4.10 Gears - Mustang Evolution
Old 02-03-2011, 03:10 PM   #1
Stang23's Avatar
4.10 Gears
I wanna order a set of ford racing 4.10 gears soon. There 155 buks on American muscle. The question is to have them installed at a local place do I need all the extras like the installation and bearing kit and the 8.8 inch rear gear pinion bearing or can I just buy the gears for 155 without the extras?
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
Old 02-03-2011, 04:36 PM   #2
Re: 4.10 Gears
If it were me I would order the install kit as well. Will probably save you money in the long run because the installer will need the parts anyway and will charge you for them anyway at his charge.
93CobraGuy is offline   Reply With Quote
Old 02-03-2011, 04:40 PM   #3
Titus Wadicus
svtlx's Avatar
Re: 4.10 Gears
he will charge u an insane mark-up for that stuff. prolly only use 1 shim, then use the rest of the kit on someone's car..
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-03-2011, 05:08 PM   #4
Stang23's Avatar
Ok so I need the installation and bearing kit?
340 RWHP
325 RWTQ
Old 02-03-2011, 05:13 PM   #5
Titus Wadicus
svtlx's Avatar
Re: 4.10 Gears
i apologize, i would recommend getting the kit for sure..you can always sell what you dont use to someone else.
Old 02-03-2011, 05:35 PM   #6
Stang23's Avatar
Ok. How much do you think a shop will charge to put them in?
340 RWHP
325 RWTQ
Old 02-03-2011, 05:43 PM   #7
Titus Wadicus
svtlx's Avatar
Re: 4.10 Gears
it varies, ive been quoted up to 600 bucks, some of the guys here have gotten it done for as lil as 200 bucks. i traded some race car parts i wasnt using when i got mine done. i think i spent 900 dollars to get my ram done. it really depends on who you know. but you definatley wanna make sure you take it to someone reputable and knowledgable. and just cause they quote u a large dollar amount doesnt mean they are good. take your time and shop around, ask ppl wit hot rods in your area where they go...ask them if their gears whine or not (it's ok to talk to chevy ppl too). just ask around, dont jump on the first shop that says they can do it...ask around, you'll be glad you did.
Old 02-03-2011, 05:48 PM   #8
Stang23's Avatar
Ya I've already been asking around. I got a few places in mind..
340 RWHP
325 RWTQ
Old 02-03-2011, 05:55 PM   #9
Titus Wadicus
svtlx's Avatar
Re: 4.10 Gears
when it warms up im taking the 3.42's in my old stang and putting them in my new stang. my friend is a master mechanic and ima have him help me with mine. he says i know enough to do it myself, i just dont feel confident. so ima have him supervise..at least
Old 02-03-2011, 11:11 PM   #10
Stang23's Avatar
Ohh cool. Well I guess I'll go with the installation kit and gears
340 RWHP
325 RWTQ
Old 02-03-2011, 11:29 PM   #11
Re: 4.10 Gears
Why don't you just swap rear ends? Wouldn't that be easier?
Old 02-03-2011, 11:31 PM   #12
Stang23's Avatar
I don't know wouldn't that cost a lot?
340 RWHP
325 RWTQ
Old 02-03-2011, 11:37 PM   #13
Re: 4.10 Gears
I was directing that at svtlx, sorry.
Old 02-04-2011, 12:39 AM   #14
Stang23's Avatar
Ohh lol ok
340 RWHP
325 RWTQ
Old 02-04-2011, 07:07 AM   #15
Re: 4.10 Gears
yea do not skimp on rear end gears, find a shop that KNOWS what they are doing, not just some crappy place because its cheap. If they do it wrong the gears can make noise or even fail.
Ford racing went over to motive to do their gears and motive are known to whine more so than OEM ford used to, just FYI to be even more careful.
Its not just as easy as shimming and your done you have to check and do more than that.
Old 02-04-2011, 08:31 AM   #16
stampde's Avatar
Re: 4.10 Gears
I've NEVER had a problem with Ford Racing (motorsport) gears , NEVER ......
but its been a few since I've done any ...
2011 GT Auto
Old 02-04-2011, 04:50 PM   #17
Stang23's Avatar
Ya they should be good
340 RWHP
325 RWTQ
Old 02-06-2011, 09:30 AM   #18
Titus Wadicus
svtlx's Avatar
Re: 4.10 Gears
im taking the gears from my 92 notch and putting them in my 97 v6 (soon to be a v8).... im taking everything from my 92 and putting it in my 97. minus the harness..i got a 95gt harness so it fits the car better instead of retro-fitting the foxbody harness.
im just swap'n the gears and trac-loc to the 97. who wants a 4lug 97 right?
Old 02-06-2011, 05:39 PM   #19
Re: 4.10 Gears
Ahhh, I gotcha now!
Old 02-08-2011, 09:36 AM   #20
The Darkside's Avatar
Re: 4.10 Gears
Yup you got the right gears, get the kit and find a good place
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 02-08-2011, 10:32 AM   #21
Stang23's Avatar
Ok I will but Ken do you know of a good shifter for an automatic? My shifter Is about to go out. I was looking at the tci ratchet shifter. Is it any good? I don't like a lot of the shifters like b&m and others because there so big and bulky.
340 RWHP
325 RWTQ
Old 02-08-2011, 12:00 PM   #22
Re: 4.10 Gears
i actually realy wanted that shifter too! but i dont know if its any good, i say look for reviews. Its a good company in general.
My shifter did get messed up once (i droped snapple in it!) so i got a stock new one. freaken 800 bucks! dam dealers.
i think the tci shifter looks bad ***!
anyone one else know anything about it?
i bleed Race fuel!
Old 02-08-2011, 12:22 PM   #23
Stang23's Avatar
If anyone knows more about it please let me know. But I read quite a few reviews on it and for the most part everyone loves the shifter and says it works great.
340 RWHP
325 RWTQ
Old 02-14-2011, 12:11 PM   #24
Stang23's Avatar
I ordered the TCI shifter on Saturday and should receive it sometime this week. I'll let you know how I like it.
340 RWHP
325 RWTQ
Old 02-15-2011, 08:04 AM   #25
Re: 4.10 Gears
oh dude please do let me know, cause im seriously thinking of getting it too.
i bleed Race fuel!
Old 02-15-2011, 08:29 AM   #26
Mustangguy0202's Avatar
If your tuned y bother with a shifter if your shift points are perfect from the tune? Funner to drive I guess
Mustangguy0202 is offline   Reply With Quote
Old 02-15-2011, 08:43 AM   #27
Stang23's Avatar
Ya well I'm pretty pissed cuz it's on back order for about 2 to 3 weeks. And I ordered it on stage3motorsports and they contacted me yesterday telling me that and on American it was out of stock so that's why I ordered it on stage3. But on there web site it didn't say **** about if it was in stock or on back order or anything so I wasn't happy at all because if I knew that I wouldn't have ordered it yet.
340 RWHP
325 RWTQ
Old 02-15-2011, 03:38 PM   #28
Re: 4.10 Gears
bro see if you can order it directly from TCI
i bleed Race fuel!
Old 02-15-2011, 04:26 PM   #29
Stang23's Avatar
Ya I'll try that.
340 RWHP
325 RWTQ
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
gears johnnyc 1996-2004 Mustang GT 4 06-09-2009 08:37 PM
4.10 gears powerhungry966 Pre-2005 V6 Mustang 7 10-23-2005 06:53 PM
gears 8.8 or 7.5 strike1980 Pre-2005 V6 Mustang 5 07-31-2005 11:05 PM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
02:14 PM
