tranny problem ? - Mustang Evolution
Old 08-01-2007, 06:04 PM   #1
1 dark demon's Avatar
tranny problem ?
I wonder if anyone is familiar with this problem. when I'm pulling in to a parking space or I'm going on reverse (very low speed) I push the clutch to get on 1st or 2nd . I heard a loud clonck noise in the tranny , and at the time of releasing the clutch too.another problem is when I release the clutch to go on 1st Ican heard a loud grinding noise on the tranny . I've taken it to three different four dealers. the first dealer said that it was normal , three different times. second dealer said that is the gear roll over (normal) . when I took it to the 3rd dealer, they change the clutch and I paid 600.00 and not only not fix the problem but is worse now . what do you think.
1 dark demon is offline   Reply With Quote
Old 08-01-2007, 06:06 PM   #2
hottcobra's Avatar
Re: tranny problem ?
why did you pay for the clutch? Is it not in warrenty?
Old 08-01-2007, 06:21 PM   #3
it should but they say that the clutch is like brakes . warranty don't cover that. but I'm fighting with them .
Old 08-01-2007, 06:25 PM   #4
hottcobra's Avatar
how many miles are one the car.
Old 08-01-2007, 06:26 PM   #5
32,000.milles
Old 08-01-2007, 06:28 PM   #6
that's why ford don't wanna touch it. cuz the warranty expires at 36,000.
Old 08-01-2007, 06:29 PM   #7
hottcobra's Avatar
warrenty cover a failure but not worn clutchs. if it's making noise it's not worn it's failing. but if you already paid for it. it will be hard to get your money back.. the up side is that they didn't fix your orginal complaint and you paid them to do so. so now you have them by the balls. you have a comeback onyour hands thay have to fix it now.
Old 08-01-2007, 06:30 PM   #8
hottcobra's Avatar
they have to fix it. even if it's got 35999 miles. go in their and throw a fit. pull the laywer and BBB card.
Old 08-01-2007, 06:35 PM   #9
excactly !!!!! that's what I'll do!!!! So you don't think that"s normal ??
Old 08-01-2007, 06:39 PM   #10
hottcobra's Avatar
no and the only way you should change your mind is if they give you paperwork from Ford not from the dealership stating it is normal. I work for a Cadillac service dept. I deal with this kind of thing all the time.
Old 08-01-2007, 06:40 PM   #11
oh. I see thanks for the advice !!!
Old 08-01-2007, 07:01 PM   #12
wiarumas's Avatar
good luck... let us know the result of the legal *****ing haha
Old 08-01-2007, 07:24 PM   #13
drive shaft clunk perhaps?
Old 08-02-2007, 08:25 AM   #14
Ibanezplayer272's Avatar
Send a message via AIM to Ibanezplayer272 Send a message via MSN to Ibanezplayer272
Thats what I was thinking. Use to do it in my 5.0, always when putting it into drive or reverse. Turned out to be the U-joints being worn out.
2007 Windveil Blue Mustang GT
Mods : Intake, Stubby antenna
Rolls are for fat chicks
Ibanezplayer272 is offline   Reply With Quote
Old 08-02-2007, 08:35 AM   #15
Y2E0L0L5OGWT's Avatar
i have 35,697 miles on mine, i am going in to my local ford dealership sometime next week to get a bunch of things fixed, hahaha
Old 08-02-2007, 09:25 AM   #16
hottcobra's Avatar
the 05+ mustang uses CV joints in place of the u-joints
Old 08-02-2007, 09:43 AM   #17
stupid two piece driveshaft lol
Old 08-02-2007, 09:45 AM   #18
hottcobra's Avatar
I no all the aftermarket driveshaft made come with tranny yokes for a standard not an auto
Old 08-02-2007, 09:50 AM   #19
I wonder if is the driveshaft but the clunk noise comes from the tranny
Old 10-29-2008, 03:37 PM   #20
i just took my 08 in for the same problem i have 4000 miles on its thay have to replace the syncros on the trans. At first when i dropped it off they couldnt find a problem then i went on a test drive with them and if did it. So now they are fixing it.
vapor08 is offline   Reply With Quote
Old 10-30-2008, 10:16 AM   #21
i bet its the throwout bearing and the driveshaft, sounds like somebody was doing some hard clutch dumps in it.
SimplyOrange is offline   Reply With Quote
Old 10-31-2008, 02:03 PM   #22
I have a clunking sound off & on with my 05 GT. I had a Powerhouse drive shaft that went bad (maybe from racing). So I put the stock D/S back in and it better, but not completely fix. Transmission is fine, had Tony from Larry's Transmission look at it, he found my D/S problem. The only other thing to fix is the rear gears. Powerhouse did fix the D/C free of charge, it's still a great D/S to buy.
1 dark demon give Tony a call, he might be able to help you too.
Shifting gears you can hear the clunking sound.
Here is Tony checking out the drive shaft.
Best transmission shop around.
msgt46270 is offline   Reply With Quote
Tranny Problem? i think... DMAC Pre-2005 V6 Mustang 2 05-16-2007 03:08 PM
Tranny/Shifter problem... Fast93Coupe 1979-1995 Mustang GT 6 04-22-2006 03:26 PM
Shifter clutch or tranny problem??? PA6shooter Pre-2005 V6 Mustang 10 04-28-2005 08:15 AM
tranny problem? 232SCstang Pre-2005 V6 Mustang 3 03-15-2004 01:15 PM
Tranny Problem.... v6mustangguy Pre-2005 V6 Mustang 16 01-31-2004 06:11 PM
10:20 AM
