Coil packs - Mustang Evolution
Old 02-07-2011, 12:43 PM   #1
Coil packs
Hey guys I'm new to this forum. I plan on sticking around as I'm new to mustangs. Just made the switch from a ricer. Anyways, I had 2 cylinders misfiring so I went and picked up a full msd kit of 8 coil packs. My question is, how hard are they to install? Should I have a mechanic do this or can it be done at home? Thanks!
Chasetucker is offline   Reply With Quote
Old 02-07-2011, 12:55 PM   #2
Re: Coil packs
should be about the same as on my car, mine there is a coil over, not sure yours has this, anyway you basically just pop em off and pop em on. You may have a bolt holding yours on the plug.
Old 02-07-2011, 12:56 PM   #3
Okay sweet. Yeah sorry for not being specific. I have a 05 GT. I can see a bolt holding them in, all I do is unscrew that, pull them out then put the new one in?
Old 02-07-2011, 01:10 PM   #4
stampde's Avatar
Re: Coil packs
yup unscrew the bolt , pop off the coil , put back in reverse order and do them one at a time so you don't get the wiring crossed
2011 GT Auto
Old 02-07-2011, 01:12 PM   #5
Awesome thanks guys. A auto place was trying to charge me $140 just to put them in. I just spent $400 on the coils. Don't wanna spend anymore than I have to
Old 02-07-2011, 01:39 PM   #6
Re: Coil packs
you might want to price OEM ones from tousleyfordparts.com as the OEM ones will work just as good and might save you some money.
Old 02-07-2011, 01:55 PM   #7
I wish I knew that before! :/
Old 02-07-2011, 02:19 PM   #8
Could the coil packs be the reason my car is pinging really loudly?
Old 02-07-2011, 02:27 PM   #9
What grade fuel are you running? May need to go to 93 if not already.
Alscobra is offline   Reply With Quote
Old 02-07-2011, 02:31 PM   #10
Yeah I'm running 93. It's still doing it.
Old 02-07-2011, 05:17 PM   #11
Re: Coil packs
i would contact msd. they might recomend a different plug. if its really pinging, which is also called detonation, it can really cause problems.
Old 02-07-2011, 05:55 PM   #12
Try 1 plug range colder plug...
Old 02-07-2011, 06:59 PM   #13
Okay so I shouldn't be putting these in? The reason I bought them was because I have 2 cylinders that are misfiring in my engine
Old 02-07-2011, 10:14 PM   #14
Titus Wadicus
svtlx's Avatar
Re: Coil packs
sooo wut? u just read the codes i assume? sounds like you just need some spark plugs. or have you tried that yet?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-07-2011, 10:23 PM   #15
I haven't tried that. The mechanic just told me that the code meant it was a misfire and it was most likely my coil packs
Old 02-07-2011, 10:32 PM   #16
Titus Wadicus
svtlx's Avatar
Re: Coil packs
so do you know which cylinders were misfiring? i would replace those plugs first before you start buying coils. you always start with the cheap stuff first then work your way up...lol. at least pull them out and look at them. sometimes they can misfire intermittenly, plugs can be weird.
Old 02-07-2011, 10:42 PM   #17
Re: Coil packs
What svtlx said. That and coil packs very rarely go bad. Not saying they don't ever, but very rarely.
93CobraGuy is offline   Reply With Quote
Old 02-07-2011, 10:57 PM   #18
Okay I will do that tomorrow then. And I believe that it is 1 and 6 that are misfiring? I'm glad I haven't put these coil packs in yet. I'll check those out first
Old 02-08-2011, 12:07 AM   #19
Just one nut holding it down, follow your spark plug wires and you can't miss them, clean the top before you pull them, you dont want dirt getting down in there...
Ducatisport is offline   Reply With Quote
Old 02-08-2011, 12:28 AM   #20
1ijack's Avatar
Send a message via Yahoo to 1ijack
Re: Coil packs
I would check the plugs first and see what the plugs say. I knew when mine were starting to go so I went to E3 plugs and later on changed the coil pack plugs not the pack and she started running good again.
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 02-08-2011, 07:37 AM   #21
Alright sweet in glad I checked on here first! Thanks guys I'll let you know what I find out
Coil Packs 04_GT 1996-2004 Mustang GT 6 01-12-2011 08:05 PM
Aftermarket Coil Packs jimbullit 2005-2010 Mustang GT 13 12-13-2010 02:53 PM
Coil on Plug Ignition Coil Pack Set (8) 99-04 Mustang W/ Wiring Harness Cobra GT Mustang Parts for Sale and Wanted 7 12-28-2008 09:59 PM
msd coil packs installed stovalini69 1996-2004 Mustang GT 0 08-04-2006 10:20 PM
Glass packs whipster24 Pre-2005 V6 Mustang 11 10-09-2003 08:57 PM
10:42 AM
