Anyone have 06 gt with pro charger and 4.10 gears? - Mustang Evolution
Old 06-21-2007, 05:04 PM   #1
dads2006gt's Avatar
Send a message via Yahoo to dads2006gt
I need info on this blower ( ps1) with the 4.10 gear or 3.73's. How much different on the highway? Mileage? Does anyone have first hand knowledge with this setup? Thanks for your help.
dads2006gt is offline   Reply With Quote
Old 06-21-2007, 08:56 PM   #2
bluemustang's Avatar
Re: Anyone have 06 gt with pro charger and 4.10 gears?
if your worrying about mileage with a supercharger then obviously it isnt for you
BTW Dont Fear The Gear
Old 06-21-2007, 10:41 PM   #3
bullitt482's Avatar
a huge PLUS ONE!!
01 Bullitt
Old 06-22-2007, 08:42 AM   #4
rydog's Avatar
Send a message via MSN to rydog
centrifugal superchargers like RPM's so the quicker you get the RPM's up the quicker you get the power
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 06-22-2007, 10:15 AM   #5
dads2006gt's Avatar
I want to know details on this system, how the motor holds up,does it need a new fuel pump, ect. This is an investment so I am trying to get good info to make sure I get the best bang for the buck and its a daily driver so every little detail counts in my decision to do this. Thanks for your comment's ...please keep them coming.
Old 06-22-2007, 10:45 AM   #6
Herbstang's Avatar
Here's a little info you may or may not have seen ProCharger Intercooled 2005-06 3V Mustang Systems
Here's a clip
Procharger 05-07 GT P-1SC Supercharger w/Intercooler TUNER KIT [PC-1FP202-SCI] - $4,968.51
I may be wrong but I believe if you got a Roush S/C you won't blow the factory warrenty
Old 06-22-2007, 10:46 AM   #7
rydog's Avatar
Yes you will probably need a new fuel pump and injectors and a good dyno tune when you are done with a hand held tuner or a chip.
Old 06-22-2007, 10:56 AM   #8
dads2006gt's Avatar
Information is my concern. This is an investment so I want any details I can get and the people on this forum are a pretty good source .
Old 06-22-2007, 11:02 AM   #9
dads2006gt's Avatar
thanks !!!
Old 06-22-2007, 03:21 PM   #10
Anytime you add a super/turbo charger, you have a whole list of supporting mods such as injectors, fuel pump, plugs, inter/aftercoolers, good and I emphasize good dyno tune.
Just remember, part of adding more power is breaking more parts.
Old 06-25-2007, 11:38 AM   #11
Herbstang's Avatar
And don't forget the suspension upgrades to handle the S/C power
Old 06-25-2007, 12:25 PM   #12
Y2E0L0L5OGWT's Avatar
+1...if you are planning to do any kind of "hard" driving on your s/c-ed S197, you will need to beef up the lower control arms, upper 3rd link, panhard bar and a rearend girdle support would help....the stock rearend will last for a little while with the extra power, but if you have any intentions of going to a drag radial or anything with a lot of grip, you will wear out the stock rearend in no time...
Also, your MPG, wear on the motor, etc. will depend on how much boost you intend to run and how much power you are looking to get out of the system...What type of hp/tq numbers are you looking for?
I am putting a Whipple 2.3L s/c on mine in the next few months and will be running 10 psi of boost and making in and around 450 rwhp, which is a good safe number for the 3V stock motor...going much higher than that would probably blow the motor before long...and again, where ever you get the s/c from, make sure that above all else you take it somewhere to have it tuned by someone who knows exactly what they are doing...even if you're only running a small amount of boost, a bad tune equals blown engine which is VERY bad...so the proper tuning is everything...
Old 06-25-2007, 02:36 PM   #13
dads2006gt's Avatar
I will be running no more than 10lbs of boost which should put me somewhere in the 440 to 460 rwhp range. I know the tune is the most important part and I am still trying to figure out who I am going to use to tune it . I am new to this state (Michigan) and I have talked to a few shops/tuners but I am still not sure about there abilities. It's a trust issue. The whipple is SWEET and was my first pick but I can get more for my money with the pro charger. I like the whipple's whine.
Old 06-25-2007, 04:00 PM   #14
bullitt482's Avatar
Sorry, but I don't see a centri putting down all but the EXACT same numbers as a roots type, a very refined roots type at that. Expect about 5-15 percent less than that whipple and even more torque, especially low end.
And you will get less for your money with a procharger. Peak numbers are nothing without support from the lower end. Now if you were aiming for 8's or 9's in the 1/4 my argument would be opposite, but that is whole nother ball game. No matter what rpm you are at with a roots type, nail it and your face will be pulled back in the seat, with a centri(i.e. procharger) it won't. It's average hp and tq in the usable range that wins races, not this top end peak power stuff.
01 Bullitt
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
Please give me your 2 cents on this Pro Charger for Shaundra DDTCM 2005-2010 Mustang GT 35 04-01-2010 11:41 AM
11 psi Pro Charger citti34 Mustang Parts for Sale and Wanted 4 07-13-2004 06:55 PM
1999 + Pro charger citti34 Mustang Parts for Sale and Wanted 7 07-06-2004 03:12 PM
05:17 PM
