Tupelo has guys dynoing less than 350 hp and guess what they run in the 1/4...... Low 11's. Dyno's ARE TUNING APARATUS'S PEOPLE!!!! If you go to a dyno just for numbers--that is looking for high numbers no matter what opposed to getting higher numbers in relation to what the car was stock--then you have a lot to learn about in the automotive and performance world.
01 Bullitt
Old 04-08-2007, 10:25 PM   #16
bullitt482's Avatar
And they do..... Numbers are numbers. The only ones that matter to me are E.T.'s and Trap Speed.
01 Bullitt
Old 04-09-2007, 06:19 AM   #17
bbunt302's Avatar
You are looking at a load of bull****.
If anyone believes that a 300 (and slightly underrated) car dynos at 199 rwhp, they are out their goddamn head. I don't care if it's on a cheese wheel dyno. A dyno is a measuring device. Sure, some of them will be slightly different. The Mustang Dynos actually simulate a load being on the car while the Dynojets do not. However, that is not going to cause a 70 rwhp loss.
I'd take that magazine and throw it in the trash.
And yes a 350 rwhp car can very easily run low 11s. I don't see what the big deal is there. I've seen 300 rwhp cars break into the high 11s. It's all about weight and traction.
The fact is, a dyno is a much better measure of actual power output than a track. A track measures power, weight, and traction. A dyno measures power, and that's it.
Scary stuff.
4.2 bolt ons 3.8boii General Mustang Discussion 1 06-12-2010 09:22 PM
Should I do all the bolt ons? upton7 1996-2004 Mustang GT 7 05-21-2009 12:33 PM
Bolt ons? 98GreenStallion The Bar 2 01-24-2004 07:36 PM
first bolt ons? Falcon Pre-2005 V6 Mustang 11 11-15-2003 12:32 PM
all the bolt ons dark Pre-2005 V6 Mustang 12 07-31-2003 04:38 PM
04:32 AM
