Clutch problems..... - Mustang Evolution
Old 05-31-2011, 02:25 PM   #1
Gibby's Avatar
I was drivin down the road the other day, another car ran me off the road and I went into some sand. didn't get stuck but right away my clutch starte to feel weird. Later on that day I went to go drive my car and it was almost impossible to get into gear when I was goin down the road. I turned around jacked up the car and check everything and all Seemed to be good. I pressed an released the clutch about ten times and tried again and it worked. But now at high rpm it's kinda hard to shift. Any suggestions?......
Gibby is offline   Reply With Quote
Old 05-31-2011, 02:33 PM   #2
Send a message via Skype™ to Texastboneking
Re: Clutch problems.....
weird problem, first think i might look at is take the shift boot out and make sure there aint sand sitting around the shifter. just a guess...
i dont see how sand should effect the clutch or the tranny
Texastboneking is offline   Reply With Quote
Old 05-31-2011, 02:49 PM   #3
Gibby's Avatar
Well I thought sand may have gotten in the tranny through the inspection hole. The s197 isn't a drop in shifter its a linkage. So I'm baffled. : /
Old 05-31-2011, 02:53 PM   #4
well the transmission is sealed for the most part. sand shouldnt be able to get in it.
Old 05-31-2011, 02:57 PM   #5
Gibby's Avatar
The tranny is sealed but the bell housing has inspection holes. I thought maybe some sand got up in the clutch or some ****. Hell I don't know. Ive been wanting to buy an after market clutch and flywheel anyways so I'm gonna do that and see if I can't see anything.
Old 05-31-2011, 03:00 PM   #6
lol my bad. when you stated it was hard to shift i thought you ment the shifter was tight and hard to get into the gears. you mean the clutch is hard to press. yes you probably got sand in there
Old 05-31-2011, 03:07 PM   #7
Gibby's Avatar
The clutch pretty much feels the same, but it's hard to get into gear at high rpm.
Old 05-31-2011, 03:21 PM   #8
sounds like its time to pull the tranny and inspect...
Old 05-31-2011, 03:34 PM   #9
Gibby's Avatar
Yea. Bad thing is it's my DD and I have no other car. Soo I'll have to wait till the weekend.
new clutch problems nasty99 1996-2004 Mustang GT 14 03-10-2011 03:04 PM
clutch engagement problems 1996v6stang Pre-2005 V6 Mustang 11 05-19-2010 08:31 AM
2006 Mustang clutch problems brokenford Pre-2005 V6 Mustang 1 03-18-2008 12:48 PM
clutch? roach 1996-2004 Mustang GT 5 03-23-2007 01:58 PM
Using a used clutch? Tbird232ci Pre-2005 V6 Mustang 2 01-16-2004 07:24 PM
04:04 AM
