Water leak! - Mustang Evolution
Old 03-19-2011, 07:54 AM   #1
Pete08GT's Avatar
Water leak!
After running through a touchless wash the other day I noticed water leaking onto the floorboards from under the dash on the passenger side. Anyone deal with this before?
Pete08GT is offline   Reply With Quote
Old 03-19-2011, 10:39 AM   #2
Beav's Avatar
Re: Water leak!
Oh yeah... Open your hood, look for a rubber drain at the lower right of your battery. It is your cowl drain and just a leaf or two can plug it. The drain is a slit, and you can fish the leaves out to let it drain, but you need to open your cowl, change your cabin filter, and clean out any foreign residue... Just a guess...
Cabin Air Filter Install on an 05-09 Mustang - LRS Blog - Read Here Shop Here
Is there a permanent solution to cowl drain issue? - Ford Mustang Forums
07 Roush 427R, Brembo 14" rotor and four piston calipers
05 GT Mustang, FRPP, FR X pipe, Hurst short throw,
American Racing Torque Thrust 10X20 wheels,
Granettelli tower brace, custom painted flat black grafix, Yellow Optima
Beav is offline   Reply With Quote
Old 03-19-2011, 11:50 AM   #3
Stang23's Avatar
Ya just clean out the filter. That happened to me before when it was raining and the water came pouring in.
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
Old 03-19-2011, 05:50 PM   #4
Pete08GT's Avatar
Zipped over to pep boys...bought the filter. Took out the old one...it was black and filthy...
Made sure that everything was clear and installed the new one. Easy fix! Thanks once again for helping out! I love this forum!
Old 03-19-2011, 06:04 PM   #5
Beav's Avatar
Re: Water leak!
Not a problem...
Old 03-29-2011, 07:28 PM   #6
05GTorchRed's Avatar
Ha that's funny. I just washed my car and was wondering why it was leaking. And I just registered at this site. BOOM
05GTorchRed is offline   Reply With Quote
Old 03-29-2011, 07:39 PM   #7
Pete08GT's Avatar
It did work! I washed mine today and guess what?....no leak! This forum is awesome!
Old 03-30-2011, 04:49 PM   #8
Beav's Avatar
Re: Water leak!
I am glad that I could help... It is an easy thing to fix, if you know what to do...
Old 04-01-2011, 10:57 AM   #9
wereKEV's Avatar
Re: Water leak!
That is good to know I'll remember that when mine needs changing.
wereKEV is offline   Reply With Quote
Old 04-03-2011, 11:17 AM   #10
Wolfsbain76's Avatar
Re: Water leak!
I Never knew about this, something else that even I can do!! Thanks Beav!! What's up with holding all this knowledge to yourself, man?! The jig is up, let us pick your brain!! LOL
2007 Mustang GT
Wolfsbain76 is offline   Reply With Quote
Old 04-03-2011, 04:45 PM   #11
Beav's Avatar
Re: Water leak!
Old 04-03-2011, 06:34 PM   #12
Pete08GT's Avatar
Bad news...leak is back! What else could it be?
Old 04-03-2011, 07:35 PM   #13
Beav's Avatar
Re: Water leak!
Is it leaking where you can see it or are you finding water on your floor?
I had strange window issues with one of my 05 GT's where the window wouldn't act normal and wasn't rolling back up that quarter inch when you closed it... When it rained, it let water get onto the floorboards, mostly at the front passenger side. I have read that a bad battery connection, or a weak battery can cause this condition... I tightened connections, wet vacuumed the water out of the car, and the fluke "fixed itself" and I traded the car before the problem reappeared.
Old 04-03-2011, 07:42 PM   #14
Beav's Avatar
Re: Water leak!
Also, check this out, other ideas....
2005 Mustang rain water leak - Ford Mustang Forums
Old 04-15-2011, 07:24 PM   #15
Pete08GT's Avatar
So here is what I did...
1. Open hood and remove passenger side plastic cover.
2. Take a towel and clean out excess water from the area around the cabin filter.
There is a rubber drain toward the center of the window.
3. Pop out the rubber drain by pinching the lip with your left hand and pulling it through the hole at the bottom with your right hand.
4. Remove debris from rubber drain...mine was nasty. I must have missed this the first time.
5. Put everything back together.
Leak is gone for good. I now completely understand why it was leaking into the cabin. The rubber drain was clogged which filled the metal box with water to the point where it was spilling through the cabin filter onto my passenger side floor. The reason I thought it was fixed last time Is because the space is big enough to hold 1 car wash worth of water, but not two. So when I fixed it, then washed the first time there was no leak...but the second time was about a half gallon. Thanks for all the good info! Love this forum!
Old 04-16-2011, 06:26 AM   #16
Beav's Avatar
Re: Water leak!
Anybody with a new Mustang that they park outside should be checking their cowl drain for debris on a regular basis...
Old 04-16-2011, 09:06 AM   #17
wereKEV's Avatar
Re: Water leak!
Thanks for the info beav.
Old 04-16-2011, 10:43 AM   #18
Beav's Avatar
Re: Water leak!
It absolutely freaked me out when I pulled out of the drive and water poured into the passenger foot well, all over my wife in my yellow 05two years ago. I spent a lot of time investigating this problem... By the time I found water on the floor of her 05, I was an old hand at finding water leaks. Water leaks need to be addressed because they can cause major electrical problems and can obviously lead to rusted floor pans. At the very least, wet vacuum excess water as soon as you notice it...
Old 04-16-2011, 10:46 AM   #19
wereKEV's Avatar
Re: Water leak!
That is very good advice , they must have made improvements because my 06 does'nt leak at all so far.
Old 04-16-2011, 01:50 PM   #20
Pete08GT's Avatar
Mines am 08. Like Beav said...check that drain often!
gas leak upton7 Pre-2005 V6 Mustang 7 04-20-2009 01:32 AM
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-27-2008 11:54 PM
oil leak 95blackgt 1979-1995 Mustang GT 6 04-03-2008 09:53 PM
Coolant Leak floridamba Pre-2005 V6 Mustang 0 04-04-2007 08:40 PM
exhaust leak 98StangGT 1996-2004 Mustang GT 8 08-29-2006 03:38 PM
05:13 PM
