UDP - Mustang Evolution
Old 05-07-2011, 10:56 PM   #1
gqsmash's Avatar
Will under-drive pulleys benefit my 08 gt? Or would it just be a waste of cash?
gqsmash is offline   Reply With Quote
Old 05-07-2011, 11:59 PM   #2
Send a message via Skype™ to Texastboneking
I had them. I think they are over rated. All I noticed was a low charging rate at idle
Texastboneking is offline   Reply With Quote
Old 05-08-2011, 12:21 PM   #3
gqsmash's Avatar
Thanks for the insight!
Old 05-08-2011, 01:18 PM   #4
Jmeo's Avatar
I had them on my 05 and thought they worked just fine.
Jmeo is offline   Reply With Quote
Old 05-08-2011, 01:20 PM   #5
gqsmash's Avatar
What kind did you have? Was it the crack pulley alone or water pump and alt pulley also?
Old 05-08-2011, 01:21 PM   #6
Jmeo's Avatar
Steeda kit with crank and water pump pulley
Old 05-08-2011, 01:22 PM   #7
gqsmash's Avatar
That's what I'm lookin into!
Old 05-08-2011, 01:25 PM   #8
Jmeo's Avatar
I recommend the Steeda ones
Old 05-08-2011, 01:34 PM   #9
gqsmash's Avatar
Did you feel any more power being put to the wheels
Old 05-08-2011, 01:36 PM   #10
Jmeo's Avatar
Negligible. It all ads up. I would guess 5 rhhp net from them.
Old 05-08-2011, 01:40 PM   #11
gqsmash's Avatar
Right right well I figured it was a little just wasn't sure if it was worth the money
Old 05-08-2011, 02:53 PM   #12
Gibby's Avatar
If I remember right steeds says 10 hp. And that comes from less rotating mass I'm sure which in turn means better throttle response.
Gibby is offline   Reply With Quote
Old 05-08-2011, 05:58 PM   #13
It's minimal power gain. For the price of those pullys you can get other things that help more like a tuner. Or nice sounding exhaust. I just didn't feel like it was worth the money for what it did. Plus on mine the headlights would dim at idle
Old 05-08-2011, 06:14 PM   #14
Jmeo's Avatar
Your headlights most likely dimmed because you were underdriving your alternator too. The Steeda kit I had did not and therefore did not dim the lights. I thought they were worth it due to an increase in HP although small and a slightly better response to revving the engine. To each their own I guess.
Old 05-08-2011, 06:22 PM   #15
Mine was crank only pulley it's ok I guess I just think the money is better spent elswhere. Kind of like cold air intakes. I think it's over hyped for the cost
Old 05-08-2011, 06:36 PM   #16
Jmeo's Avatar
I hear ya. Mine came off to install a Whipple SC but if I were to do it again I would still do underdrives. When you compare $1,200 - $1,400 for LT headers and X/H pipe to gain 30 HP then $200 - $250 for 10 HP isn't bad.
Old 05-10-2011, 09:01 PM   #17
05bluestang's Avatar
Re: UDP
I had them on my 05 until I put the b;ower on. They may not give you more HP but it sure helps spin up the engine faster. Also in the 1 year + I had them I never had any charging issues nor did the headlights dim at idle. Get the Steeda ones, you won't regret it unless you'll plan to put a blower on down the road in which case you cant use them (unless it a Roush TVS).
My 0.02c
2005 Mustang GT, Pacesetter LT's with OR H-pipe, "Magna Pack" exhaust, Techco SC @ 9psi making 464whp & 449tq, steeda tri-ax shifter, 3D Carbon Eleanor Grill, Pioneer F90BT, FRPP 3.73 gears.
Get in, sit down, strap in, hold on, shut up!
05bluestang is offline   Reply With Quote
Old 05-10-2011, 09:05 PM   #18
Re: UDP
if im going for horsepower im going big. im getting cams, supercharger, turbo. something that is going to make a for sure difference. after you spend several grand on all the little crap. you would have enough for something that will make real power. my theory.
Old 05-11-2011, 02:09 PM   #19
Blacks197's Avatar
I'm with you. I did a couple little things then decided I would stop doing small things and save for a supercharger. Took a while but was well worth it once I got my procharger
Blacks197 is offline   Reply With Quote
Old 05-11-2011, 03:36 PM   #20
Re: UDP
my friend put a steeda crank underdrive pulley on his 08 and he picked up 5-7rwhp or so from it~
UDP or not? 03blumist Pre-2005 V6 Mustang 4 12-13-2010 07:20 AM
fs 99-04 25% udp mustang0386 Mustang Parts for Sale and Wanted 1 03-04-2007 02:48 PM
udp mustang0386 Pre-2005 V6 Mustang 6 12-18-2006 01:02 PM
UDP Kit crazeflier07 Mustang Parts for Sale and Wanted 3 04-21-2006 06:49 PM
CAI V. UDP SixSilver Pre-2005 V6 Mustang 23 08-09-2003 09:55 PM
12:21 PM
