Tire Seal Breaking - Mustang Evolution
Old 03-13-2011, 07:01 PM   #1
stmpede's Avatar
Tire Seal Breaking
Has anyone had issues with the seal breaking on newly installed tires? I had 275/35/19's (BFG KDW's) installed on 19" x 9.5" RTR wheels and had two separate tires go flat in two days. The leaks were very quick and the escaping air was loud and obvious. Once I fill them back up with air, they are fine again.
stmpede is offline   Reply With Quote
Old 03-13-2011, 08:55 PM   #2
cbf102770's Avatar
Re: Tire Seal Breaking
Not something I have heard of, but I know I would be calling the shop where you had them installed and having a nice long talk with the manager , sounds like a bad install to me, not to mention the danger of the situation. I hope you weren't driving it when they went down. I would see about having the shop replace the ones that went flat at their expense.
2014 Sterling Gray GT Premium 6 MT. Track Pack, Recaro Seats, Shaker Pro. Upcoming mods Roush axle back, JLT oil separator, Roush front splitter, MGW shifter. Trufiber Carbon underhood dress up.
cbf102770 is offline   Reply With Quote
Old 03-13-2011, 08:59 PM   #3
Jamesgt08's Avatar
I agree. Take em back and make em replace it.
Jamesgt08 is offline   Reply With Quote
Old 03-13-2011, 09:14 PM   #4
Titus Wadicus
svtlx's Avatar
i seen it happen before. it just happened to me three weeks ago so wtf right? i air it back up and been driving every since.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-13-2011, 11:16 PM   #5
Tire hasn't softened with driving yet and the bead is really stiff. Should solve itself in a couple weeks
Built 2 Last TTT
Old 05-03-2011, 06:02 PM   #6
Gibby's Avatar
If the tire guy put clip on weights on the rim it will cause some tires to have a slight leak untill the tire gets low enough to unseat the bead.
Gibby is offline   Reply With Quote
Old 05-03-2011, 06:08 PM   #7
Titus Wadicus
svtlx's Avatar
cant say ive seen that happen..
Old 05-03-2011, 06:13 PM   #8
Gibby's Avatar
I was a tire guy for quiet a while and I've seen it. Just a suggestion.
Old 05-03-2011, 06:22 PM   #9
stmpede's Avatar
They did use clip on weights!
Old 05-03-2011, 06:25 PM   #10
Gibby's Avatar
Ok well there you go. If you do any "real" driving clip on weights are a NO GO! Especially if you have lower profile tires.
Old 05-03-2011, 06:26 PM   #11
Loc: Austin,TX
Never heard of that happening either....
Old 05-03-2011, 06:28 PM   #12
Gibby's Avatar
Well if any of you were tire guys you would understand what I'm sayin. If not consider the source.
Old 05-03-2011, 06:37 PM   #13
Loc: Austin,TX
Ive done pleanty of tires....just never experienced that particular issue.
Old 05-04-2011, 05:59 AM   #14
Tib
Tib's Avatar
I havn't heard of this happening but I do change tires on the side for motorcycles. Just a stupid question, is it leaking from the valve core? Might need to check and see if it is. You can replace the core without replacing the whole vavle if is it.
2003 Roush Mustang GT Stage 2 Package - Current 'Stang
1998 Mustang GT - Previous 'Stang
Tib is offline   Reply With Quote
Old 05-04-2011, 07:19 AM   #15
its either the tire, the rims out of round, or the installation
New U.S. Seal Herbstang The Bar 8 08-07-2008 12:59 PM
'98 Marker Light seal? matthews.stang Mustang Audio & Video 4 05-25-2007 11:18 PM
Tail light seal? 19ClearCobra96 Mustang Audio & Video 13 03-27-2005 08:24 AM
Pinion seal now fixed SpectorV Pre-2005 V6 Mustang 2 01-11-2005 07:19 PM
Got a pinion seal leak... SpectorV Pre-2005 V6 Mustang 18 01-04-2005 08:19 PM
05:29 AM
