Ford racing lowering springs - Mustang Evolution
Old 05-23-2011, 03:10 PM   #1
buck199's Avatar
Has anyone had any problems with alignment and camber issues with just putting Ford racing springs on ?
buck199 is offline   Reply With Quote
Old 05-23-2011, 03:26 PM   #2
Loc: Austin,TX
Re: Ford racing lowering springs
Not I....Ive had the K springs on my 07 and on the 2011. You will need a allignment afterwards of course and it is up to you it you want to use the caster camber plates that will run you around $300 or the Camber bolts that are about $30. The K springs dont drop it that much so some choose not to do either. Go get a allignment and ask for a print out so you can see it you have a issue.
Old 05-23-2011, 03:33 PM   #3
buck199's Avatar
Man. Thanks a lot great info. I was really thinking the same thing . My buddy had the k's on his 06'. And to honest it doesn't look that dramatic of drop. I have the aggressive CDC chin spoiler enroute from AM and thought of the springs as well. But I am thinking of putting that $ towards a better mid pipe ! I like the higher stance with that splitter ( looks 69' boss-ish ! ) thanks again
Old 05-23-2011, 03:37 PM   #4
Loc: Austin,TX
The K springs on the 07 and 11 have a different look. The 11 looks and feels a ton lower,Ive had friends tell me that they can barely see under the car when in front or behind me.
Here are a couple pics of my 07 and the 2011 with the same K springs.
Old 05-23-2011, 03:43 PM   #5
buck199's Avatar
Looks great ! Really nice !!
Old 05-23-2011, 04:02 PM   #6
buck199's Avatar
So there is no way to get around it ? You have to get a alignment when using k springs ? It's not a bolt on and go ?
Old 05-23-2011, 05:28 PM   #7
Loc: Austin,TX
You are messing with the suspension so if you wanna drive around with a screwed up alignment and cause wear on your tires than that will be up to you. Just get it aligned soon after the install.
Old 05-23-2011, 05:30 PM   #8
Cdlax93's Avatar
Lmao I was about to ask you if you have two different rims on your stang ( black on the left chrome on the right) till I looked closely and saw that one was ur 07 stang and the other was the 11 hahahaha
Cdlax93 is offline   Reply With Quote
Ford Racing C-Springs BirminghamStang Pre-2005 V6 Mustang 8 12-22-2005 05:49 PM
FRPP Lowering Springs - G Springs Stangthang Pre-2005 V6 Mustang 9 02-23-2005 03:57 PM
Ford Racing C Springs and Stock Rims White6Pack Pre-2005 V6 Mustang 5 09-05-2004 06:31 PM
Ford Racing C Springs....$121?? 02Stang Pre-2005 V6 Mustang 2 05-13-2004 06:27 PM
Lowering Springs -- How Much? Stang01 Pre-2005 V6 Mustang 7 09-20-2003 12:07 PM
04:23 PM
