Control Arms - Mustang Evolution
Old 06-12-2007, 10:41 AM   #1
Y2E0L0L5OGWT's Avatar
Control Arms
What upper and lower control arms would yall suggest?
Steeda has a "stop the hop pak" (i.e. wheel hop which the 197 suffer badly from) as they call it and it includes chome moly steel tubular upper and lowers...but I was really leaning toward billet lowers and an adjestable upper arm which steeda also has. other brands have similar setups either tubular steel or billet...What would yall suggest? Keep in mind I am going to be running FI before long so I will need a pretty stout rearend...
Old 06-12-2007, 11:14 AM   #2
Re: Control Arms
I would look at maximummotorsports.com they are extremly good. I remember reading about them testing LCA/UCA's on the 05+ and said so far they have not been enough of an improvment to make them to sell. I would ask them to see what they have to say about it.
Old 06-12-2007, 04:19 PM   #3
bullitt482's Avatar
Re: Control Arms
NOOOOOO STEEEDA.. Just the shifters is all I would EVER get from them... My .02.
I would recommend said Maximum Motorsports, but also consider the UPR's. Some of the fastest stangs in the country use their stuff(NMRA) and last years winner of DR class from Tupelo uses them as well. Also, since you are keeping it a street car, go with poly bushings. It's going to be a tad rougher than stock, but they will definately be better than riding around on solids.
And if you are talking about beefing up the rear end, I'd definately look into eaton's posi and some matching 31 or 33 spline axles from Moser. You will definately need those come torque time.
01 Bullitt
Old 06-12-2007, 05:03 PM   #4
Re: Control Arms
I don't really care for UPR's stuff all that much, i never really have, no particular reason why, just a preference...
and for upgrading/"beefing up" the rearend, i won't really need upgrade axles or performace LSD for what I plan to do with it...My intentions are to make it into a weekend driver that I run to the drag strip with a few times a year...leave it mostly stock on the outside, run a blower at about 10 or so psi with full exhaust (LT's, x-pipe and c/b) and some 295 street tires in the back...I am looking at making about 450hp/410ft-lbs at the wheels...so the stock rear end would hold up just fine as it sits for a couple years maybe...so i was looking to go with a few rearend upgradaes, UCA, LCA's, Girdle Support, maybe some other small things, in order to make the rearend last longer, but I am not looking to make the kind of power or use slicks to warrant swapping out axles and all that good stuff...
Old 06-12-2007, 05:47 PM   #5
bullitt482's Avatar
Re: Control Arms
You know I used to say the same thing. Brad and I had a discussion about it, then I started seeing their stuff on REALLY fast(as in coming out of the hole/60' times) cars still running a stock style 4 link.
I totally see where you are coming from though. I feel the same way about MAC and Holley. Some of their products are ok/super, but just not my cup of tea.
Another recommendation is **********************THE BEST Upper Control Arm Kit on the market**********************. I know the link says otherwise but the site is baselinesuspensions.com and their stuff is REALLY nice and people have cut AMAZING 60' times with even 18 inch drag radials.
01 Bullitt
Old 06-20-2007, 10:57 PM   #6
Re: Control Arms
I,m currently in the process of making the baddest control arms on the market. No bull**** parts just the best on the market, double adjustable, chromemoly air craft ends, chromemoly center tube, i,m tried of seeing people getting hammered by these companys, I figured $200 a pair would be fair.
flying5 is offline   Reply With Quote
Adjustable Lower Control Arms matthews.stang Pre-2005 V6 Mustang 6 07-10-2007 06:17 PM
affordable control arms flying5 2005-2010 Mustang GT 10 06-27-2007 12:26 AM
which lower control arms to get? mild2002gt 1996-2004 Mustang GT 11 01-17-2005 12:54 AM
Installing Upper Control Arms Rellik Pre-2005 V6 Mustang 8 09-22-2003 07:20 PM
Lower control arms Rick0636 Pre-2005 V6 Mustang 10 07-15-2003 04:43 PM
08:15 PM
