Supercharged people - Mustang Evolution
Old 04-01-2011, 04:37 AM   #1
Blacks197's Avatar
Supercharged people
Just got my procharger h.o. Kit installation finished up yesterday and had a question for you guys who have installed a supercharger of any kind. What psi are you guys running and rwhp numbers you putting down? My kit came with a 10 psi pulley but I was thinking of dropping it down to 8 psi just to keep from throwing a rod or something. Any stories good or bad will help.
Blacks197 is offline   Reply With Quote
Old 04-01-2011, 07:19 AM   #2
Brett Greene's Avatar
12psi and 650 rwhp. All depends on the guts of the engine of how high of Boost you cab really run safely
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 04-01-2011, 07:24 AM   #3
Re: Supercharged people
since its an s197 you ar efine with 10lbs with no problems...just get a good tune...when i had my 05 gt i had a vortech non intercooled s-trim,comp cams,stage 2 heads and my car was putting down 565 to the tires for 2 years no problems..
10lbs on your car depending on your other supporting mods would probably be low to mid 400 range with no problems..
slow02gt is offline   Reply With Quote
Old 04-01-2011, 07:24 AM   #4
Message Jmeo. He's pretty new here but has a boosted gt with some good hp.
Alscobra is offline   Reply With Quote
Old 04-01-2011, 08:04 AM   #5
Blacks197's Avatar
I have the stock rotating assembly and want to keep it that way for a couple years until I can afford forged internals. I want to keep the hp under 450 which it should be all I have besides it is a axle back exhaust. I have just heard conflicting stories in wether or not 450 was safe. I think the tune has more to do with it than anything else so I'm having it dyno tuned next Friday. Just wondering what you all thought. I guess I'll be safe sticking with the 10psi pulley.
Old 04-01-2011, 08:08 AM   #6
Yea man you should be good. Let us know how it goes. Post up sone pics to . Welcome to the boosted world
Old 04-01-2011, 08:12 AM   #7
Blacks197's Avatar
Thanks man! Been saving up a long time to get this kit can't wait until next Friday so I can drive it. I'll post pics then.
Old 04-01-2011, 08:16 AM   #8
SaleenFiend's Avatar
What mods do you have? What internals?
Old 04-01-2011, 08:39 AM   #9
wereKEV's Avatar
my s197 has a vortech h.o. supercharger with cooler and diablo tune runing 10psi no problems not sure on hp.
wereKEV is offline   Reply With Quote
Old 04-01-2011, 08:39 AM   #10
what do you have done to your car to pull that off?unless its twins with some decent compression that aint gonna happen lol...
Old 04-01-2011, 10:21 AM   #11
He has a 'fully built 347' from what I'm reading... not completely far fetched (although I still have a very very hard time beleiving the claim until PICS of Dyno for proof). He claims $18,000 sunk into the engine. I'm just interested to see b/c I haven't seen him post up all his information.
Old 04-01-2011, 10:25 AM   #12
I have to get my dyne sheet outta my car. But what do you wanna know bout it. I bought a new block with the stroker kit ect. Every part on the engine/drive train is new. The blow it's self cost me 5000
Old 04-01-2011, 10:26 AM   #13
Just your set up spelled out. HCI, bottom end choices, compression, blower brand? ect ect
Old 04-01-2011, 10:28 AM   #14
what size blower? and what block are you running? whats the compression?
just curious because i have seen those numbers b4 but its with a a 80mm turbo ususally ... blower setup usually an f1 series or a big vortech..
Old 04-01-2011, 10:43 AM   #15
I have seen 80mm and f1 series setups into the 1000hp mark.
Old 04-01-2011, 11:09 AM   #16
oh i have too..but i was talking about the 12lbs at 650rwhp...it can be done with a novi 2000 also..
Old 04-03-2011, 09:31 PM   #17
Jmeo's Avatar
Hi, my 05 is putting down 455 RWHP with 11.9 lbs of boost. This is whats up;
Stock block
Whipple H.O. Kit
Whipple 10 rib pulley setup
Kooks long tubes
Kooks catted H pipe
Magnaflow exhaust
FFRP 62mm Throttle body
I have other things done like a Fore fuel rail but the above mentioned parts are what makes my numbers on the dyno. Car runs like a top and pulls hard. My tuner shop could have pulled a more aggressive tune for some more pony's but chose to keep it more on the safe side. Good luck and enjoy!
Jmeo is offline   Reply With Quote
Old 04-04-2011, 05:27 AM   #18
Blacks197's Avatar
Stock block
Whipple H.O. Kit
Kooks long tubes
Kooks catted H pipe
Magnaflow exhaust
How long have you had your supercharger on the car?
Old 04-04-2011, 07:33 AM   #19
get it TUNED fully before you dare test it out, I am sure you know that already.
I am at 14psi and 472rwhp/494rwtq on a dynocom dyno.. I didnt want to go high boost so 12-14 is the sweet spot.
Old 04-04-2011, 07:43 AM   #20
Blacks197's Avatar
Yes I'm not driving it at all right now I'm trailering it to my local speed shop to have it tuned and dyno'd Friday
Old 04-04-2011, 07:43 AM   #21
Jmeo's Avatar
Just put it on over the winter and due to weather here in Massachusetts I would say I have driven it about 600 miles. I think your concerned about how long the block will last. There is no definite but it should last as long as without a blower with a safe tune, proper maintenance and some good old common sense while driving it.
Old 04-04-2011, 08:58 AM   #22
wereKEV's Avatar
I heard 10psi is the amount of boost you can safetly put through a stock 3V motor,any more and it could screw things up.
Old 04-04-2011, 09:00 AM   #23
Blacks197's Avatar
thats what im gonna stick with
Old 04-04-2011, 09:03 AM   #24
i need to take mine and have it looked at for an exhaust leak~ not sure but I may have one... and if so gotta fix it, probably not good to drive it hard with it.
Old 04-04-2011, 10:00 AM   #25
Jmeo's Avatar
My kit is a 10lb kit it just makes slightly more than advertised. Totally safe with a safe tune.
Old 04-04-2011, 04:54 PM   #26
wereKEV's Avatar
So does anybody think I could raise the boost with no danger of motor damage.
Old 04-04-2011, 06:03 PM   #27
Jmeo's Avatar
Well I don't wanna be the guy who says you can. I know my kit and most Whipples make more than advertised and are plenty safe. It's your call but if you decide to add boost just get her re tuned.
Old 04-04-2011, 07:01 PM   #28
wereKEV's Avatar
My supercharger is a vortech h,o.with cooler not sure what it's tuned for because it was moded when I bought it I wish I knew all the details because I would like to know all that was done to it and the hgorsepower out put , But it is awful fun to drive.
Question for you Supercharged people Jmeo 2005-2010 Mustang GT 16 04-19-2011 06:28 PM
Supercharged V6 stout33 Pre-2005 V6 Mustang 13 06-29-2009 05:52 PM
supercharged v6 mustang9403 Pre-2005 V6 Mustang 11 12-12-2008 02:51 PM
supercharged v6? stangracer Pre-2005 V6 Mustang 16 11-03-2003 08:45 AM
05:48 AM
