Tire light - Mustang Evolution
Old 02-10-2011, 03:45 PM   #1
Tire light
I put air in my tires but the tire pressure sensor light is still on. Not sure how I can get it to go away any suggestions?
Jnapoli85 is offline   Reply With Quote
Old 02-10-2011, 03:58 PM   #2
Re: Tire light
Check the psi on all your tires to make sure you've filled them up enough.
sno4life is offline   Reply With Quote
Old 02-10-2011, 04:13 PM   #3
06mustangmike's Avatar
Re: Tire light
i'm not sure if there is a way to reset that,someone here will know.
06mustangmike is offline   Reply With Quote
Old 02-10-2011, 04:53 PM   #4
Unplug the battery for 15 minutes. Should shut it off unless there is still a problem
Old 02-11-2011, 05:39 AM   #5
Mustangguy0202's Avatar
Hit the reset button that's by the hazards button above the radio
Mustangguy0202 is offline   Reply With Quote
Old 02-11-2011, 06:01 AM   #6
Wolfsbain76's Avatar
Re: Tire light
When I got my stang one of the things that the dealer told me was about the tire pressure light. He said that if it stays on, even after they have been filled with air, then I would have to bring it to them so that they could reset it.
2007 Mustang GT
Wolfsbain76 is offline   Reply With Quote
Old 02-11-2011, 06:09 AM   #7
What tire pressure do you normally keep your tired at
Old 02-11-2011, 06:16 AM   #8
Re: Tire light
I just put the recommended amount that is posted on the tire. Unfortunately though, my light is on now for the past 3 days and of course every gas stations tip to the air pump is damaged from the people that can't put it back the right way, so it gets ran over by the cars!
2007 Mustang GT
Old 02-11-2011, 06:16 AM   #9
No mine always goes off after I fill the tire and drive maybe 20 feet
Old 02-11-2011, 08:20 AM   #10
Re: Tire light
you can get a little tool to reconnect them to the car~ might be that (or get the dealer to do it)
Old 02-11-2011, 01:43 PM   #11
MC770's Avatar
Re: Tire light
Don't know if ford does this but on my cousins toyota tacoma he had this problem and it turned out that the spare tire had a sensor in it too.
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 02-11-2011, 09:26 PM   #12
Blogger
99ford's Avatar
Re: Tire light
I don't think they do. I thought they did away with the spare on 10 models; maybe I'm thinking a different car.
Also make sure you check your air the morning. I found this article helpful at TireRack Tire Tech Information - Air Pressure, Temperature Fluctuations
Old 02-12-2011, 05:43 AM   #13
Re: Tire light
Would you believe that my light wouldn't turn off after reading this post! I usually just fill the bad tire and it goes off...not this time! So I checked all the tires and I'll be damned that the two fronts were low as well. So I filled them too, and the light still wouldn't go off!! So I called the dealership and they said that the computer probably needs to be retrained again. But first try driving it around now that all tires are filled and give the computer time to retrain/reset itself. I didn't, I let it sit over night and this morning it was off. But if yours is acting up the way it is, then unless someone here on the forum knows how to retrain the air sensor like the window, then you might have to take it to the dealer. Let us know what the outcome is!
2007 Mustang GT
The Service Engine Light Soon light is on!! HELP! punisher0822 1996-2004 Mustang GT 11 07-15-2010 10:15 PM
Brake Light & ABS Light on. stevinas 2005-2010 Mustang GT 1 06-26-2008 02:21 PM
Green Light, Red Light Brent Pictures and Videos 11 01-24-2008 04:23 PM
tire help mustang0386 Mustang Wheels & Tires 10 11-16-2006 11:51 AM
tire Q STEVE Mustang Wheels & Tires 6 06-28-2005 10:13 PM
11:26 PM
