Spark plug wires - Mustang Evolution
Old 01-20-2011, 03:10 PM   #1
Mustangguy0202's Avatar
Ok guys help me out here... Lookin for advice on which plug wires I should get. I have an 08 V6 turbocharged mustang.. I have the screamin demon coil pack and NGK iridium plugs now I need sumthin that will deliver all that spark... I was thinking the Taylor 8.2 thundervolts or possibly livewires although a little pricey I've gotten used to that... Any opinions or experience on this?
Mustangguy0202 is offline   Reply With Quote
Old 01-21-2011, 06:04 AM   #2
Are they cop.... If so buy the ford stockers every aftermaket type go bad fast
Old 01-21-2011, 07:53 AM   #3
If I was gonna leave it stock I wouldn't of gotten the coil pack I need aftermarket wires to carry the extra spark that is generated by the coil pack but constricted in my stock wires
Old 01-25-2011, 05:37 AM   #4
The taylors are 8.2mm and the livewires are 10mm still no suggestions?
Old 01-25-2011, 08:40 AM   #5
Re: Spark plug wires
most dont upgrade coil pack/wires as most of the time is useless power wise. I am sure the Taylors will deliver all the spark you will need.
Old 01-25-2011, 08:47 AM   #6
Well running the turbo and sprayin more fuel than most due to the injectors I need that extra spark to burn up all that fuel in my mind anyway... The way I c it more air from the turbo more fuel from the injectors only thing missing is the bigger spark to bring it all back together which is y I got the coil pack and iridium plugs which because of the coil pack I can gap them to .065 but first I need the wires to carry the spark
Also should help my mpg's
Old 01-25-2011, 08:53 AM   #7
I guess im stuck on the COP's the 4v motors use, my OEM system is perfect, no issues and no need to change for just about any level. I guess on a car that uses wires with a power adder it will help the overall system work better and more efficient.
Old 01-25-2011, 08:58 AM   #8
Yea that's what I'm thinking... Just makes sense more spark means more fuel burned which leads to more power
Old 01-25-2011, 06:00 PM   #9
Chick Nasty's Avatar
Send a message via AIM to Chick Nasty
I put the taylors on my dads 86 vette....they seem to do a good job
Chick Nasty is offline   Reply With Quote
Spark plug wires Nrooney3 1996-2004 Mustang GT 2 12-20-2010 09:09 PM
JBA Spark plug wires, 8mm or 9mm? ricklmesa Pre-2005 V6 Mustang 6 01-24-2006 10:40 PM
spark plug wires... which one? electricstang Pre-2005 V6 Mustang 6 09-15-2005 02:19 PM
Spark Plug Wires Laser02 Pre-2005 V6 Mustang 32 11-08-2004 08:30 AM
Spark Plug Wires Shahrum Pre-2005 V6 Mustang 10 02-05-2004 10:09 AM
10:05 PM
