V6 gas - Mustang Evolution
Old 01-19-2011, 08:08 PM   #1
V6 gas
What gas do you use for your V6?
Jnapoli85 is offline   Reply With Quote
Old 01-19-2011, 08:11 PM   #2
MC770's Avatar
Re: V6 gas
If you don't have any mods done on your car you can use the cheapest gas at the station and your car will be fine...
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 01-19-2011, 08:13 PM   #3
soccerfreak2143's Avatar
Re: V6 gas
^^^+1
i run 93 but only because of the tune. use cheap gas if you dont have a tune...it doesnt help any
soccerfreak2143 is offline   Reply With Quote
Old 01-19-2011, 08:14 PM   #4
What mods make a difference for gas? I'm about to put on a cai does that matter?
Old 01-19-2011, 08:15 PM   #5
Re: V6 gas
what year is your car?
Old 01-19-2011, 08:16 PM   #6
MC770's Avatar
Re: V6 gas
Correct me if I'm wrong but I don't think that you need a specific type of gas with a cai should be fine on the cheap stuff. If you have a tune on your car sometimes they require you to run a higher octane of gas.
Old 01-19-2011, 08:24 PM   #7
Titus Wadicus
svtlx's Avatar
Re: V6 gas
yup, i put on a k&n filter and now can only run 110 octane race fuel...just put the cheap stuff in bud
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-19-2011, 08:25 PM   #8
Re: V6 gas
yeah...a cai doesnt need better gas, but i would suggest getting a tuner also...if you have an 05+ i've heard a tuner helps a ton so i would suggest that..
Old 01-19-2011, 09:20 PM   #9
What tuners work best with an 08 v6?
Old 01-20-2011, 05:38 AM   #10
many people have been going for the sct tuners from american muscle. if you have an auto it will help the shifting a ton.
i have an 05 v6 and have the sct sf3 x3 tuner and its great. i'v heard that the 05+ cars are more responsive to basic bolt-ons than most other stangs, so i would suggest getting a tuner with your CAI cuz it would make a noticeable diference
Old 01-20-2011, 07:19 AM   #11
Does any of these mods void an extended warrenty n if not what mods do?
Old 01-20-2011, 08:02 AM   #12
Re: V6 gas
The neighbors. The guy that owns that old gasoline bus with the great big tank thats out in the open calling out to me saying frreee! gaass!
Seriously though I use 87oct and search for the cheapest when I'm going to fill up.
Straublittleman is offline   Reply With Quote
Old 01-22-2011, 07:38 AM   #13
Loris06LimeGT's Avatar
Re: V6 gas
Tuners don't void a warranty because you can plug it back in and put it back to stock. A cai if they have a problem with it, can be taken off and the original can be put back on.
I'm a Mustang Kind of Girl
2006 Legend Lime Mustang GT Vert 1 of only 718 made
Loris06LimeGT is offline   Reply With Quote
Old 01-22-2011, 10:44 AM   #14
06mustangmike's Avatar
Re: V6 gas
mine is tuned, 93 only.
06mustangmike is offline   Reply With Quote
Old 01-22-2011, 11:27 AM   #15
Loc: Austin,TX
Re: V6 gas
There are cai's for the S197 that dont require and tune but that is a waste IMO.Get a cai & tune now........smile later.
02:03 PM
