heads - Mustang Evolution
Old 07-11-2011, 06:19 AM   #1
heads
I need to know this, are the blocks for the 2v and 3v the same?
rashii is offline   Reply With Quote
Old 07-11-2011, 06:34 AM   #2
Send a message via Skype™ to Texastboneking
For the most part yes. Slight differences as far as outside of the block bolt holes.
Texastboneking is offline   Reply With Quote
Old 07-11-2011, 06:51 AM   #3
So the head mounting holes are in the same location, just have to use 3v exterior accessories, ie exhaust, etc
Old 07-11-2011, 07:01 AM   #4
Let me go double-check
Old 07-11-2011, 07:41 AM   #5
Ok. Checked with my buddy here at the ford house. He said the bolt Patters are the same. But he said your harness won't work with it cause of a different cam sensor. And you most likely can't use a PCM and harness out of a newer 3v cause your cluster and other modules won't be compatible.
He said if it was an easy swap many ppl would have already done it. But he says he knows no one that has successfully done it.
got some new heads cam question workmail21 1979-1995 Mustang GT 6 07-11-2011 09:09 PM
93 fox gt black.fox.93 1979-1995 Mustang GT 6 07-10-2011 12:24 PM
I wanna go FAST! CodyNelson 1996-2004 Mustang GT 61 06-24-2011 10:20 PM
12:16 PM
