STS Turbo - Mustang Evolution
Old 01-05-2011, 09:44 AM   #1
Mustangguy0202's Avatar
STS Turbo
I have a rear mount sts turbo on my 08 V6 runnin 7 psi anyone know how I can get more boost out of it? There could be a couple tiny leaks which I plan on fixing this weekend. Also thinking about a boost controller
Mustangguy0202 is offline   Reply With Quote
Old 01-05-2011, 09:48 AM   #2
Re: STS Turbo
make sure as you said you are not losing pressure, then you can work on a new blow off valve/controller to up the boost. I wouldn't push it much more though~ maybe 10psi with 91+ octane (maybe race gas or torco addative).
Old 01-05-2011, 09:51 AM   #3
Yea I'm over 350 hp now which is great for a V6 but I always want more.... Another thought would be the water/methanol injection kit for another 50-100 hp but might hold off on that for a while
Old 01-05-2011, 01:29 PM   #4
dwood63's Avatar
Re: STS Turbo
with a rear mount turbo you wont be able to push much boost
dwood63 is offline   Reply With Quote
Old 01-05-2011, 01:49 PM   #5
With all stock internals I'm not wanting alot more just 4 or 5 psi more and I've heard of ppl running 15 on a rear mount
Old 01-05-2011, 02:16 PM   #6
Re: STS Turbo
meth injection is nice and all but its such a hassle to mess with and refill etc... you do have an intercooler dont you?
Old 01-05-2011, 02:50 PM   #7
Yes I do
Old 01-05-2011, 05:01 PM   #8
Liltroy's Avatar
Re: STS Turbo
Dont know what size turbo you're running but assuming its large enough to maintain 10 psi through all that piping and intercooler, you could just change out the wastegate spring as a cheaper option to buying a boost controller. Or doesnt the sts kit come with an adjustable wastegate anyway? If so, then more boost is simply a screw turn away.Just make sure you tune for the added boost.
Wide open till you see God! Then brake!
Liltroy is offline   Reply With Quote
Old 01-05-2011, 05:24 PM   #9
Yea I'm going to look into it and explore all my options
Old 01-05-2011, 05:58 PM   #10
Old 01-05-2011, 08:26 PM   #11
Liltroy's Avatar
Re: STS Turbo
well according to sts's website, the turbo that came with your kit is suppossed to be good to 380hp and they're claiming around 320@9psi so I'm pretty sure it's capable of holding a steady 10psi.
Old 01-05-2011, 09:09 PM   #12
Yea I'm well over 320 at 7 psi although I have tons of other mods and not just the turbo
Old 01-05-2011, 10:49 PM   #13
The Darkside's Avatar
What's the other mods?
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 01-06-2011, 05:41 AM   #14
Bbk headers, throttle body, tb spacer, 3.73 gears and a t-lok
Old 01-06-2011, 08:48 AM   #15
Re: STS Turbo
the number 1 most important by far key to this equation is the tune, if the tune is bad or cheap or not done professionally by a dyno shop that knows what they are doing you should get that done asap, many times boost doesnt kill motors, the tune does lol.
also your fuel pumps, injectors, maf all need to be checked to see how close to their limit they are, I know with my MAF my ad counts are close when its cold (much closer to limits when its cold out side FYI) so thats currently my issue~ I cant boost any more without at least that and maybe a boost a pump for my fuel pump.
Old 01-06-2011, 09:54 AM   #16
I got the tune done by sts it's there turbo kit so I figure they probably know what their doing also got the predator maf and 42# injectors... I've been looking for a good fuel pump to upgrade to as well
Old 01-06-2011, 10:04 AM   #17
Re: STS Turbo
nice, you got a pic of the dyno graph?
Old 01-06-2011, 12:51 PM   #18
Naw sure don't
Old 01-06-2011, 03:12 PM   #19
Re: STS Turbo
did it get dynoed or did they just load a tune and say your good to go?
Old 01-06-2011, 04:46 PM   #20
Asked for all the info as far as mods and the vin and all and sent it to me and I drove and data logged and sen the info back to them and did that a few times... So I'm looking in to actually getting it on a dyno
v6 turbo pringle9666 Pre-2005 V6 Mustang 3 12-12-2010 05:13 PM
turbo for 94 3.8L Mikemx250 Pre-2005 V6 Mustang 3 09-02-2008 02:41 PM
Sts System Or Supercharger?? mustangmaniac Pre-2005 V6 Mustang 7 10-27-2006 10:29 PM
Turbo Mjcorn23 Pre-2005 V6 Mustang 12 04-25-2005 12:13 AM
Turbo!!!! steedav6builder Pre-2005 V6 Mustang 16 08-21-2004 12:13 AM
09:23 AM
