Brake rotors - Mustang Evolution
Old 03-09-2011, 01:12 PM   #1
Stang23's Avatar
Brake rotors
Looking to replace all 4 rotors and pads with Baer drilled and slotted rotors. Not sure what pads to go with. The rotors by Baer are a little pricey. Anyone know of a good setup for the price? Any suggestions or advice would be great.
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
Old 03-09-2011, 01:26 PM   #2
Re: Brake rotors
hawk makes good pads dont they? Ive heard they have dust issues. Is this a track car or a daily driver?
Old 03-09-2011, 02:20 PM   #3
Stang23's Avatar
It's a daily driver. But I'm not impressed with hawk pads. The stopping is good but there really noisy and a lot of vibration in the petal. I have drilled and slotted rotors with hawk pads and I just don't like it. The rotors aren't the greatest either. So I wanted to upgrade to something better. And do all 4 instead of just the front two.
340 RWHP
325 RWTQ
Old 03-09-2011, 02:30 PM   #4
With drilled and slotted rotors, you may not want a very hard ceramic pad. Try top line raybestos. They may wear out a little quickly but shouldn't damage the rotors. I've used those and Wagner pads.
Alscobra is offline   Reply With Quote
Old 03-09-2011, 02:38 PM   #5
Stang23's Avatar
Ok what about as far as rotors. What would be a good setup?
340 RWHP
325 RWTQ
Old 03-09-2011, 02:41 PM   #6
Power slots are pretty good. I'm running brembos.
Old 03-09-2011, 03:27 PM   #7
Stang23's Avatar
Ya slotted rotors are more for the track right?
340 RWHP
325 RWTQ
Old 03-09-2011, 03:28 PM   #8
Stang23's Avatar
And also do ss brake lines make a good improvement?
340 RWHP
325 RWTQ
Old 03-09-2011, 05:40 PM   #9
Region: Iowa
Re: Brake rotors
SS lines will help provide a more firm and predictable pedal feel. Stock rubber lines will flex and expand to a certian degree and the SS lines remove that.
Changing over to a high performance brake fluid will provide a higher boiling point and also improve braking by increasing the amount of time it takes to 'boil' your brakes (pedal to the floor). This is really a track thing where you are heating up the brakes.
You will actual see a lot track people shy away from (especially drilled) and slotted rotors as they are more prone to cracking under extreme track conditions. If you are not going to track the car and like the looks, go for it.
NQSperformance
Vendor for:
American Muscle - Maximum Motorsports - Stack Racing - Koni - Tokico - H&R - Eibach - Hawk - Powerslot
John@NQS is offline   Reply With Quote
Old 03-09-2011, 05:51 PM   #10
Stang23's Avatar
Ok what rotors would you recommend?
340 RWHP
325 RWTQ
Old 03-11-2011, 08:07 PM   #11
Gil_T2's Avatar
Re: Brake rotors
For street use any of the rotors are good, they must meet FED spec's, Hawk pads are very good, i had 82,000 miles on my hawks and drilled, and slotted rotors. They performed great on and off the track. If your current setup has problems it maybe sticking calipers. I have fixed alot of brakes for customers and found that rust and dirt build up causes the caliper to stick
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 03-11-2011, 09:20 PM   #12
Stang23's Avatar
I was thinking about going with the power slots. What do you think? And I'm Not sure what pads yet since I wasn't too I'm pressed with the hawk pads.
340 RWHP
325 RWTQ
Old 03-13-2011, 10:17 PM   #13
Region: Iowa
Re: Brake rotors
powerslot are good rotors. If you don't like the Hawks, you might want to look into the EBC brand.
NQSperformance
Vendor for:
Old 03-13-2011, 10:26 PM   #14
Stang23's Avatar
Ok. Does EBC make good pads?
340 RWHP
325 RWTQ
Old 03-16-2011, 05:54 PM   #15
Re: Brake rotors
I have heard good things about EBC, thinking about their stuff(Rotors / Red Stuff Pads) on mine with SS lines
06blkGT is offline   Reply With Quote
Old 03-16-2011, 06:14 PM   #16
Stang23's Avatar
Ya they seem like they are pretty good too
340 RWHP
325 RWTQ
« Sound Clip | Mod »
GT Front Brake Calipers and Rotors SVTCOBRA Pre-2005 V6 Mustang 23 07-20-2010 02:22 PM
Stock Front Brake Calipers & rotors off a 2002 V6. runvsofthisbull Mustang Parts for Sale and Wanted 0 05-27-2009 05:20 PM
brake pads and rotors electricstang Pre-2005 V6 Mustang 18 07-10-2006 03:18 PM
Installing Brake Pads and Rotors Mustang414 Pre-2005 V6 Mustang 13 05-21-2005 06:04 PM
11:44 PM
