Just learned..... - Mustang Evolution
Old 04-19-2007, 05:52 PM   #1
bullitt482's Avatar
Just learned.....
....if you pop a head gasket on a 3V mustang, you have to pull the dam motor just to take the heads off....... Imagine the labor costs later on. Ford, WTF? I pulled the head off the 302 a couple weeks ago with room to spare....
01 Bullitt
Old 04-19-2007, 05:59 PM   #2
MonteCitan's Avatar
Re: Just learned.....
It takes what, 3 hours to pull a motor in a mustang?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 04-19-2007, 08:05 PM   #3
The question is...who has the equipment necessary to pull an engine?
That's where the costs will come in.
Old 04-19-2007, 10:53 PM   #4
matthews.stang's Avatar
*raises hand*
All you need is an engine hoist and find/make a plate to lift the engine out.
matthews.stang is offline   Reply With Quote
Old 04-20-2007, 07:00 AM   #5
due to room???? they can take my heads off without issue, and I thought the 05s had a bigger engine bay hmmm
Old 04-20-2007, 08:42 AM   #6
I am now intrigued...I will have to check out the engine bay of an 05+ and see if is true now.
Old 04-20-2007, 09:49 AM   #7
MonteCitan's Avatar
It may have more to do with the front cover than the head itself...
Old 04-20-2007, 09:51 AM   #8
Very possible...which is why I am intrigued. If that is the case...it will just boost my thought of why 99-04 > 05+ .
Old 04-20-2007, 11:50 AM   #9
Originally Posted by matthews.stang View Post
*raises hand*
I'm the same way you are, I have access to any tools/machines I may need. But not everyone is in the same boat.
Old 04-20-2007, 04:29 PM   #10
bullitt482's Avatar
This is according to the latest issue of 5.0 and Super Fords. They did some cams and some headwork on an 05 GT.
01 Bullitt
Old 04-20-2007, 04:33 PM   #11
bbunt302's Avatar
I was under the impression that the 05+ actually had a larger engine bay than the 99-04. Either way, if I'm working on the heads of a 4.6, I'd rather pull the engine anyway.
Scary stuff.
Old 05-02-2007, 04:26 PM   #12
hottcobra's Avatar
i have a 06 GT and i dont see any reason why you cant pull the heads with the engine in the car you just have to tear down thw whole front of the motor to get the cover off and you have to do that even if its on the stand (the impossible is only under founded)
Old 05-02-2007, 04:36 PM   #13
bullitt482's Avatar
But have you done it? Not saying I have, but I just keep hearing that you would have to pull the motor.
01 Bullitt
Old 05-02-2007, 06:24 PM   #14
hottcobra's Avatar
no I havn't but the biggest clearence issue i see is the firewall & the cure for that is to lower the engine cradle i few inches.
pinochio learned his lesson... STEVE The Bar 7 09-28-2004 03:16 PM
Share what you have learned from showing your car: Rick0636 Mustang Audio & Video 31 07-03-2004 08:03 PM
so I learned something new Warfire80 The Bar 2 03-09-2004 02:55 PM
Everything I learned from FATF Rellik The Bar 15 10-07-2003 10:36 AM
I guess I havn't learned my lesson yet .:DarkEntity:. The Bar 8 09-19-2003 02:58 PM
10:56 PM
