Mods - Mustang Evolution
Old 01-26-2011, 10:40 AM   #1
Mods
Hi I got a 2009 mustang gt with 4:10 gears, a cold air intake and pypes violator axle back exhaust I want to make it faster but don't know what to buy I want something thats cheap I was thinking about doing bbk shorty headers or a bbk throttle body. What do you guys think
MustangZach is offline   Reply With Quote
Old 01-26-2011, 10:49 AM   #2
Re: Mods
you will need a tune for nearly all CAI kits for 05+ GT mustangs so if you dont have one make that your top priority (as it may not be safe currently to drive if it doesnt have a tune)
CAI
under drive pulleys
Exhasut
Tune
alum drive shaft
those will all help out
Old 01-26-2011, 11:06 AM   #3
Chick Nasty's Avatar
Send a message via AIM to Chick Nasty
Re: Mods
+100000000 on the tune
Chick Nasty is offline   Reply With Quote
Old 01-26-2011, 11:08 AM   #4
Kpd3014's Avatar
I agree with the tune but I would install a twin 62mm throttle body first. Huge difference in acceleration.
2012 GT500 PP, NAV, SSW exhaust, BMR lowering springs
Kpd3014 is offline   Reply With Quote
Old 01-26-2011, 12:42 PM   #5
CAI
under drive pulleys
Exhasut
Tune
alum drive shaft
Ok I will do a tune what about some headers or should I do a throttle body
Old 01-26-2011, 01:06 PM   #6
Re: Mods
im not sure how those work some say they see noticable gains with good headers on their 05+ gt but I personally do not know. The car could be unsafe (a/f to lean etc) and could have issues or major issues so until you tune it I would consider putting the OEM intake back on or making sure the mauf of the intake says its ok to not have a tune when using it.
Old 01-26-2011, 01:22 PM   #7
Ok but the cold air intake said it didn't need a tune but ill buy one anyways
Old 01-26-2011, 01:27 PM   #8
Kpd3014's Avatar
I had an '05 and I did a full exhaust as well as the throttle body. With the exhaust the only noticeable difference was the sound. When I installed the bbk throttle body I could feel a quicker acceleration which only adds to your CAI and tune. Plus the throttle body is cheaper and alot easier to install if money and time are an issue.
Old 01-26-2011, 01:59 PM   #9
Okay I'll look at them
Old 01-26-2011, 02:12 PM   #10
Re: Mods
if the intake said it didnt require a tune you are probably fine, just wanted you to double check to keep the car safe is all.
Old 01-26-2011, 04:34 PM   #11
Yea I checked it again and it docent need a tune but I'm going tonged one anyways thanks
Old 01-26-2011, 06:59 PM   #12
Shorty headers are a waste of money....the stock manifolds flow great only to be outdone by long tubes ...Spector pretty much has the nail hit on the head up there...and I noticed my car revved alot quicker after I installed an accufab tb....bbk is hit or miss...they are cheap for a reason
Old 01-26-2011, 09:23 PM   #13
Ok thanks
How about a throttle body spacer do they help any?
Old 01-27-2011, 04:30 AM   #14
No...
Old 01-27-2011, 10:24 AM   #15
No...
Ok
Old 03-23-2011, 12:13 PM   #16
Dion11197's Avatar
Re: Mods
There's plenty of things that you can do, it's all just about how much money you want to / can spend. You've already got the gears, CAI, and axle back. If you're gonna spend money on headers, save for the long tubes. An off-road h or x-pipe will help out with gains also, but then you run into emission problems if you have emissions in your area. The TB is a great way to go... and there are plenty out there. There's one company L and M I think it is that has larger TB's that don't require a tune. Something to look into. A turner is a must though to get the full potential out of your combination. Ford leaves a lot on the table with their conservative factory tunes. Hope this helps.
Dion11197 is offline   Reply With Quote
Old 03-23-2011, 12:28 PM   #17
Hey does anybody know what kind of exhaust i can put on in southern California because of all the stupid ****ing laws
Frye0811 is offline   Reply With Quote
Old 03-23-2011, 12:29 PM   #18
Re: Mods
Post a new thread and someone may be able to help you out.
93CobraGuy is offline   Reply With Quote
Old 03-23-2011, 12:47 PM   #19
Gil_T2's Avatar
Re: Mods
To make power you should replace your current CAI with one that requires a Tune, You need to get more air in the engine if you plan on a TB, or LT headers. As far as TB's go Ford racing 62mm for $600.00, or BBR's GT500 TB kit 60mm, for $340.00, what ever fits your pocket book
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Some welcome mods... The Whistler Pictures and Videos 10 03-23-2011 12:24 PM
mods 50 pony 1979-1995 Mustang GT 3 10-11-2009 09:41 AM
My Mods So Far AutoMovt Pre-2005 V6 Mustang 15 06-21-2009 02:12 PM
what mods should i do first? zapstang Pre-2005 V6 Mustang 25 06-12-2009 12:39 PM
Which Mods Justin 1979-1995 Mustang GT 20 04-27-2006 05:43 PM
03:03 PM
