cam scratch - Mustang Evolution
Old 01-14-2011, 06:05 PM   #1
b's stang's Avatar
cam scratch
i bought a set of 127300 comp cams from a buddy of mine and one of the lobes has a scratch on it is that a problem? i mine its not a bad scratch but its noticeable. he ran them in his car for 5000 miles.
ID:	22806   Click image for larger version
b's stang is offline   Reply With Quote
Old 01-14-2011, 06:36 PM   #2
Gil_T2's Avatar
Re: cam scratch
take it to a machine shop, if it is not bad they can buff it down with emery cloth. also that cam requires you change the valve springs, Why did your friend take them out?
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 01-14-2011, 06:52 PM   #3
b's stang's Avatar
Re: cam scratch
got married, needs a truck, so he took all of his performance mods out
Old 01-14-2011, 09:15 PM   #4
Titus Wadicus
svtlx's Avatar
Re: cam scratch
+1 def get that buffed down a bit, that way the lifter roller rides sumwut true. it might be fine, but it seems awful deep on the pics from here.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-15-2011, 10:13 AM   #5
Re: cam scratch
Are you guys kidding me, I just went from BBR stg1 cams to FFRP hot rod cams and from what many mechanics and techs told me I would return those cams or toss them before installing them. Buffing out that scratch to the point where it can no longer be seen means reducing the lobe pitch of that particular lobe, definitely a NO NO. Even a third of a millimeter will change the profile.
MUSPOR911 is offline   Reply With Quote
Old 01-15-2011, 10:18 AM   #6
Re: cam scratch
My 2800 miles BBR stg 1 cams are available if you want. NSRs.
Old 01-16-2011, 03:40 PM   #7
b's stang's Avatar
Re: cam scratch
well i just got these cams so im gonna see if they are usable. if they arent im just gonna get a set of brand new cams.
Old 01-16-2011, 07:53 PM   #8
Re: cam scratch
If you want you could have my BBR stg 1 cams I just took out only 2800 miles.
Old 01-17-2011, 06:07 AM   #9
b's stang's Avatar
Re: cam scratch
How much do you want for them
Old 01-17-2011, 11:21 AM   #10
Titus Wadicus
svtlx's Avatar
Re: cam scratch
wutever lift you lose on that one valve i dought will b a noticable difference in h.p.
Scratch Remover Products sonicpony03 Mustang Audio & Video 9 11-08-2009 06:08 AM
Scratch Doctor? SVTCOBRA General Mustang Discussion 13 09-12-2009 04:05 AM
Building An Engine From Scratch OsirisGuy Classic Mustangs 10 07-08-2007 04:29 PM
fix - a - scratch Murph00 Mustang Audio & Video 2 07-14-2005 02:47 PM
Need Opinion on Scratch Removal... NJStang86 The Bar 24 10-21-2004 08:26 PM
01:54 PM
