Rear tire size? - Mustang Evolution
Old 05-09-2011, 01:08 PM   #1
waldo7650's Avatar
Rear tire size?
Need some input on what size rubber to put on my 09 GT. I am thinking of purchasing the Godspeed Omega Deep Dish Black Chrome wheels (18x9 front and 18x10 rear). I plan on running 255/45/18 on front but don't know what to run on rear. I saw on one tire site they have a package with 275-40-18 for rears............... then found another tire site that has wheels packaged with 295-45-18. My 09 GT suspension is stock and I want to make sure that what ever wheel/tire i pick with fix without any rubbing etc. All advice and experience is greatly appreciated!
waldo7650 is offline   Reply With Quote
Old 05-09-2011, 07:38 PM   #2
I have an 06 gt with 255 in the front and 275's in the rear on 20's. No issues at all on stock suspension.
Nyce03 is offline   Reply With Quote
Old 05-10-2011, 01:53 AM   #3
Starfighter's Avatar
Re: Rear tire size?
Here is a good calc to help with the tire size
Tire size calculator
2005 Mustang GT, Silver, JLT CAI + SCT Tuner....more to follow
Starfighter is offline   Reply With Quote
Old 05-10-2011, 03:46 AM   #4
Murph's Avatar
Region: Maine
Re: Rear tire size?
Mustang Tires - Aspect Ratio, Tire Width, and Wheel Diameter Explained at AmericanMuscle.com
Murph's Glassback!
Murph is offline   Reply With Quote
Old 05-10-2011, 10:05 AM   #5
05bluestang's Avatar
Re: Rear tire size?
It all depends on your offset, I know people the run 315/30-18's or 305/45-18 nitto drag radials without a problem. Just make sure you front to rear ratio is not too far off or will cause problems with you ABS due to the different wheel speeds. Myself, I am having my rims widened later this year and will run 335/30-18's after that in the back and 285/35-18's on the front (yes they fit). Right now I am running 275/40-18 on the front and 285/40-18's on the rear with a 1 1/2" drop withour problems.
my 0.02c
2005 Mustang GT, Pacesetter LT's with OR H-pipe, "Magna Pack" exhaust, Techco SC @ 9psi making 464whp & 449tq, steeda tri-ax shifter, 3D Carbon Eleanor Grill, Pioneer F90BT, FRPP 3.73 gears.
Get in, sit down, strap in, hold on, shut up!
05bluestang is offline   Reply With Quote
Old 05-11-2011, 04:24 PM   #6
waldo7650's Avatar
Re: Rear tire size?
Thanks everyone! I appreciate all the info! BTW starfighter, that tire calculator rocks! I didn't know there even was such a thing!
Old 05-12-2011, 08:44 AM   #7
Re: Rear tire size?
a 9 inch wide tires need AT LEAST a 265 wide tire, a 275 is the best fit. Do not go any smaller than a 265, and I highly recommend a 275. I have 275/35/18s on my front fit perfect.
For a 10 wide rear a 295/35/18 works great NO SMALLER. I wouldnt go wider than a 305 on a 10 wide with an average fit tire (every tire measures differently)
Old 05-21-2011, 02:09 PM   #8
03GT88's Avatar
Why no smaller than 295 35 18 for a rear on 10 inch?
03GT88 is offline   Reply With Quote
Old 05-21-2011, 08:15 PM   #9
Loc: Austin,TX
Re: Rear tire size?
I'm running a 285/30 in the rear on a 10" and they look,fit and perform just fine.
Old 05-21-2011, 08:51 PM   #10
03GT88's Avatar
Good to know. The 295 35 18s are stupid high priced
Old 05-21-2011, 09:21 PM   #11
UHNIL8's Avatar
I had 295 35 19 kdw2 on a 19x10.5 rear. Had room to spare. no rubbing. On a 06' gt.
2008 GT500 conv.
May the Horsepower be with you
UHNIL8 is offline   Reply With Quote
Old 05-21-2011, 09:35 PM   #12
03GT88's Avatar
I'm putting 18x10s on the rear of my 03 gt. I can't afford new 295 35 18. Need something cheaper with same looks
Old 05-22-2011, 12:02 AM   #13
Loc: Austin,TX
Re: Rear tire size?
Is it a high HP car or do you just want the look? If its not the 275s still look really good.
Old 05-22-2011, 02:39 PM   #14
03GT88's Avatar
Its not too extreme so I May get them. Its still more tire than the stock Size I have
Old 06-23-2011, 10:46 PM   #15
Re: Rear tire size?
I have an 08 and I am running the 255/45/18 on the front with 285/40/18 on the back. It looks great on the car and there is no rubbing and i am on stock suspension it drives and handles great.
Murdered_Stang is offline   Reply With Quote
Old 06-24-2011, 07:16 AM   #16
Re: Rear tire size?
every tire manuf. runs different there is no standard to what the sizes actually mean... sadly. I recommend no smaller than a 295 as if its a narrow tire or even a normal ran tire it will be right, any smaller will be to narrow and your rim lip will be exposed, looking bad and being easier to run on a curb.
Old 06-26-2011, 10:37 AM   #17
Windveil88's Avatar
Re: Rear tire size?
These are 275/40/18s. The wheel itself seems to be tucked in just fine, but as soon as I can, I will be getting 295s or 305s.
For now, I don't come within 10 feet of any curb.
Windveil88 is offline   Reply With Quote
Old 06-26-2011, 10:50 AM   #18
Ninjasteffers's Avatar
I have staggered 19" Tenzo wheels with 305/30/19 Nitto Invo's on the back... Yes it sticks out a bit but i wanted that old school muscle look
Ninjasteffers is offline   Reply With Quote
Old 06-26-2011, 10:56 AM   #19
poloka's Avatar
Looks good! What you running up front?
2011 GT 5.0 Supercharged Phase 2 TVS2300
http://www.mustangevolution.com/forum/f376/t290294/
poloka is offline   Reply With Quote
Old 06-26-2011, 11:51 AM   #20
Thanks .. The fronts are 245/35/19 with 1/2 spacers
Old 06-27-2011, 09:32 AM   #21
Re: Rear tire size?
if you cant afford the tires then get a smaller rim~ dont put the wrong size tire on a rim
New Tire size help. explicitrock Mustang Wheels & Tires 11 03-07-2011 12:30 PM
Tire size?? FordFan87 Mustang Wheels & Tires 3 01-14-2011 10:56 PM
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
tire size stang-rookie Mustang Wheels & Tires 2 05-15-2005 02:54 PM
Tire size Help 35thAniVertible Mustang Audio & Video 1 11-03-2003 01:23 PM
03:34 PM
