Ford Lightning Question - Mustang Evolution
Old 02-19-2011, 08:45 AM   #1
I'm working on a buddies 04 Lightning today doing the brakes and he also said the truck is sluggish in power so I cleaned his air filter first thing and it was bad (K&N) but I noticed the throttle body is slobbering oil any suggestions
Redline22 is offline   Reply With Quote
Old 02-19-2011, 09:40 AM   #2
stampde's Avatar
Re: Ford Lightning Question
it may be sucking oil through the pcv valve ? hope fully there's not a problem with the s/c
its a shame because if thats all up in the throttle body i'm sure its through out the super charger to
2011 GT Auto
Old 02-19-2011, 10:32 AM   #3
Titus Wadicus
svtlx's Avatar
+1
itsa common deal on blown motors... i get sum in my intake too and i got a pushrod motor with centrifugal supercharger. i agree it's prolly the pcv. i seen somewhere that they make a resevoir tank that runs in line with the pcv and catches the oil before it gets to the blower.
im not a twin screw expert, but im pretty sure you are gonna have to take the blower apart and get the oil out. unless someone else in here chimes in with a better suggestion or advice.
i read the stuff in a tech article a while back, so now i check my pcv once a month, but i still have to empty the intake from time to time.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
« Dad's '08 GT | V6 »
Ford Lightning Vs. Other Vehicles JROC Pictures and Videos 0 01-10-2007 04:07 AM
Ford Lightning 98StangGT General Car Discussion 24 01-05-2007 07:57 AM
Top Gear - Ford Lightning Test Drive JROC Pictures and Videos 1 10-26-2006 12:02 AM
Ford lightning dead... PureVenom The Bar 5 10-22-2004 08:45 PM
Whats a Ford Lightning? 03redfire cobra The Bar 5 05-14-2004 11:57 AM
01:55 AM
