Driveshaft vibration with 1 piece alum DS - Mustang Evolution
Old 02-24-2011, 12:35 PM   #1
RLF9409's Avatar
Last year I purchased a one piece driveshaft and ever since I have had a vibration above 100 mph.
I reduced it significantly by rotation the DS a bolt at a time and now 180 degrees from where I started.
The vibration is not that bad but still noticeable. I didn't have any vibration before so I am beginning to wonder if the $ spend on this mod was worth it. I have read that my pinion angle might be off considering the cars racecraft suspension.
Anyone else have a lowered car with sim problems? Wondering if I am on the right track with this adjustable upper control arm. I'm sure once I get urn the car and measure the pinion angle I'll know if that is the problem.
Any input would be greatly appreciated.
Mike
Saleen:475 HP Upgrade 3.8 pulley 39# injectors, upgraded CAI, 20" Chrome w/275/35ZR's, 14 in Front Brakes, GT500 Heat Exchanger, Rear bumper inlays, Shaftmaster 3.5 Alum Driveshaft, AEM Wideband A/F guage, Pypes Long tube headers X-pipe w/cats, Extreme chin spoiler, Steeda Tri-Ax short throw shifter, Hood Struts WMS stealth hood pins, UMR upper and lower rear control arms. Also have a 1967 S Code w/351 Windsor, 4 wheel disc, 9 inch posi,Fastback & 1964.5 Convertible 2nd owner 260 V8 w/generator (basketcase)
RLF9409 is offline   Reply With Quote
Old 02-24-2011, 12:54 PM   #2
Re: Driveshaft vibration with 1 piece alum DS
my cobra has the factory ford alum driveshaft and they are known to have vibration in the higher mph, mine vibrates a bit around 80 mph but settles back out at 95~
You did lessen your pinion angle by lowering the car no doubt but I dont think that would make it worse~
Old 02-24-2011, 01:25 PM   #3
RLF9409's Avatar
This is a factory Saleen. It had no vibration before the alumDS upgrade. I'm kind of wishing I kept the stock one..
This is getting to be one of those don't fix it if it ain't broken mods.
Old 02-24-2011, 01:27 PM   #4
stampde's Avatar
Don't go 100 mph !!! I KNOW ITS HARD NOT to do !!!
maybe a u joint ? or pinion angle ? or maybe u bought a drive shaft that wasn't balanced properly from the manufacturer ..
2011 GT Auto
Old 02-24-2011, 02:28 PM   #5
SaleenFiend's Avatar
Def check your U-Joints and see if you can have your pinion angle checked. Lastly as stated check the balance on the driveshaft with a local shop that specializes in driveshafts.
Old 02-25-2011, 10:01 AM   #6
they make a big difference in 05+ the stock one is SO HEAVY. Every 1lb of rotating mass is equal to about 10lbs of dead weight so you may only save 20lbs but thats like 200lbs of dead weight
Old 02-26-2011, 08:11 AM   #7
Gil_T2's Avatar
If your car is lowered , you need an adjustable upper control arm , and need to set the pinion angle. I had same problem, it was even stated on the install instructions from Coast DS.
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 03-12-2011, 11:06 PM   #8
RLF9409's Avatar
Ok. To report my findings...
I installed the upper control arm and got the angle a little closer. The vibration isn't as bad so I must be on the right trail.
I'm in germany right now so it is a little hard to find a driveshaft shop. I think once I get it back in the states this summer I'll take it in. Of course I won't be able to drive at 100+ all the time.
I'm going to rotate the DS another 45degrees on the pinion to see if that helps a little.
Maybe it's my new tires but but it feels like it is hooking up a little better as well.
Old 03-14-2011, 07:43 AM   #9
let us know how it works out rotating it again.
Several things FS: (clutch, alum flywheel, ect) jimmy_beaner Mustang Parts for Sale and Wanted 41 06-14-2009 10:32 PM
driveshaft and transmission Mustangbobby General Mustang Discussion 1 04-24-2008 07:07 AM
driveshaft for new rear charkelly9 Pre-2005 V6 Mustang 2 10-22-2005 09:11 PM
FS - Aluminum Driveshaft drummerstang98 Mustang Parts for Sale and Wanted 13 09-22-2005 09:06 PM
Driveshaft from a T-5 fit on a T-45? SpectorV Pre-2005 V6 Mustang 0 08-03-2004 09:44 AM
04:46 PM
